Brazilian Split 4 stud wheels
Redfox2020
Redfox2020 is offline
PostPosted: Thu Jun 05, 2025 11:12 am    Post subject: Brazilian Split 4 stud wheels Reply with quote
I've bought a Brazilian split window bus. It's been lowered and is riding on 14 inch 4 stud wheels. My understanding is that the buses ran 5 stud wheels. Any ideas what the set up is that's allowed a 4 stud wheel to be used. It's discs front drums on the back.
Clara Premium Member
Clara is offline
PostPosted: Thu Jun 05, 2025 11:43 am    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
Yes, split buses came new with wide five bolt pattern, so yours has some mods.
post pics of your suspension, what the wheels were bolted to.
Redfox2020
PostPosted: Thu Jun 05, 2025 1:14 pm    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
[img] this is the beam.
[/img]
Clara is offline
PostPosted: Thu Jun 05, 2025 3:36 pm    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
[/img]
I see a king/link spindle, but not what the front wheels bolts to.
Does it have 4 lug wheels in back as well? Could be a beetle tranny in back.
From the angle of the trailing arms, could be a turned beam. But that doesn't mean how the wheels bolt on.
panel
panel is offline
PostPosted: Thu Jun 05, 2025 5:57 pm    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
Can you post a pic of the spindle with the brakes etc ? And the same for the rear....brake area where the wheel bolts to.
My '65-Subaru EJ20 Turbo conversion
Redfox2020
PostPosted: Fri Jun 06, 2025 12:20 am    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
Hi, I'll try and get the wheels off tomorrow and some pics of the set up. It's 14 inch 4 stud wheels all round, adjustable spring plates and drums on the back. It's too low for the roads here, speed bumps everywhere.
71 Karman Ghia
73 Split Bus
Malokin Martin
Malokin Martin is offline
PostPosted: Fri Jun 06, 2025 12:42 pm    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
I have a feeling this is going to be good…
Redfox2020
PostPosted: Sat Jun 07, 2025 12:39 am    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
Thanks everyone. I got the wheels off today. The front is using spacers and looks like discs have been drilled to accept the 4 stud pattern? Rear is this a beetle transaxle? No engine in at the moment so back is sitting higher than it usually does.
71 Karman Ghia
73 Split Bus
Redfox2020
PostPosted: Sat Jun 07, 2025 12:59 am    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
Rear drum set up
71 Karman Ghia
73 Split Bus
pondoras box
pondoras box is offline
PostPosted: Sat Jun 07, 2025 4:41 am    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
I don’t know what that is but I do know I would be terrified to drive that. Please just get stock brakes back on it and ditch that mess. Wheels look cool but not at the cost of your safety.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
Another 65 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
Stocknazi
Stocknazi is offline
PostPosted: Sat Jun 07, 2025 5:14 am    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
What the bubba??? Shocked
Someone just got on about it with this one. I'm diggin' the front shock.
Yeah, ditch all that crap and start over with the proper parts.
WANTED:
Thomas Jefferson
Redfox2020
PostPosted: Sat Jun 07, 2025 12:29 pm    Post subject: Re: Brazilian Split 4 stud wheels Reply with quote
Yes quite shocking. I'd intended to overhaul the brakes and suspension but not sure if it's worth salvaging that front beam or starting from scratch?
Any thoughts on the rear setup? Scrap it and start again? Ideally would like to convert to disc brakes.
71 Karman Ghia
73 Split Bus
