Vanagon is now Vanagone
Alleycat1990
Alleycat1990 is offline
PostPosted: Sun Jun 15, 2025 2:12 pm    Post subject: Vanagon is now Vanagone Reply with quote
I was driving down a main road in Ottawa today and my 2.1 imploded. I called Hagerty but I am pretty sure they won't cover it. I am researching now I think I blew one cylinder. She is currently sitting at Ajs garage waiting for him to do an assesment hopefully Nonday am.
That is why I said they probably won't cover it..
1990 Vanagon GL purchased fall of 2024
never winter driven and well maintained
minor repairs needed example odometer
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Jun 15, 2025 2:17 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
why TF would Hagarty cover your engine? Unless a manhole cover that jumped up, grabbed your sump and pulled your crank out I've never known ANY insurance company to cover mechanical issues....ever.
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Alleycat1990
PostPosted: Sun Jun 15, 2025 2:19 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
Never had it happen before. That happened before with my 2018 Kia Soul and the dealership replaced the engine.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Sun Jun 15, 2025 2:22 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
Imploded, hmm... Like a big noise from the rear end? Did the rear end lock up? Did it make a noise and immediately engine stopped? I assume you had it towed? Was it leaking fluids? Chunks strewn along behind as you came to a stop?
latelogan
latelogan is offline
PostPosted: Sun Jun 15, 2025 2:32 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
sorry! let us know whats the assessment. Go grab a drink/snack and try to enjoy the rest of the day
1991 Westy stock 2.1 auto transmission
1978 Westy (Sold)
1971 Westy (Sold)
Alleycat1990
PostPosted: Sun Jun 15, 2025 2:57 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
Luckily I had enough speed to pull over loud noise then nothing a few chunks of metal in the engine bay. I didn't notice anything on the road. Towed to a vw mechanic I usually go to.
PostPosted: Sun Jun 15, 2025 3:14 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
Well.... Hmmm, I'd be guessing here, but you mentioned metal chunks in the engine compartment. That's likely a thrown rod.
If you've done upgrades to your engine, like stainless exhaust, updated throttle body, performance rocker arms, etc. you'll want to pull those off to save. Start asking around at any nearby or local shops that do transplants, you might find a reasonably decent pull that was done only because the owner wanted more "power" or something else like "reliability"
Hope things get back to where you left off, after you get this sorted!
-bobby
ThinkingD
ThinkingD is offline
PostPosted: Sun Jun 15, 2025 3:30 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
Time for a conversion. Contact https://mecaniquemartin.com/ and get a 2015 VW 2.0 SOHC turn key for a very reasonable price.
87 Titian Red Westfalia 2.0 VW I4 SOHC manual Ottawa, Ontario
Alleycat1990
PostPosted: Sun Jun 15, 2025 4:05 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
We are both in Ottawa. I contacted Eurotech they actually rebuilt my engine in 2020.
zerotofifty
zerotofifty is offline
PostPosted: Sun Jun 15, 2025 6:03 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
only fives years, how may miles on the rebuild?
Did it run low of oil?
that sucks, but it is recoverable with a new engine. bummer, but not the end.
unless you did something wrong like not do oil changes as required, or let oil get low, or over reved the motor, or have 250k miles on it since rebuild, I say stay away from eurotech. properly maintained, not abused, and assuming no excessive miles, the rebuild was bad. eurotech either did the rebuild poorly or your abuse is at fault, unless you have extremely high miles on it for only five years.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Alleycat1990
PostPosted: Sun Jun 15, 2025 6:11 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
Oil change was done last week and installed a good oil pressure gauge. 215 k on motor but i should look to see if the mileage is listed on the rebuild.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jun 15, 2025 6:12 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
So bring it to a VW dealer and see if they'll replace the engine
Rolling Eyes
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Captain Pike
Captain Pike is offline
PostPosted: Sun Jun 15, 2025 6:31 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
Rebuilt 2.1. If your rod bolts were not replaced it was only a matter of time.
LEARN TO SELF RESCUE
....Bad Sneakers....
Mr. 010
Glenn is offline
PostPosted: Sun Jun 15, 2025 6:39 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
"rebuilt" means different thing to different people, some just replace the bearings, rings and lap the valves.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Wildthings
Wildthings is offline
PostPosted: Sun Jun 15, 2025 6:57 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
IIRC, 10c says that 2.1L Rod bolts should be installed using 1.9L torque specs and procedures.
Wildthings
PostPosted: Sun Jun 15, 2025 6:59 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
What motor oil were you using?
ThinkingD
PostPosted: Mon Jun 16, 2025 9:25 am    Post subject: Re: Vanagon is now Vanagone Reply with quote
Would like to know when (year) Eurotech re-built you motor. Was it Eurotech or a Frank Condelli build. Was it a full re-build or new heads...?
Eurotech will install a FAS kit but I found that too expensive for my budget and went with a Mechanic Martin conversion.
In 2022 it cost me $7500.00 can for a 2015 VW 2.0 with 132,000 km on it, new timing belt, coil pack, water pump, accessory belt, drive by wire, ODB2 port up front. Turn key.
I gave him my old 2.1, it was running fine but oil pressure was starting to drop. You could reach out and see if he has any 2.1s. Phone is best.
Is yours the white tin top I see in Westboro from time to time?.
Howesight
Howesight is offline
PostPosted: Mon Jun 16, 2025 5:18 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
That picture clearly shows a failed connecting rod. In the 2.1 WBX engine (1986 to 1991 models), the connecting rods feature "torque-to-yield" bolts. Sadly, there are two big problems with these connecting rod bolts:
1. They are NOT re-usable; and
2. They ALWAYS fail eventually, although the time of failure may be at 150,000, 200,000 or 250,000 miles. Typically, as the connecting rods approach the point at which they are likely to fail, the oil pressure drops. This can allow a careful owner to rebuild before the engine "blows up good", as John Candy used to say:
https://www.youtube.com/watch?v=-wf4exIiQr8
By contrast, the 1.9 engines used "standard" connecting rod bolts and those connecting rod bolts almost never failed.
So, my guess is that either the rebuilder re-used the connecting rods bolts that were in the engine before rebuild or your engine suffered a low-or-no oil pressure event that caused the connecting rod failure.
You will need a replacement engine. If you have never found the WBX to be underpowered for your needs, then a good core engine from a person intending to do an engine conversion can be found, often at a decent price.
You can rebuild a core with replacement connecting rods that are sold, with new bolts and correctly machined:
https://vwparts.aircooled.net/Waterboxer-Connectin...ods-rb.htm
You can also buy a kit from GoWesty:
It remains possible that the cylinder heads associated with the failed connecting rod in your "blowed up real good" engine, with relatively low miles, might be re-usable in such an engine build.
Hope this helps!
'86 Syncro Westy SVX
wesitarz
wesitarz is offline
PostPosted: Mon Jun 16, 2025 5:24 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
$7500 CAN all in? That is reasonable. 115hp?
Wildthings
PostPosted: Mon Jun 16, 2025 6:39 pm    Post subject: Re: Vanagon is now Vanagone Reply with quote
This is why I asked about what oil he was using, as when the rods are first showing signs of failure, the oil pressure at idle drops and people tend to go to 20w50 to make the light stay off. This is just masking the only warning one is apt to get that their engine is about to grenade. Way back in the day, it was also common to find that a seller had disabled the oil pressure switch(s) to keep the light(s) off.
