Two nights, three day trip: what worked, what didn't
RiversToTheSea
RiversToTheSea is offline
PostPosted: Mon Jun 09, 2025 8:52 pm    Post subject: Two nights, three day trip: what worked, what didn't Reply with quote
Took the van out for two nights and three days camping. I thought all the electrical upgrades were sorted out and done. I was wrong.
I charged the 100 Ah battery using the shore power charger before leaving home. On the trip out I ran an electric cooler that draws 5A.
So 100 Ah divide by 5A means my electric cooler should have run for 20 hours. Call it 16 hours if I leave a 20% reserve.
About two thirds of the way to the destination the Victron DC/DC Charger started cycling off and on. Starter battery voltage <9A, charger off, DC charger shut down. Then starter battery voltage >12, DC charger back on.
Fine, I stopped the DC/DC charger using the app. At the campsite I start the gas engine to test things. The 40A Winnebago fuse in the 10 AWG wire from the battery isolator to the power panel blew and the Winnebago wire to the battery compartment was warm to the touch.
So my questions: obviously my DC-DC charger is drawing more current than the Winnebago wiring can deliver. For the AC/DC charger I can select 15A or 7.5A but I can't find in the Victron app where I can set a limit for the DC charger current. I saw another thread where someone replaced the 10 AWG Winnebago wiring with 4AWG. Is that what I have to do? What is the current output of the VW alternator? ,Is my alternator failing?
kourt
kourt is offline
PostPosted: Tue Jun 10, 2025 4:38 am    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
Whether or not you can modify the DCDC charger's amperage draw and amperage delivery is a matter of what model of Victron charger you have. While several models have adjustable voltage, only a very few have adjustable amperage. The one I have, Victron Energy Orion XS Smart DC to DC Battery Charger 12/12 50A, does have adjustable amperage.
I set it to only draw 15A from the alternator and deliver no more than 15A to the lithium battery. I do this to ensure the DCDC does not overburden the alternator.
You may be asking, "how can it draw one amperage and deliver another?" and that is a reasonable question. The Victron DCDC I have is a buck/boost style charger, which will adjust amperage or voltage to obtain a certain outcome.
My memory from my install is that the primary stranded charging wire from the isolator on the firewall to the MagneTek charger at the rear of the EVC is adequate for this 15A charging, and that's what I'm using.
A word on voltage sensing. You mention starter battery voltage, less than 9A (but I think you meant volts), DCDC charger off, and then >12V, DCDC charger on.
This is far too broad to be effective, and would destroy your start battery. The DCDC should be configured more like start battery >13.1 volts charger on, <12.6 volts charger off. But you'll need to know your running voltages and dial them in based on your experience and readings.
kourt
xEVC
xEVC is offline
PostPosted: Tue Jun 10, 2025 6:51 am    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
Something doesn't seem right. Fortunately, you should have the tools to diagnose it.
Use VictronConnect app and open up your BMV 712 - click the Trends tab and you can see a historical graph of many parameters, including Current, Voltage, State of Charge, and possibly even the Starting battery voltage (if you wired that up).
From these data, you should be able to figure out what's happening.
* Eurovan alternators come in 90 amp versions (and higher) and even if your DCDC charger was drawing 40 amps, that leaves 50amps for the van. Even if you were using many electrical devices while driving (high beams, fan on high...) the alternator should have been able to keep up.
* For your starting battery to get under 9V, it really sounds like your alternator is not working properly (and/or your starting battery is dying. How old is the starting battery?)
* If the starting battery was at 9V, and your LFP house battery was at 13V, and you tried to start the van, the draw from the starter motor could easily pull more than 40A from the house battery and pop the fuse.
However, this would only happen using the stock wiring in which the House and Starting batteries are connected. With your rewired DC-DC charger, I think this is not possible. I wonder if your DC-DC charger is wired incorrectly (backwards?) or you still have the DC-DC charger in parallel with the original house wiring?[/i]
2000 Eurovan Camper (Winnebago)
Upgraded with 16" wheels
Stripped66
Stripped66 is offline
PostPosted: Tue Jun 10, 2025 9:24 am    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
IMO, you have a recipe for disaster.
Your DC/DC charger pulls 30A continuously, 40A periodically (up to 10sec), and requires a 60A fuse.
Max amperage for 10ga wire is conservatively 30-40A. Not continuous...max. You have no safety factor built in here. You're undersized per Victron's recommended wire size -at any length. 8ga for a 0.5m run; 6 to 4ga from the alternator, depending on the total length.
Do you know the amperage of your alternator, and what's the duty cycle at max continuous amperage (between your charger and all other electronics in the vehicle)? 50% duty cycle would be a good ball-park to work with.
If you're not willing to completely redesign your system, get rid of the 12/12-30A charger and step down to the 12/12-18A charger. If you're not willing to get rid of the 30A charger, then do some research and build your system with a reasonable safety factor (larger gauge wire, higher-rated alternator, etc).
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
xEVC
xEVC is offline
PostPosted: Tue Jun 10, 2025 10:40 am    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
One of the great things about Victron is you can demo all the models using the app.
