xEVC Samba Member
Joined: March 23, 2017 Posts: 181 Location: California
Posted: Sat May 10, 2025 8:41 am Post subject: Gradual loss of power in 2000 EVC |
I have a 2000 EVC that I've owned for 15+ years. It is my impression that over the last decade or so, there's been a subtle loss of power.
I notice it on a few big hill climbs in the Sierras where I used to do at 60mph without strain, and now 50mph feels more natural.
The van otherwise runs great, passes smog, MPG seems pretty consistent, and has no CEL or codes.
It's possible it's all in my mind
Recently Completed Maintenance
* timing chains
* plugs, wires, and coil pack
* air filter
* transmission filter & fluid
Possible culprits:
* partially clogged catalytic converter
* fuel injectors
* gasoline? I run 91 octane gas, but maybe there is more ethanol now than in the past?
Any ideas? _________________ 2000 Eurovan Camper (Winnebago)
Upgraded with 16" wheels |
SambaBurnsRed Samba Member
Joined: February 07, 2025 Posts: 93 Location: object:1698
Posted: Sat May 10, 2025 11:31 am Post subject: Re: Gradual loss of power in 2000 EVC |
An engine is an air pump. Moving air = power. There is usually enough fuel available, if not it would start to buck or miss.
Catalytic tech has improved a lot in the past 25 years. So going to new catalytic and if rusty, exhaust system should give you a boost in flow.
I put new catalytics in this Range Rover, and it turned into a beast. Was going to sell but decided to keep it, and turn it into an overland machine. So much fun to drive with that power on tap.
https://www.instagram.com/reel/DFOhZ99ScXf/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA== |
paddygarcia Samba Member
Posted: Sat May 10, 2025 1:17 pm Post subject: Re: Gradual loss of power in 2000 EVC |
Converter is a good thing to check. Injectors are another.
I sent the injectors out for cleaning on what I thought was a good-running 2003 with 145k miles, it turns out that one was fully blocked, one fully open, and the rest clogged to varying degrees. Similar results on a good-running Porsche 911 that I refreshed.
They're underneath the intake manifold so unfortunately it's a production to get them out. |
EuroTec Samba Member
Joined: August 24, 2020 Posts: 512 Location: Asheville, North Carolina
Posted: Sun May 11, 2025 7:18 am Post subject: Re: Gradual loss of power in 2000 EVC |
+1 on the cat suggestion. _________________ If it ain't broke, don't fix it! |
xEVC Samba Member
Posted: Sun May 11, 2025 7:41 am Post subject: Re: Gradual loss of power in 2000 EVC |
Great ideas all, thank you.
* injectors can be had for $650 for 6 at europarts-sd.com . I've watched videos on replacing them, and it looks difficult, but something I could manage myself.
* a CARB-compliant catalytic converter is $750 to $1300 at magnaflow.com (? not even sure there are any available for my 2000).
Seems like an expensive way to do "reconnaissance by parts"
I have VCDS - are there any measuring blocks I could watch that would diagnose this?
Also, what about the Mass Air Flow (MAF) sensor : I don't know if mine has ever been replaced. _________________ 2000 Eurovan Camper (Winnebago)
Posted: Mon May 12, 2025 2:16 am Post subject: Re: Gradual loss of power in 2000 EVC |
MAF isn't hard to clean, worth a try I guess?
If you go the injector route, RC Injection will clean and rebuild 6 injectors for well under $200. IMO a good rebuild of original parts is better than new parts these days. |
TheOneTrueQuux Samba Member
Posted: Mon May 12, 2025 7:30 am Post subject: Re: Gradual loss of power in 2000 EVC |
| xEVC wrote: |
Also, what about the Mass Air Flow (MAF) sensor : I don't know if mine has ever been replaced. |
You can measure the exhaust back pressure, and that will give you an idea if the cat is clogged. |
Posted: Mon May 12, 2025 10:39 am Post subject: Re: Gradual loss of power in 2000 EVC |
Regarding injectors, most old, high mileage engines will have passed a lot of fuel, so they will be dirty for sure.
