70’DerpyDerby Samba Member
Joined: July 25, 2023 Posts: 41 Location: San Leandro, CA
Posted: Mon May 19, 2025 10:05 pm Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Good evening y'all!
It has been quite a while since I posted last, about 9 months ago actually. Since my last post my wife and I got married, sold her car and bought an Expedition, and a whole host of other life things that have slowed progress on the car. No big deal, that's the perk of project cars right? They'll always be there when you have time and get back to them!
Anyways, in the last few months I resealed the input and output shafts on the transaxle, started assembly of the engine with new bearings, a mild cam, painted both the engine block and trans, started painting all kinds of odds and ends, and ordered a hoard of parts. I also picked up a German 34 Pict-3 recently, it needs a rebuild and an idle shutoff valve, but otherwise it is complete.
The engine should be completed this week with a brand new set of 1641 pistons and jugs from A&A, new windage pushrod tubes (for whatever those are worth) and I cleaned up and painted the headstuds. I drilled and tapped an oil passage plug towards the bottom of the engine to accept an oil temp sensor, as I figured that would give me a good and accurate reading.
Today I also received another box of wholesale clouseout parts from RockAuto including a washer pump kit for $13, an adjustable cooling fan temp switch for $9, and a points kit for $3.
If you made it this far thank you for reading and following along, I really appreciate it!
_________________ Phil “Deluxe”
1970 VW Bug "Derby" |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4940 Location: Stuck in Ohio
Posted: Sat Jun 07, 2025 9:00 am Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Buggeee wrote: |
Congratulations!!!
This is such a thorough effort, the bug is going to be awesome. Super impressive how you pieced together the pans from all those quarter pans.
Thank you very much Buggeee!
It’s been a long road up to this point, but I’m hoping to have it moving under its own power by August. We’re now under contract for a house, so with moving in 4 months, job hunting, and getting stuff packed it’s going to be tight but I think I can make it. _________________ Phil “Deluxe”
Posted: Sat Jun 07, 2025 9:08 am Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Just a quick update from the last couple of weeks.
I’m working on getting the engine fully assembled and ready to test fire. I still need to clean out the intake crossover piping as it’s plugged with rust and dirt. Tins still need final fitment before painting, and I have get seats in it for mounting location measurements. On the bright side, I found a local guy giving away a bunch of free VW stuff. 10 wheels, 5 chrome with tires, and 5 OEM wheels. Also had a VW engine stand and a bunch of other goodies. Not a bad Tuesday afternoon if you ask me!
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11223 Location: Huntington Beach, CA
Posted: Sat Jun 07, 2025 10:15 am Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Congratulations! I have been married for 31 years and it has been an awesome journey! Not easy, not hard, just perfect! I had to learn to listen and keep my mouth shut. Took 10 years. Those were the roughest ones. After learning to just listen, life got way easier!
DUDE! I just caught back up! You are killing it! Fast working hands for sure!
Looking forward to hearing it roar to life! Keep on moving forwards. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Sat Jun 07, 2025 11:59 am Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
VW_Jimbo wrote: |
Looking forward to hearing it roar to life! Keep on moving forwards. |
Thank you Jimbo!
It’s been a very rewarding life change, and I’m very happy to have such a supportive partner that is happy to be involved in trips to the junkyard and other places to procure parts.
The car is coming along well, but I’m still a ways out from running and driving. My goal for this month is to fit all the tins on the engine and get them painted, and then fabricate seat mounts and weld in the jack mounts and battery mounts so I can paint the whole chassis assembly. _________________ Phil “Deluxe”
Rome Samba Member
Joined: June 02, 2004 Posts: 10585 Location: Pearl River, NY
Posted: Sat Jun 07, 2025 1:12 pm Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Before you continue on your engine, remove the 4 small M6 bolts that hold the generator backing plate to the fan shroud. Rotate the backing plate with the gen 1/4 turn CW so that the gen's terminals point upwards at the "2:00" position.
There is an air duct inside the backing plate (inside the fan shroud) which needs to be in the corrected position to enable air to pass through the duct and thereby help cool the end of the generator.
Measure each of your 10 free wheels carefully for overall width and the backspacing. The chrome ones look to be 5.5" wide. The unpainted ones would be either 4.0", 4.5" or 5.5" wide, with various possible backspacing/offsets. Some wheels have the width stamped into the flat sections between lug bolt holes. If they have "ET_" stamped in, that is the offset in millimeters (ET stands for the German word Einpresstiefe, meaning press-in depth = offset). Usually the wider wheels fit best on the rear axle. For the fronts, just find a pair of the narrower ones that are exact matches. |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 904 Location: Moreno Valley
Posted: Sat Jun 07, 2025 1:17 pm Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
this is my 70 FrankenBug , it had a baja bug front end on it when i got it . 40 some years ago .
do as Rome said , your generator it tilted wrong so the venting isnt right . ya air is forced thru the genny .
