SA Double-Bubble
Page: Previous  1, 2, 3, 4
ALLWAGONS
ALLWAGONS is offline
PostPosted: Tue Jan 07, 2025 10:07 pm    Post subject: Re: SA Double-Bubble Reply with quote
Has anyone purchased this seal?
Turk.380 Premium Member
Turk.380 is offline
PostPosted: Sun Feb 02, 2025 2:20 pm    Post subject: Re: SA Double-Bubble Reply with quote
I only just now saw this post and it's out of stock! Sad Sad
Brian W
St. Louis, MO
'64 SO-33 Hatch Top Westy | '74 RHD DoubleCab | '87 Syncro Westy: Subaru EZ30D powered | 2002 VW Winnebago Vista
'70 Karmann Ghia AutoStick coupe.
Turk.380 is offline
PostPosted: Sun Feb 02, 2025 2:40 pm    Post subject: Re: SA Double-Bubble Reply with quote
Finally after the holidays, my birthday, and about a month of sub-freezing temps with everything covered in about a 6" layer of ice here in St. Louis...
I finally took some time to work on the DCAB..
I think I posted previously about the alternator pulley blowing apart and cutting into the alternator case, so I had to install a new alternator...
Luckily one of my birthday presents was one of those induction bolt heaters because I had to cook THE FUCK out of the fan bolt, and the remaining hub of the pulley to remove them from the old alternator.
Also, despite claims to the contrary here on TheSamba, the fan bolt is NOT left-hand threaded!
so, new alternator and Volksbitz rebuilt 34-PICT3 were installed.
After that I turned back to the shifter bushings, and had a lot off issues with the long "rear" shift rod... it was SO DANG TIGHT! I had ran solvent-soaked shop towels through the tube repeatedly, like swabbing out a shotgun barrel.. and greased it all up.. but that front shuttlecock looking bush with the spring wire (from WW) was just so insanely tight! like, I had to pound the gorram rod in with a dead blow hammer..
The next week I decided that just can't be right.. So I pounded everything back out and ended up crushing down the "spring ring" of the front bushing... It seemed to help. It's still pretty stiff, but at least I can move it by hand, with some effort.
What has stopped me dead now is this gorram kludge by a previous owner:
yep, that's a thick plate someone has welded up in the front-most shifter bushing bracket. and there's not enough clearance to get the rubber bushing in there. So I gotta figure out how to get something in there to cut it out. uhhgg.
According to a buddy of mine, this style front bushing bushing was NLA for many years, so we think maybe they welded in this plate as a front support. Which is also too big and doesn't support the shift rod properly.
So, that's where I'm stuck for now..
60F and sunny here in STL today but I'm stuck at home to work a Zoom meeting for work Evil or Very Mad
hopefully I have some time to hack at it a night or 2 this week.
Brian W
St. Louis, MO
busdaddy
busdaddy is offline
PostPosted: Sun Feb 02, 2025 4:57 pm    Post subject: Re: SA Double-Bubble Reply with quote
Spectacular!
Since the booger welds seem to mostly run up each side I'd split the plate with a body saw and bend the halves outwards so the welds snapped (stop cutting before you hit the VW metal). That bushing was never NLA, someone was just being cheap. A sawzall likely has too long a stroke so it'll be impossible to stay on the plate without bashing the shit out of the bottom of the floor.
And Happy birthday!
Слава Україні!
Turk.380 is offline
PostPosted: Tue Feb 04, 2025 3:14 pm    Post subject: Re: SA Double-Bubble Reply with quote
busdaddy wrote:
Spectacular!
And Happy birthday!
thank you sir!
any more details on what this "body saw" might be? Google is only giving me exercise routines! lol
I picked up a few carbide blades for one of those vibratey cut off tool things hoping it's long enough to reach up in the box and get at that plate. I have a feeling the e-brake lever is going to muck up the job uhhg.
I was also thinking of maybe a small battery-op sawzall... perhaps they have a shorter stroke than the standard ones?
Hopefully I can get over there tonight and bash around a bit.
Brian W
St. Louis, MO
Turk.380 is offline
PostPosted: Tue Feb 11, 2025 7:43 pm    Post subject: Re: SA Double-Bubble Reply with quote
well it took maybe an hour or so, and about 6 or 7 different cutting tools but club-mate Mario Vitale (Chippuller) did most of the labor and we got that kludged in "bushing" removed, and I was able to install the proper rubber bushing.
After Mario left I forged ahead and got the shift rod all re-assembled, and the trans back in by myself and loosely bolted up finger tight. lost track of my square grub screw and need to get everything aligned.
another winter storm coming tomorrow, hopefully I can get over to the shop this weekend and get it finished up.
Brian W
St. Louis, MO
busdaddy
busdaddy is offline
PostPosted: Tue Feb 11, 2025 9:40 pm    Post subject: Re: SA Double-Bubble Reply with quote
Good job!
Sorry I missed this earlier, I should have said "air powered body saw", that would have improved the searching.
Слава Україні!
Turk.380 is offline
PostPosted: Wed May 21, 2025 9:11 pm    Post subject: Re: SA Double-Bubble Reply with quote
Guess I'm long overdue for an update
With barely 24 hours to spare I got the doublecab wrapped up and back together in time for the Easter Sunday car show here in STL.
new steering guibo.. new brake pedal return spring..
Got the 3rd door latch mechanism cleaned up in the ulrasonic and lubed.. no longer pops open on me!
new repro 3rd door seal installed, but required modifications..
then the top & bottom of the door really stick out..
