Mechanical Trans Temp Gauge
BayStYat
BayStYat is offline
PostPosted: Sat Jun 07, 2025 9:19 am    Post subject: Mechanical Trans Temp Gauge Reply with quote
I am going to install a mechanical trans temp gauge. I want to install the sensor in the oil pan. Is the trans oil temperature an indication of how hot the transmission is?
Thank you
67rustavenger
67rustavenger is offline
PostPosted: Sat Jun 07, 2025 10:21 am    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
Thank you
Short answer, Yes.
There is an easier way to measure trans fluid temps.
Buy and install a "Scan Gauge." It plugs into the ODB port under the steering wheel and measures just about everything going on with your engine and transmission.
You can also scan CEL codes and clear them if needed.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
dsh1705 Premium Member
dsh1705 is offline
PostPosted: Sat Jun 07, 2025 10:27 am    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
Buy and install a "Scan Gauge”
This only works if you have a 97 or later EuroVan with OBD2.
I installed an in-line sensor in my transmission cooler on my 95.
David
1705.net
95 EVC
ACU,098
67rustavenger
PostPosted: Sat Jun 07, 2025 10:46 am    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
Fair enough. BayStYat didn't state what year van he has.
Looking at his gallery pic, because there's only one. He has an image of a Scan Gauge II readout.
Buy Once, Cry Once!
BayStYat
BayStYat is offline
PostPosted: Sat Jun 07, 2025 3:27 pm    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
Sorry it’s a 2002. I have a scan gauge but it so dam inaccurate.
67rustavenger
PostPosted: Sat Jun 07, 2025 3:55 pm    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
Really?
My scan gauge was reading funky last weekend on the way home from a campout.
It was showing the trans temp way lower than the engine temp.
I unplugged it waited 30 seconds and plugged it back in.
Then the readings were matching.
It's strange that your is inaccurate.
Buy Once, Cry Once!
BayStYat
BayStYat is offline
PostPosted: Sat Jun 07, 2025 4:21 pm    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
Well I was changing my trans oil Friday and the gauge would hold 85deg for about 4 minutes then jump to 105 then back to 85. I was checking the pan with a temp gun and it was at 110 and climbing ever so slightly but the scan gauge was just sitting back at 85.
It’s so dam annoying
kourt
kourt is offline
PostPosted: Sat Jun 07, 2025 10:23 pm    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
You need to check if your ScanGauge has the Eurovan firmware. Did you get it from BusDepot? If not, it likely does not have the correct firmware.
The temp jumping you describe is a symptom of incorrect firmware.
Any regular ScanGauge will not come properly configured to read Eurovan trans temps out of the box.
Contact ScanGauge customer service to remedy this. They will have you send in your gauge for an update at a reasonable fee.
kourt
BayStYat
BayStYat is offline
PostPosted: Sun Jun 08, 2025 4:41 am    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
kourt
Kourt
I did send it in and had it updated.
dsh1705 is offline
PostPosted: Sun Jun 08, 2025 8:44 am    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
There is this approach: https://www.vwvortex.com/threads/eurovan-adding-a-transmission-temperature-gauge.7492658/
David
1705.net
95 EVC
ACU,098
BayStYat
BayStYat is offline
PostPosted: Sun Jun 08, 2025 8:52 am    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
That’s where I got the idea.
Endopotential
Endopotential is offline
PostPosted: Sun Jun 15, 2025 3:38 pm    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
I added that manual transmission temp gauge. It's a nice feature, but I've found it to be quite inaccurate.
If you can get your Scan Gauge / Torque Pro / any OBD2 reader to work, I would go with that, as presumably that's what data the ECU is actually using to function.
With the manual gauge, it sometimes reads 15-20F below OBD2. And because the temp probe is bolted to the transmission housing, I think there is likely a "heat soak" phenomenon so that it doesn't ramp up and down quickly enough to be super accurate.
bigfoot_ev
bigfoot_ev is offline
PostPosted: Sun Jun 15, 2025 9:14 pm    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
This conversation is good timing for me since I just did a transmission oil change today and I needed to get the trans temp up to the proper temperature.
I started out using Torque and a bluetooth OBD II dongle. What could be more convenient than to walk around the garage or under the van and monitor trans temp? The strange thing is that the temp seemed to be stuck on 86 F. So, I started to get nervous and decided to switch to VCDS. That meant unplugging my OBD II dongle and plugging in the VCDS cable.
After getting the swap set up the trans temp went to (sorry SWITCHING to deg C) 33 C. Then it sat for a bit, but then jumped to 36 C and falling back to 33 C every now and then. Finally after quite a while it hit 40 C, my target, but again falling back to 36 C every now and then. So, I am seeing the same as BayStYat with VCDS.
What I thought was interesting is that VCDS, the so-called gold standard, only showed 33 C, 36 C, 40 C, and fluctuated between them. My take-away is that Torque works just as well and the resolution is not that precise coming from the TCU.
2003 Westfalia Weekender, AXK, 01P
Endopotential
PostPosted: Sun Jun 15, 2025 11:29 pm    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
That's an interesting observation Bigfoot. I wonder if others could comment as well.
With my Torque Pro, the readings seem to update every 10 seconds or so. Which hopefully is accurate enough for doing the fluid change and monitoring things on the road.
With the analog dash gauge, the needle doesn't move anywhere rapidly enough. I even tried an infrared thermometer but the heat soak phenomenon and time needed to heat up the metal of the transmission pan seemed to generate wildly inaccurate readings.
2002 Eurovan Weekender
bigfoot_ev
PostPosted: Mon Jun 16, 2025 8:51 am    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
I just realized we might be talking about 2 different scenarios. The first is waiting for a cold engine/trans to warm up and monitoring the temp from cold. The second is driving along for some time after the engine and trans have had time to come to operating temp and monitoring ongoing temps.
Specifically, in the first scenario I get very little temperature resolution. And while just idling it takes a long time to hit target temp.
However, in the second scenario as I'm traveling along glancing at the trans temp, especially going up hills it seems I get frequent and higher resolution temperature readings. This is just seat of the pants no real close monitoring. That would need a second person tracking data.
Endopotential
PostPosted: Mon Jun 16, 2025 10:21 am    Post subject: Re: Mechanical Trans Temp Gauge Reply with quote
Yes, excellent point. That's exactly my experience.
The warm up period from a cold start does take a while, especially during the transmission fluid change when your hands are all greasy and you just want to finish the job.
It was only when I got Torque Pro configured to find transmission temp (thanks to you Bigfoot or HeyCrutch I believe, thank you!) that I was able to do the fluid change with more confidence.
With the van warmed up and running on the highway, OBD2 readings are quite granular.