My boat engine injectors were a mess, it was hard starting & smelly (leaks, low fuel pressure, partial spray pattern) but I did have decent top-end power. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2955 Location: North Carolina
Posted: Mon May 12, 2025 12:54 pm Post subject: Re: Gradual loss of power in 2000 EVC |
I know it's might be snake oil/placebo effect, but I feel like annual use of Techron (kind of the most reputable FI cleaner product)has helped my van run more smoothly _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24467 Location: NYC/Upstate/ROW
Posted: Mon May 12, 2025 3:17 pm Post subject: Re: Gradual loss of power in 2000 EVC |
Check the cats with a back pressure measurement.
Clogged fuel injectors would P0174 code on at least one bank.
Itβs not the gas.
Tire pressures up to snuff? _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
xEVC Samba Member
Posted: Thu May 22, 2025 5:00 pm Post subject: Re: Gradual loss of power in 2000 EVC |
Is the catalytic converter back pressure easy to test? I've never heard of doing that.
More info:
* Injectors: could purchase a new set for $650 or get the originals cleaned for $200. I have read a few reports of the OEM injectors plastic electrical connections becoming brittle over time, so this might lean me towards new vs. refurbished.
* I found a much cheaper ($500) California (CARB) Catalytic converter from busDepot here: https://www.busdepot.com/023131089dx
I did some test drives this week running VCDS, and everything looked pretty good:
* Group 025 Oxy Sensor before Cat showed -3.1% (regulation), 4.7% (adaptation partial load) and -2.3% (adaptation idle) - I believe these are all great numbers, being within 5% of zero.
* I did some hard accelerations watching group 045 (Knock Control Cyl 1-4) and Group 046 (Knock Control Cyl 5-6) and all stayed at 0.0 degrees. No audible knocking heard either.
My thinking now - the van is really running pretty good, and I may just run a bottle of Techron through it and drive it this summer, and save the parts cannon for later... _________________ 2000 Eurovan Camper (Winnebago)
xEVC Samba Member
Posted: Thu May 22, 2025 5:17 pm Post subject: Re: Gradual loss of power in 2000 EVC |
Forgot to mention this:
On my 2000, with VCDS, Group 009 and 010 show this:
| Code: |
May 2025
RPM Time Misfires Misfires
680 /min 1.50 ms 0.0 / s 14.3 / s
RPM Engine Load Timing from Map Timing Actual
680 /min 1.55 ms 9.0 BTDC 8.3 BTDC
I wonder what the two Misfires values are - perhaps "instant" and "worst"?
The only thing that worries me is the 14.3 misfires per second - at 680 RPM, that's 680/60 =11.333 revolutions per second.
To have 14.3 misfires per second would suggest at worst that one cylinder was never firing, or if misfires were spread equally among 6 cylinders, at 680 RPM there should be 680/60*6 = 68 cylinders firing per second, so 14.3/68 would be a 21% misfire rate.
I have no CELs and the idle feels pretty smooth, so I'm wondering if this 14.3 value is bogus?
I checked these values against ones taken a year ago (June 2024) and found this.
| Code: |
June 2024
840 /min 2.10 ms 2.0 / s 17.4 / s
840 /min 2.05 ms 9.0 BTDC 8.3 BTDC
Note: Between June of 2024 and May of 2025, I replaced all 6 spark plugs and both Oxygen sensors. _________________ 2000 Eurovan Camper (Winnebago)
xEVC Samba Member
Posted: Wed May 28, 2025 4:18 pm Post subject: Re: Gradual loss of power in 2000 EVC |
I decided to replace all 6 injectors. Not exactly on a whim, but based on my gut feeling that since everything else seemed to be working well (timing chains, spark, O2 sensors...) that fuel delivery was suspect.
