making sense of my starter (with picture) 84 westy
Page: Previous  1, 2
greggarthurevans
greggarthurevans is offline
PostPosted: Tue Jun 10, 2025 4:24 pm    Post subject: Re: making sense of my starter (with picture) 84 westy Reply with quote
I was planning on going to an appliance place (listed by Supco) to buy a connector, but from what you are saying, it will be plated and rust. Also, it seems that any connector available is fake. Where else might I look for a reputable connector?
Holy crap I want to get this van on the road.
greggarthurevans
PostPosted: Wed Jun 11, 2025 11:37 am    Post subject: Re: making sense of my starter (with picture) 84 westy Reply with quote
The connectors came in the mail with believable Supco packaging and did have the imprints on the metal, but they were magnetic. It fit on the spade a little loose, so I flattened it some with a needle nose and had to work very hard to jam it on. The van is consistently starting, so I moved the other cars out of my driveway and took a victory lap around the neighborhood.
Still looking for a better connector.
1988M5
1988M5 is offline
PostPosted: Wed Jun 11, 2025 1:19 pm    Post subject: Re: making sense of my starter (with picture) 84 westy Reply with quote
You can drill a larger hole and use micro nuts, bolts and baby fender washers for serious contact.
BK
1991 tin top GL
Some BMWs.
DanHoug
DanHoug is offline
PostPosted: Wed Jun 11, 2025 2:29 pm    Post subject: Re: making sense of my starter (with picture) 84 westy Reply with quote
here's your better connector... from this very thread. plus I gave the part numbers for the correct Supco plated brass connectors also in this thread. you want something better?
DanHoug wrote:
I took a look around the web searching for a high quality quick connect for the starter solenoid terminal. ideal would be made of beryllium copper but I couldn't find any 10-12ga 0.25" quick connects. next best is phosphor bronze... while slightly less conductive than brass, it is stronger and retains its springiness much better. to that end, the below female 1/4" 10-12ga quick connect fits the bill. it is an "open barrel" crimp which requires its own crimper but creates a better bond with the wire.
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/62428-3/1153781
-dan
www.thefixitworkshop.com
greggarthurevans
PostPosted: Wed Jun 11, 2025 5:51 pm    Post subject: Re: making sense of my starter (with picture) 84 westy Reply with quote
I will buy one of those, thanks. I learned a lot this week. Thank all of you.
Rorke
Rorke is offline
PostPosted: Sat Jun 14, 2025 7:26 am    Post subject: Re: making sense of my starter (with picture) 84 westy Reply with quote
Thank you for all this great information guys.
I am two weeks without my daily driver because of this starter situation and my work schedule.
I don’t know that I can afford to wait for more parts to be delivered so I think I’m going to be replacing these spades in due time.
Page: Previous  1, 2
Page 2 of 2
