faux Samba Member
Joined: April 16, 2006 Posts: 44 Location: UK, South Wales
Posted: Thu Jun 05, 2025 7:11 am Post subject: 1960 Split Bus pop out catches |
I'm trying find out why there is a difference between long spoon and medium spoon pop out catches. I keep getting told that they are the same fit and will fit all years but the photos here show something different. The long spoon is a repro and came off my 1960 Kombi (closes the window perfectly), and the medium spoon is an original but will not fit, (the spacing means the spoon won't fully close).
faux Samba Member
Posted: Thu Jun 05, 2025 7:12 am Post subject: Re: 1960 Split Bus pop out catches |
Can anyone share pictures of medium spoons fitted? |
BruceFD Samba Member
Joined: August 31, 2020 Posts: 20 Location: Placentia, CA
Posted: Thu Jun 05, 2025 9:31 am Post subject: Re: 1960 Split Bus pop out catches |
I found this to be the case on my 1959 Micro as well. The medium latch will not fit no matter how much adjusting and bending I do to the latch or bracket on the pop out. Original and Repop 'long' spoon works fine and closes great.
Anyone know if VW made different medium spoons post barndoor? |
Joined: April 27, 2002 Posts: 6824 Location: Pentwater, Michigan
Posted: Thu Jun 05, 2025 9:47 am Post subject: Re: 1960 Split Bus pop out catches |
I have a medium spoon on my 1957 Kombi. My understanding is that it was factory installed on the forward cargo door so that it will not interfere with opening the passenger front door. My other five spoons are the long ones. I’ve not noticed any issues with my spoons. I am away from home so can’t take pictures. _________________ Roads Scholar
Member# 2059 |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19850 Location: Land of Whine and Phonies
Posted: Thu Jun 05, 2025 2:04 pm Post subject: Re: 1960 Split Bus pop out catches |
From the gallery _________________ Roads Scholar
Member# 2059 |
faux Samba Member
Posted: Fri Jun 06, 2025 2:27 am Post subject: Re: 1960 Split Bus pop out catches |
BruceFD wrote: |
I tried fitting to the front cargo door and the rear passenger side window (11 Window with 6 factory pop outs) with no luck. There may be some adjustment in the rear, I'll have a look at that later today I hope. |
faux Samba Member
Posted: Fri Jun 06, 2025 2:31 am Post subject: Re: 1960 Split Bus pop out catches |
faux wrote: |
BruceFD wrote: |
Thank you, I will compare these to the ones I have, I wonder if they made changes from 58 to 59?
Also, I can not find anything that says what the pop out catches would be on a 60 bus with factory pop outs? What di my bus leave the factory with? |
faux Samba Member
Posted: Fri Jun 06, 2025 9:32 am Post subject: Re: 1960 Split Bus pop out catches |
The mystery is solved to a certain extent. There are adjustable plates at the rear of a 60 bus which allows fitment of the medium spoons but the others are factory and will only allow short and long spoons.
Posted: Fri Jun 06, 2025 9:44 am Post subject: Re: 1960 Split Bus pop out catches |
faux wrote: |
The mystery is solved to a certain extent. There are adjustable plates at the rear of a 60 bus which allows fitment of the medium spoons but the others are factory and will only allow short and long spoons. |
That sorta makes sense, but everything I've read on here says on a early factory 6 pop-out bus, it should have 5 long laches, and 1 med latch - on the forward facing cargo door. I am still curious if the latches from Barndoor-era buses (medium latches) are different than post barndoor. Ill measure my medium latch tonight (it also doesn't fit on any position other then the rear) but I don't think it will be any different.
Can anyone with a nice fitting (front cargo door) Medium latch take it off and measure the mounting position so maybe we can get to the bottom of this. |
faux Samba Member
Posted: Fri Jun 06, 2025 12:16 pm Post subject: Re: 1960 Split Bus pop out catches |
I was told that a 58 had adjustable plates (like the rears on the 60) all around. I haven’t seen this but it was from the person I bought the medium spoons from.