Posted: Sat Jun 07, 2025 3:06 pm Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Rome wrote: |
There is an air duct inside the backing plate (inside the fan shroud) which needs to be in the corrected position to enable air to pass through the duct and thereby help cool the end of the generator. |
I’ll definitely make sure to orient it appropriately when I reinstall it. By chance would you know the proper install of the thermostat flap linkage? For whatever reason I can’t seem to be able to get it lined up without it either hitting the case or missing one of the flap rods. I’ve searched the forums but I can’t get a definitive visual of the orientation. Thank you for your help and advice! _________________ Phil “Deluxe”
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 475 Location: Eastern north carolina
Posted: Sun Jun 08, 2025 4:12 am Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Nice work all around , you are an inspiration to all the young vw enthusiasts who by following your progress , get motivated to take on a similar project. I had a 1970 diamond blue bug brand new and it was one of the best all around bugs I ever owned. If I remember correctly the sunroof on your car has 2 drains that go down the front windshield pillars, make sure they are not clogged. Someone please correct me if I am not remembering that correctly as it's been a lot of years. Is that 67 bug we see in your photos also yours? Best of luck with your car-Bob |
Posted: Sun Jun 08, 2025 9:07 am Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Thank you Bobs67vwagen, I really appreciate the support!
It’s been a long road here but there is a light at the end of the tunnel. The sunroof does have drain holes, which are clogged. However the sunroof also doesn’t have a seals anymore so it has to be tarped before it rains.
That is a 67’; It’s my buddies who has let me keep my jalopy in his driveway for 2 years. _________________ Phil “Deluxe”
Posted: Tue Aug 05, 2025 10:05 pm Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Good evening everyone!
Since the last time I posted I have made quite the progress on Derby.
I started with patching the hole I created after cutting out rust from the death foam.
Even gave it a good coat of restoration-in-a-can!
I then test fit the Honda Civic SI seats in the car, and boy do they fit perfectly. I used 2x4's as spacers and found that 1.5" is exactly the height needed all the way around to set the seat height to the perfect spot. I have the seat slid all the way to the back of the seat tracks, and it's a bit far back for me as a 6' man, so I think that gives it a little extra room to fit a bigger person. It also spaces it about 1' from the rear seat support brace, so there wont be any rubbing issues when I made the rear compartment lid to replace the seat.
I also utalized seat belts from a 2018 Explorer rear seat. They are nice and compact but also function perfectly, and look really nice. I may make covers in the future for them but its towards the bottom of current concerns.
I ordered a cheap chinese rebuild kit from RockAuto that included my missing idle shutoff valve. I did retain the original Solex float as it seemed to be in perfect condition. I cleaned out all the tubes and orifices in the carb after soaking it in carb cleaner for half an hour. I do know the choke is clocked farther than most, but that is the location it originally was and seems to be happy at the adjustment. I also removed the original fuel inlet tube, drilled, and tapped the hole for an 1/8"npt fitting to 1/4" barb. I will also not be using the supplied plastic fuel filter, as I have a glass and metal assembly from Dorman I am going to try out.
I started the final assembly of the engine, specifically getting the tins and exhaust manifolds on to see how everything fit after paint. I also got the disributor sorted out. I originally ordered a set of cap and rotor but they ended up being too tall. I sourced some NOS parts and that turned out perfectly. I replaced the condenser on the distributor before install, and cleaned the points with a points file as well. That has been set to 0° timing at TDC on the #1 and will be adjusted during first fire-up.
I did notice the 70's era filter adapter (which I know will be very polarizing, but I ask you refrain from giving me hell for it ) was running into the aftermarket exhaust. I have not decided yet if I'm going to cut and weld the tubing to get the needed clearance, but for now I left it off.
I decided to take a break from building the engine to install the rear window since I am done welding inside the shell in that area. I prepped the pinch-weld and applied some rust-reformer to the window frame. I then installed the new Cal-look seal and popped the glass in. It worked out perfect using jute rope soaked with soapy water, and some plastic trim tools to help it along.
I installed the fan shroud after notching it to clear the oil cooler adapter (yet another sin against the VW gods), I just need to touch up the slot edges. I will be installing new fittings in the future, but these came in a lot box I bought a while back and will let me do the test fire before taking the car up north.
I installed the plug wire retainers, plugs (NGK 6222) and new plug wires. I also installed the throttle tube with its seal after painting the tube. Props to AirCoolin up in Washington state for having so many random seals and pieces at really affordable prices. I've bought so many pieces from them, its probably half my eBay purchase history for the last year.
I got some Gates fuel line for the test firing, and hooked up the vacuum line for the advance as well. I ordered some 6AN to 3/8 barb fittings, so once those show up I can prime the oiling system and verify proper flow.
I do still need to adjust the valves, paint the dipstick handle and install it, and bolt up the engine to the transaxle to bench start it. I need to fill the transaxle with fluid still, so I am looking at 75w-90 or 80w-90 full synthetic gear oil.
I am hoping to fire the engine up early next week, then it will be unbolt the trans, mount it in the car, mount the engine, and the load the car onto its trailer and strap it down. I am excited but nervous to trailer it 1300 miles in 2 days, but after repacking the trailer bearings and making sure I have a spare tire for the trailer, I know we should be all good to make the trip up.
Thanks everyone for following along this far! I still have a ways to go but I hope to have the car driving by the spring. Whether that happens depends on how much work our new-to-us 1967 house needs!
Have a great night everyone! _________________ Phil “Deluxe”
Posted: Wed Aug 06, 2025 7:35 am Post subject: Re: First VW, a 1970 Bug. What did I get myself into? |
Very nice work Phil it is really progressing nicely. I noticed your dizzy on one of the last photos. I may be wrong but it looks to be one of the earlier 66 to 69 units for single port motors. For a dual port motor with 34 pict- 3 I think the dizzy that works the best with that is the svda. Others will weigh in on that. Good luck-Bob |