I'm working on a detailed writeup, but the most amazing find was:
Injector Turd
this chunk of something popped out when I flushed the fuel passages after separating the intake manifold and removing the injectors. _________________ 2000 Eurovan Camper (Winnebago)
xEVC Samba Member
Posted: Fri Jun 13, 2025 6:49 pm Post subject: Re: Gradual loss of power in 2000 EVC |
Recap: after feeling like my 2000 EVC had lost some of its "oomph" over the years, I decided to change out the injectors.
While changing the injectors, I found weird gunk (turds) in the fuel galley.
Afterwards, my driving partner said "This feels like it's driving better" a feeling I agreed with.
Today the data came back: I had sent the old injectors out to RC Injectors for testing and cleaning.
Results:
| Code: |
Before Cleaning After Cleaning
Injector # CC/min Pattern CC/min Pattern
1 157 Dripping 200 Excellent
2 188 Fair 201 Excellent
3 193 Fair 202 Excellent
4 120 Dripping 199 Excellent
5 145 Dripping 200 Excellent
6 171 Fair 201 Excellent
The old injectors were running from 120 to 193 cc/minute, which is nearly 40% deviation in flow, not to mention the poor flow patterns.
Happy to have done this - and if you have 100k+ mile injectors and are having rough running, might be something you should consider doing yourself.
P.s. I paid $35/injector for this from https://www.rcfuelinjection.com/ - not the cheapest option but it was local (California) and fast.
If anyone is interested in buying these refurbished set of 6 Eurovan injectors (1997-2000) please send me a message. _________________ 2000 Eurovan Camper (Winnebago)
Posted: Fri Jun 13, 2025 10:39 pm Post subject: Re: Gradual loss of power in 2000 EVC |
The injector leaking or dripping is a problem that causes rich condition, at idle.
Being below 200 cc/min max just means you won't reach full throttle peak HP.
The injectors are sized for the max air flow into the engine & some margin for tuning
The O2 sensor takes care of deviance in flow rate, until it can't, then would CEL a lean condition code..
A clean fuel system will feel new and snappy. My boat didn't run so great until I did the injectors, but it runs open loop - no O2 to trim the syatem. |
xEVC Samba Member
Posted: Sat Aug 23, 2025 8:28 am Post subject: Re: Gradual loss of power in 2000 EVC |
Having done the injectors and being very happy with the results after several thousand miles, is there any reason to think about doing the Catalytic Converter too?
The only symptom I have that could be cat-related is a somewhat gassy smell right after startup that lasts for a minute or two.
I'm not sure if this is abnormal, or just how the Eurovan runs, combined with the fact that other modern cars are super clean by comparison, it makes the Eurovan feel gassy.
In other words, do the VW catalytic converters "wear out"? _________________ 2000 Eurovan Camper (Winnebago)
Posted: Sun Aug 24, 2025 4:12 am Post subject: Re: Gradual loss of power in 2000 EVC |
This might just be high idle caused by sas system. Does the smell go when the car comes back down to 750 rpm, and the jet engine whine stops?
That Magna flow converter will fit but wonβt pass smog in CA, and they may not ship it to a CA address _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Posted: Sun Aug 24, 2025 10:17 am Post subject: Re: Gradual loss of power in 2000 EVC |
I got the new catalytic in along with both O2 sensors. Custom exhaust OMG, the low bass note sounds like a small block V8.
Runs like butter, super smooth. It's the quietest, silkiest idling engine we have on the driveway here.
I do not have new injectors tho, so 45 seconds after start-up. when it crosses over to O2 closed loop, it's not perfect until I hit the throttle and get more air (and heat) into the engine. This is likely due to a slightly rich condition (leaky injector or two).
It's supposed to run a bit rich to heat the cat up. The new cat handles that well, and is similar to everything else we have (except very new) in terms of pollutants. A new cat will flow better and be more efficient. |
