RUNWAY13 Samba Member
Joined: November 13, 2024 Posts: 50 Location: Colorado
Posted: Thu Jun 05, 2025 9:49 pm Post subject: trying to get the horn to work! |
I have read diagrams and posts about this but my 74 sb has a porsche 924 steering wheel.
new horn and new wiring from the brake light wires to the horn.
Can somebody tell me about how the ground works on the steering column. i get the part about it grounding with the column. i have tried grounding the wire from the steering wheel to the column...no go!
the ground wire coming from the horn itself goes under the dash somewhere, possibly to the two column switches via the harness plugs at the base of the dash and column.
does it, ground wire continue to one of the switches (turn signal or wiper) and then some how gets to the horn button?
Could it be the base of the 924 steering wheel cannot make contact with something to carry the ground circuit to the horn button?
looking for some help on this....go easy on me, i rode the short bus...lol thanks in advance!!!
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1486 Location: San Diego
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2104 Location: Wichita, KS
Posted: Fri Jun 06, 2025 6:50 am Post subject: Re: trying to get the horn to work! |
Here's a link to info & pictures on how the stock horn setup is configured and works in late models Beetles -- may give you some insight in dealing with your modded system:
https://www.thesamba.com/vw/forum/viewtopic.php?p=10175381 _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2477 Location: Gladstone, Ore
Posted: Fri Jun 06, 2025 4:47 pm Post subject: Re: trying to get the horn to work! |
I fought the horn in my 72 super for years. I could never get a good clean ground through the steering column. I could get enough flow to light up a test light so I knew it was wired correctly, but not enough to honk the horn. I added a relay to the circuit, with a negative trigger, and now the 53 year old horn sounds great.
It takes only a small amount of flow to tickle the relay, sending out a resounding blast.
Google "relay with a negative trigger" for a simple wiring diagram. _________________ 1972 1302
HPMX 40's & 019 |