Open VictronConnect app, choose Demo Library, and then select your product. The app will give you a simulated unit to play with.
From this, I can see that Kourt's charger (Orion XS 12/50) does have both input and output amperage limits, but it looks like smaller versions (Orion Smart 12/30) does not have that feature.
It does have variable voltage output settings, so you might be able to do a reasonably good amperage control by simply limiting the charging voltage. A LFP battery charging at 14.6V will gobble up a ton of amps, but charging at 13.8V or even a bit lower will lower the amperage draw substantially.
If you've determined that everything is wired up correctly (which I'm still skeptical of) and don't want to upgrade to the Orion XS, this might be worth a try.
dsh1705 Premium Member
dsh1705 is offline
PostPosted: Tue Jun 10, 2025 1:52 pm    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
Just an observation: the wire from the solenoid on the firewall of the EVC to the house battery is 8 gauge, with (for some reason) the wire from the battery to the 40 amp fuse before the solenoid being a 10 gauge. The Winnebago wiring diagram shows this.
David
1705.net
95 EVC
ACU,098
xEVC
xEVC is offline
PostPosted: Tue Jun 10, 2025 2:44 pm    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
I've wondered about this myself.
Turns out there are different wire ratings for
* "chassis" wiring (a single wire suspended in air) - which is what that short piece of 10 ga wire qualifies as.
* "power" or "bundle" wiring (2 or more wires often run in a bundle or tight space) - the rest of the circuit made of 8 gauge.
The ampacity ratings for those situations are dramatically different.
See here for an example: https://electronics.stackexchange.com/questions/33...ansmission
... in that discussion a 10 gauge wire is good for 55 amps in "chassis" but only 15 amps in "bundle" configuration.
RiversToTheSea
PostPosted: Wed Jun 11, 2025 5:37 pm    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
[quote="kourt"]
kourt
Yeah it was late and I was tired when I posted. I meant that the Victron monitor was showing the starter battery dropping to 9 volts with the engine running and the DC/DC charger on.
My wife was driving and I was adjusting the settings in the DC/DC charger to try to diagnose the problem. At idle and when cold I get 14A out of the alternator, and I had the Engine Start Sense feature turned on, with the lower limit at 13.2V or so. But after a couple of hours driving when the DC/DC charger was dropping out I set the starter sense voltage lower to see if that helped. I knew when I set it to 12V and the DC/DC charger was still dropping out something was amiss. I set it to 9V just to see how low the supply voltage was going, I didn't expect that this was normal at all. At that point I turned the DC/DC charger off.
RiversToTheSea
PostPosted: Wed Jun 11, 2025 5:45 pm    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
I kept the stock battery isolator in, even though the Victron DC/DC charger has a smart sense feature to determine if the engine is running and the alternator is supplying power. So no fears that the house battery can backfeed to the starter battery.
I'm positive (hah!) that the DC/DC charger is wired correctly, the starter battery lead is connected to +(IN), and the house battery is connected to +(OUT), and for short trips it works fine. I am leaning towards the idea that the alternator failing and was unable to keep up with the draw of the DC charger. Except that the house battery was fully charged, and the only draw while driving was my electric cooler at 5A. As Kourt noted above the stock alternator output is 90A so the 5A draw of the cooler should not have required the DC charger to draw more than 5A from the starter battery.
RiversToTheSea
PostPosted: Wed Jun 11, 2025 5:53 pm    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
Maybe I'm misunderstanding something here. My house battery was fully charged when I started, and the only house side draw was my electric cooler pulling 5A while driving. Is the Victron really pulling 30A? Would it not just pull 5A to match what the cooler is drawing? Or when it senses the house battery needs to be charged it goes up to the max right away?
Or in other words, I assumed the Victron modulated how much current it draws based on the SOC, but you're saying it's either on and pulling the full 30A or off, and nothing in between.
dsh1705 is offline
PostPosted: Wed Jun 11, 2025 5:57 pm    Post subject: Re: Two nights, three day trip: what worked, what didn't Reply with quote
The device on the firewall is NOT a battery isolator. It is a solenoid, triggered "on" by the ignition. When on, it combines the starter battery and the house battery, so that the alternator can charge the house battery.
(well, I guess it IS an isolator - it isolates the batteries when the ignition is off)
Very Happy Very Happy Very Happy
David
1705.net
95 EVC
ACU,098
xEVC
xEVC is offline
PostPosted: Thu Jun 12, 2025 6:14 am    Post subject: Re: Two nights, three day trip: what worked, what didn't Reply with quote
I can think of two reasons you could have read 9v on the starting battery with the engine running:
1. Alternator is failing.
2. High resistance connections between the alternator and the Victron DC DC charger.
Can you do a quick sketch and or upload pictures showing the wiring?
xEVC
xEVC is offline
PostPosted: Thu Jun 12, 2025 3:38 pm    Post subject: Re: Two nights, three day trip: what worked, what didn't Reply with quote
This! This is the way Wink
Funny story, but my partner got sick of the "let's diagnose as we drive" trips in our prior Westy Vanagon camper. So we sold that to a friend (long story) and bought a "new" Eurovan Camper.
