my_vw_sucks Samba Member
Posted: Thu Jun 12, 2025 9:24 am Post subject: Headlight frame screw to body size? |
I pulled my headlights to get them all cleaned up. In pulling the headlights I left the frame to body screws on the bumper. Moved on to other projects while the headlights were drying and, well, drove away with them still on the bumper while running to the auto parts store.
Anyone have any idea what size they are? I can only find info on the adjusters in search. |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Thu Jun 12, 2025 1:55 pm Post subject: Re: Headlight frame screw to body size? |
half inch eights. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5720 Location: Bemidji, MN
Posted: Thu Jun 12, 2025 2:14 pm Post subject: Re: Headlight frame screw to body size? |
if your van is worn like mine, you'll need one size larger than was in there! _________________ -dan
www.thefixitworkshop.com |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10379 Location: Orbiting San Diego
Posted: Thu Jun 12, 2025 3:33 pm Post subject: Re: Headlight frame screw to body size? |
Originally the top 2 screws on each side were a larger size than the lower 2 screws on each side.
The difference isn't so obvious and people often mix them up and cause damage to the holes.
While VW Parts gives metric sizes for them those sizes cross well to these American sizes.
Upper 2 screws on each side, #8 x 1/2" long
Lower 2 screws on each side, #6 x 1/2" long
If someone has forced the upper screws into the lower holes, the lower holes may now fit #8 better than #6
( the OP has a 90 I believe)
Mark |
Posted: Thu Jun 12, 2025 8:34 pm Post subject: Re: Headlight frame screw to body size? |
Thanks! Mine all seemed the same size so 8’s it is. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10640 Location: Western WA
Posted: Fri Jun 13, 2025 8:40 am Post subject: Re: Headlight frame screw to body size? |
It pleases me that my holes are "original".
It reassures me that I respect my van
even though I did cut the springs at the license plate door.....
But gotta wonder what was going on in that German office...
when the final design decision was
"ja, hier werden zwei unterschiedliche Schraubengrößen benötigt, weil irgendein Arschloch den unteren Befestigungsbereich 1 Millimeter zu schmal gemacht hat"
#6 is too small..... and all same screws is better design.
What did it "cost" the VW factory for:
1) the intitial dispute regarding assembly effifcency
2) two bins of screw sizes (vs one bin) at every headlight assembly station
3) extra lines of text in the assembly procedure
4) extra lines of inspection procedures
5) rework? in case an installer put in the wrong screw.
It's just silly, (but greatt forum-fodder. )
At our stage, eight 8s is an upgrade.
It's one of the less expensive upgrades.
Headlight resellers could find:
proper german-looking screwheads
offer one kit of
"4x #6
and
8x #8"
to cover all needs
(+ 'obsessions')
of an 'enthusisast' assembly line. _________________
....KTMs, GasGas, SPOT mtb
Posted: Fri Jun 13, 2025 8:52 am Post subject: Re: Headlight frame screw to body size? |
Agreed, why 2 screw sizes so close that many people don't even realize that they are different?
VW gives part numbers as these:
top screws - N01396626 4.2 x 13 mm qty 4 (US #8x1/2")
lower screws - N0139681 3.5 x 9.5 mm qty 4 (US #6x3/8")
Edit: helped an engineer friend with a headlight upgrade recently.
He mixed them up putting things back together and didn't quite notice there were 2 sizes even when I mentioned it.
Mark |
kamzcab86 Samba Moderator
Posted: Fri Jun 13, 2025 10:14 am Post subject: Re: Headlight frame screw to body size? |
Sodo wrote: |
Oktoberfest?
crazyvwvanman wrote: |
He mixed them up putting things back together and didn't quite notice there were 2 sizes even when I mentioned it. |
Whenever I have to remove the headlight assemblies, I place the screws in a safe, nearby place, laid out in the pattern of removal. No guesswork as to where they go back to. _________________ ~Kamz
2016 Golf GTI S