I would really like to know the differences in catches and the years they were introduced and fitted. I don’t seem to know anyone who can answer this and the repro catches all say up to 67 and are all universal. Now I know different, unless the repros are based on the smaller footprint (which would fit all my windows). |
Stocknazi Samba Member
Posted: Sat Jun 07, 2025 5:37 am Post subject: Re: 1960 Split Bus pop out catches |
No bus had six (6) long spoons. A spoon latch (some like to call them medium spoon) was always used on the forward cargo door to prevent the passenger door from smashing into the window when opened. Long spoon latches used on the other five (5) windows.
Are your pop-out window frames original or reproduction?
If your reproduction latches fit and the originals do not I would suspect the frames are not original. No way to tell without pics of what you have going on though.
All buses have the same slotted plates in the rear AFAIK. I've never had any issues with long spoon or "medium" spoon latches working with original pop-out frames. No changes to the pop-out window mounting sheet metal or frames that I know of. _________________ WANTED:
Thomas Jefferson |
faux Samba Member
Posted: Sat Jun 07, 2025 9:41 am Post subject: Re: 1960 Split Bus pop out catches |
That is what I thought, but my 60 has all original pop outs and the original plates welded to the bus.
Why would they have slotted rear if it wasn’t to allow for this? Apart from one long spoon, all of my pop outs catches are original.
So, if what you are saying is correct, how are long spoon and medium spoon fittings 2/8” different? It isn’t an issue with the bus, it is the difference in the catches dimensions that causes the problem, thus the medium and long spoons fittings on rear due to the slots. Some has said that their 58 had slots all round but I haven’t seen these in the flesh or in picture. |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15310 Location: Casa de Oro, California
Posted: Sat Jun 07, 2025 6:19 pm Post subject: Re: 1960 Split Bus pop out catches |
Stocknazi wrote: |
A spoon latch (some like to call them medium spoon) was always used on the forward cargo door to prevent the passenger door from smashing into the window when opened. |
How close is the rear cargo door window to the window behind when the check strap is off and the door wide open? |
faux Samba Member
Posted: Sun Jun 08, 2025 4:10 am Post subject: Re: 1960 Split Bus pop out catches |
BarryL wrote: |
Stocknazi wrote: |
With the medium spoons in the rear open, I can open the cargo door to the rear of the bus (with window closed) and the door just touches the rubber of the pop out. I assume it would be the same with the front cargo door and the front passenger door, but as above, the medium spoon won’t fit there, just a long spoon. |
GERMANAIRE Samba Member
Joined: August 25, 2007 Posts: 787 Location: BUFORD,GA.
Posted: Mon Jun 09, 2025 6:01 pm Post subject: Re: 1960 Split Bus pop out catches |
Here is a picture of the medium spoon latch on the front cargo door as it came from factory. Hope this helps.
faux Samba Member
Posted: Tue Jun 10, 2025 12:45 am Post subject: Re: 1960 Split Bus pop out catches |
faux wrote: |
BarryL wrote: |
Stocknazi wrote: |
On my 60, the rubber of the pop out is just touching the rear side window. |
faux Samba Member
Posted: Tue Jun 10, 2025 3:21 am Post subject: Re: 1960 Split Bus pop out catches |
GERMANAIRE wrote: |
Thanks for this, what year is the bus? |
Posted: Tue Jun 10, 2025 5:10 am Post subject: Re: 1960 Split Bus pop out catches |
faux wrote: |
GERMANAIRE wrote: |
It’s a 1957 Kombi
https://www.thesamba.com/vw/forum/viewtopic.php?t=800764 |
faux Samba Member
Posted: Tue Jun 10, 2025 11:15 pm Post subject: Re: 1960 Split Bus pop out catches |
That makes sense, I still think the early spoons like this only fit early busses (maybe up to 58?). Now I need to find out if there is a difference in hole placement on the early ones. |