That was 15 years ago, and it seems like we are getting to this point in the Eurovan.
RiversToTheSea
PostPosted: Thu Jun 12, 2025 4:52 pm    Post subject: Re: Two nights, three day trip: what worked, what didn't Reply with quote
Attached. Errata, my house battery is 100Ah not the 200 shown.
bigfoot_ev
bigfoot_ev is offline
PostPosted: Thu Jun 12, 2025 5:47 pm    Post subject: Re: Two nights, three day trip: what worked, what didn't Reply with quote
I think you have the Orion Tr Smart DC/DC charger. IIRC, as soon as that charger detects the engine is running it will go into bulk charge mode, since that is the first step in charge algorithm: bulk – absorption – float. If your battery was fully charged the algorithm will still go through the steps.
I could see with LFP batteries that it would take a bulk charge current long enough to cause issues if the rest of the circuit has problems.
I think xEVC is probably correct with either of the 2 issues. To test, draw down your battery just a bit. Enough so that it requires a bulk current longer than just briefly. Start your engine and check the Victron app. It will show what stage the charger is in and the BMV will show the current. If you get the same results, by that I mean, your alternator sagging to 9V, or some upstream resistance so high the Orion sees 9V, that would indicate something is wrong upstream of the Orion.
BTW, your wiring diagram looks good to me. Nothing jumps out.
2003 Westfalia Weekender, AXK, 01P
Stripped66
PostPosted: Thu Jun 12, 2025 6:07 pm    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
You may be.
https://www.victronenergy.com/upload/documents/Ori...pdf-en.pdf
Read Section 5.1 (including the figure) and details about the "charger state" and settings, 9.2.2 and 9.3.2.
Once your charger hits bulk charging mode, it's constant current @30A.
A Victron employee confirms this here: https://communityarchive.victronenergy.com/questio...r-sma.html
You have this all mounted in the back of your van, so you probably have 15+ feet of wiring from the isolator to the charger...pulling 30-40A through 10ga wire. Please reference section 4.2 for recommended wire size.
Abscate Premium Member
Abscate is offline
PostPosted: Fri Jun 13, 2025 3:01 am    Post subject: Re: Two nights, three day trip: what worked, what didn't Reply with quote
20% reserve is not a thing with a lead acid battery
A 5 Amp load constant will have a reserve load of 8 hours on a new battery and half that on an aged battery (over 3 years or more than 20 discharge cycles)
xEVC
xEVC is offline
PostPosted: Fri Jun 13, 2025 7:40 am    Post subject: Re: Two nights, three day trip: what worked, what didnt Reply with quote
If I understand you correctly, your wiring now looks like this:
Starting battery --> fuse (?) -> battery relay --> 8 gauge wire to back of van --> fuse (?) -> Victron DCDC charger.
If so, so potential concerns:
* is the Victron OK with having its power supply switched completely off like this?
* the battery relay is probably heavily corroded, which could provide a high resistance connection leading to substantial voltage drop.
Here's a picture of what mine looked like on the inside:
And I ended up replacing it altogether: https://xochi.com/evc/house-battery-relay/
I think, with the DC DC charger in circuit, there's no need for the relay any longer, because it can sense the starter circuit voltage and stay OFF when the engine is not running.
xEVC
xEVC is offline
PostPosted: Fri Jun 13, 2025 7:56 am    Post subject: Re: Two nights, three day trip: what worked, what didn't Reply with quote
That wire from the firewall to the house battery is supposed to be 8 gauge, but that should be confirmed in these old model campers.
A voltage drop calculator using these values:
8 gauge
20 feet distance
13.8vdc
40 amps
https://www.calculator.net/voltage-drop-calculator...;ctype=nec
you get a 9% voltage drop of 1.25V, meaning if the alternator is at 13.8V the voltage at the battery charger would be 12.5.
I think that's pushing the limits with 8 gauge wire, but probably still within safety margins.
To be measuring 9VDC anywhere suggests something is quite amiss.
Like @David says, discharge the house battery a bit, start the van engine and repeat this test -- take measurements at the starting battery, on both sides of the relay and any fuses, and also at the back of the van.
Stripped66
PostPosted: Fri Jun 13, 2025 9:06 am    Post subject: Re: Two nights, three day trip: what worked, what didn't Reply with quote
I agree it's pushing the limits of 8ga wire. Regarding safety margins, I would default to the recommendations in the Victron manual, which is in-line with most wire-size calculators online (the manual addresses several issues/questions R2C has posted here).
However, I do agree that the voltage drop alone is not the root of the problem.
Regarding the 9VDC measurement, there's some details not posted here, including the actual voltage and the duration only 9VDC was being detected. I'm inventing a scenario here, so feel free to challenge its plausibility: if the alternator's voltage regulator cut the voltage output (perhaps at high combined load during idle, or maybe the voltage regulator is going south) leaving the starter battery alone to supply this load, the resulting voltage drop at the starter battery, plus the voltage drop across 20' of wiring, could put the detected voltage at the charge controller below 10VDC.
Definitely the right place to start!