I wound up finding the defrost "Y" and 1 of the branch tubes hidden way up under the dash! then ordered the other branch tube from eBay..
it took about 15 test fittings but the new glove box liner was trimmed and fitted, along with a new door..
Then fabbed up a steel panel for the radio hole, that holds some power outlets which I mainly use for a cheap little MPH GPS speedo I stick on the dash..
fitted a new VolksBitz rebuilt 34-PICT3 but was having some bad hesitation and stumbling.. I went to do another compression test and leakdown test.. found this..
that may explain a few things yeah?
BTW - my leakdown was less than 10% on all Cyls.
went on about a 100 mile club cruise ..
found that I still have shit highway power.. like, it bogs down worse than the worn out 1500sp in my splitty. barely can do 60mph in a flat. Down into 3rd gear on modest hills. uhhg..
still trying to figure that one out.
my compression is 110-140 but need to re-test that after a fresh valve adjustment.
so, that's just a quick and dirty update to now.
Cheers!
Brian W
St. Louis, MO
Wildthings
Wildthings is offline
PostPosted: Thu May 22, 2025 4:20 am    Post subject: Re: SA Double-Bubble Reply with quote
Put a scope in the cylinder with the smashed plug and see what's going on in there.
ALLWAGONS
PostPosted: Thu May 22, 2025 6:34 am    Post subject: Re: SA Double-Bubble Reply with quote
I was looking at the 3rd door seal you have. I was also looking at mine. I think one could make a better fitting seal out of a front door seal. I am not good at fabricating rubber stuff, but I will give it a shot. Just need to find a way to cut the rubber without it getting kinky or bumpy at the actual cuts, so the ends meet flush when glued back together.
NASkeet
NASkeet is offline
PostPosted: Sat May 24, 2025 11:39 am    Post subject: Re: SA Double-Bubble Reply with quote
I wonder who had been abusing your spark plugs to distort the Earth (i.e. Ground in USA parlance!?!) electrode in that way and close the spark-gap to virtually nothing!?!
I hope you or a suitably qualified & equipped person gave that vehicle a proper roadworthiness inspection & test (including brake balance & efficiency test on a rolling-road brake dynamometer) before you ventured out on your 100 mile test run!?! Question
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
jtauxe Premium Member
jtauxe is offline
PostPosted: Tue Jun 10, 2025 7:48 pm    Post subject: Re: SA Double-Bubble Reply with quote
Turk.380 wrote:
If you have some #'s handy for all the control cables, and maybe a brake pedal return spring - that may be RHD-specific too? I would appreciate it.. just to make sure I'm going after the correct bits.
OK, I'm ridiculously slow, but I have info! My tardiness reminds me of a T-shirt I saw recently. On the back it said
"If I said I'll do then I'll do it! You don't have to keep reminding me every six months." Wink
The following parts are for 1973-1979 buses with 1700-2000 cc engines:
accelerator cable:
LHD: 211 721 555 T
RHD: 214 721 555 AD (I've also seen variant C)
accelerator cable boot
LHD or RHD: 211 721 579 B
heater control cable, left
LHD: 211 711 629 N
RHD: 214 711 629 N
heater control cable, right
LHD: 211 711 630 N
RHD: 214 711 630 N
speedometer cable
LHD: 211 957 801 F
RHD: 214 957 801 H
hand brake cable, 2960 mm, L and R, LHD and RHD:
211 609 701 T
clutch parts are all the same for LHD and RHD:
clutch cable only: 211 798 335 J
clutch cable chassis boot: 311 721 363
Boden tube only: 211 721 361 D
Boden tube boot: 211 721 365 A
clutch cable bit, including all above and more: 211 798 335
I like to carry all these spares...
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Abscate Premium Member
Abscate is offline
PostPosted: Wed Jun 11, 2025 2:07 am    Post subject: Re: SA Double-Bubble Reply with quote
Xevin wrote:
airschooled wrote:
You'd be surprised how many places can stash a .38 Special, especially if you have a camper.
Agreed Wink
Mixing Alcohol Guns Again!
Very Happy
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jun 11, 2025 6:18 am    Post subject: Re: SA Double-Bubble Reply with quote
I second that. It is a sign something may be in or have gone thru that cylinder. Catch it now.
Depstech with side view https://www.amazon.com/dp/B0928Q3T42?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_2&th=1
USB no side view https://www.amazon.com/dp/B07PBF6DX5?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_9
NASkeet
NASkeet is offline
PostPosted: Fri Jun 13, 2025 3:54 am    Post subject: Re: SA Double-Bubble Reply with quote
accelerator cable:
LHD: 211 721 555 T
LHD: 211 711 629 N
RHD: 214 711 629 N
LHD: 211 711 630 N
RHD: 214 711 630 N
speedometer cable
LHD: 211 957 801 F
RHD: 214 957 801 H
211 609 701 T
Keep in mind that there are different accelerator cables for 1972~79 VW 17/18/2000 Type 2s, dependent upon whether one has twin Solex carburettors or Bosch L-Jetronic fuel-injection and whether manual or aautomatic transmission.
Regards.
Nigel A. Skeet
jtauxe is offline
PostPosted: Fri Jun 13, 2025 1:40 pm    Post subject: Re: SA Double-Bubble Reply with quote
NASkeet wrote:
Keep in mind that there are different accelerator cables for 1972~79 VW 17/18/2000 Type 2s, dependent upon whether one has twin Solex carburetors or Bosch L-Jetronic fuel-injection and whether manual or automatic transmission.
Good point, Nigel. Yes, there is a wide variety of accelerator connections.
John
http://vw.tauxe.net
Page 4 of 4
