Fuel tank not filling….
Icebox500
Icebox500 is offline
PostPosted: Mon Jun 16, 2025 2:51 pm    Post subject: Fuel tank not filling…. Reply with quote
OK, I’ve done some reading and I’m still stumped.
I have a 2 year old tank, all new lines and a nearly brand new filler neck (replaced the old one with a missing check ball). I have a gas gauge that under reports the first half of the tank and does not rise to the top.
Clarifications (edit) The check ball is the only thing that has changed prior to this new behavior.
Also, I did do a test where I opened the cap and tried to start the van but it was truly out of gas. Added 2 gallons from my spare and it started right up.
The problem:
I’m on a road trip and am seemingly unable to put more than 8 gallons into the tank! I confirm that I’m getting 15-16 MPG (loaded Westy). How do I “know” the tank is empty? I ran out of gas twice by trusting that it was “full” and the gauge was off (I carry 2 spare gallons).
The last time I ran out, I hadn’t even hit the “red zone” yet (about an 1/8th above red). Prior to the troubles, I could trust the gauge and the bottom half of the tank. The last time I ran out (today) I could hear the fuel pump start to complain just before running out of gas. I (think) I’m convinced I’m not getting a full tank.
My fill technique:
Fill it slowly. Let it burp, try to top it off… it takes only a tiny bit more and there is gas clearly visible. At the top of the tube.
This experience is all new to me in this van I’ve been driving for 2 years and I’m a bit puzzled on how to resolve this new issue.
Thanks and sorry if I’m missing some magic post somewhere about a resolution.
87 Westy 2WD “Van Geaux”
2.2 Rebuilt WB
AZ Transaxle + Peloquin Manual Transmission
GW lift springs, solar, Burley front disc, etc...
New Orleans, LA (previously CO, WA, and CA)
Past
87, 90 Westys
64, 65 splittys + various air cooled
fxr
fxr is offline
PostPosted: Mon Jun 16, 2025 3:03 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
Perhaps the tank isn't venting properly through the Evap Crap (canister etc). I'd test by removing the input hose to the canister, and trying again.
Jim Crowther
Vespa GTS 300
zerotofifty
zerotofifty is online now
PostPosted: Mon Jun 16, 2025 3:10 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
Id be looking at the vans charcoal canister to see if it or its hoses are clogged. the tank breaths thru this canister, if it is clogged then pressure builds in the tank when filling, which may shut off the fuel dispensing nozzle. Like wise when clogged, if the tank js sealed well with a good seal on the gas cap, a vacuum can be created as fuel is consumed, which can lead to the engine stalling for lack of fuel flow, this symptom might be mistaken as out of gas, when in fact plenty of gas remains in the tank.
You need to assure the venting of the tank via the canister is working.
if it is clogged and the motor stalls do to lack of fuel flow, a temporary fix is to open the gas filler cap to release the vacuum, then upon restart you can drive away a bit more until the vacuum again gets to much for the fuel pump to over come
So check this out, this is referred to as the evaporative system.
I once had a spider nest block the vent on the canister, creating a stalling and fuel filling problem.
A partial blockage may still allow van to run ok, but still be restrictive for filling the gas tank, a more complete block can both effect filling and running.
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Icebox500
PostPosted: Mon Jun 16, 2025 3:14 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
I did do a test where I (when stuck on the side of the road) removed the cap and waited a moment and tried to start the van again. No luck - no fuel. Added 2 gallons from my spare and it started right up.
2.2 Rebuilt WB
Past
87, 90 Westys
Icebox500
PostPosted: Mon Jun 16, 2025 3:19 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
Updated my post to indicate that I did to a vacuum test (as you described) and was still DOA. Added 2 gallons and ran off without a problem. I truly feel like I’m not filling the tank.
2.2 Rebuilt WB
Past
87, 90 Westys
AndyBees
AndyBees is offline
PostPosted: Mon Jun 16, 2025 3:21 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
My first Vanagon was a 1983 Tin-top with the Air-cool engine. Although I had been driving VW Beetles for over 12 years, I had no clue what to expect from the Vanagon. I purchased it for a road trip to Alaska in 1986.
Anyway, with a gasoline jug on board and a very low tank, hanging close to service stations, I drove it until it ran out of gas. I dumped in one gallon of gasoline and drove it to the nearest filling station and filled it until it would hold no more (visible in the filler neck). It held slightly over 16 gallons, counting what I dumped in.
So, from there, I would always fill it to the max to determine the MPGs. I also reset the trip-o-meter. The amount it held was always well within the ball park of the comparable MPGs. And, my 84 with the TDI engine is basically the same.
In your case, it is possible the vent system is compromised with maybe a kinked vent pipe. How many miles are you getting on a fill-up? Do you use the Trip-o-meter to aid in guessing about how much fuel you have left?
One last thing, on a steep hill and a low tank, it is possible the Fuel Pump will begin sucking air. This has happened to me with my 84. And, I am suspect of the aftermarket fuel tank, maybe the pickup tube is not close to the bottom of the tank as in the OE fuel tank.
'84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful.
Icebox500
PostPosted: Mon Jun 16, 2025 3:41 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
Reasonable questions (and a good story).
According to the 7-8 gallon fill ups, I’m getting what is expected, 15-16 MPG.
While it could be a bad vent situation, I’m doubting it since I can pull the cap and the vehicle is still “out of gas”. Frankly; I think it’s really out of gas and something is off after the new check ball.
2.2 Rebuilt WB
Past
87, 90 Westys
Ahwahnee
Ahwahnee is offline
PostPosted: Mon Jun 16, 2025 6:09 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
I seem to recall some cases of the in-tank pickup coming loose and thus unable to access the last few gallons.
That may seem counterintuitive since the outlet is right there at the bottom corner of the tank but I think it's a bit more complicated than that.
zerotofifty
PostPosted: Mon Jun 16, 2025 6:44 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
Yes pick up tube or filter may come loose...
Words to live by.
Icebox500
PostPosted: Mon Jun 16, 2025 7:10 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
An interesting theory for sure and one that’s a pain in the rear. I’ll keep an eye on that and drop the tank if I must.
2.2 Rebuilt WB
Past
87, 90 Westys
AndyBees
AndyBees is offline
PostPosted: Mon Jun 16, 2025 8:49 pm    Post subject: Re: Fuel tank not filling…. Reply with quote
Take a look at this Thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=630469
zululep
zululep is offline
PostPosted: Tue Jun 17, 2025 4:16 am    Post subject: Re: Fuel tank not filling…. Reply with quote
The check ball seems to be the only independent variable here. Sounds like you replaced it very recently, like right before your trip? Do you know if the tank has filled properly since you installed the new check ball? Even if you think it has, I'd suspect the check ball. You might want to remove the filler neck, remove the check ball, reinstall the filler neck and see if that resolves the issue. I don't have one on my '84 (early vans didn't have them) so I'm not sure how it works or why it's there. My van has never puked gas out the neck or blown up, so I'd presume you don't NEED one. When you get home you can dig into it a little more deeply. Good luck.
1984 Westfalia with Bostig Zetec
Icebox500
PostPosted: Tue Jun 17, 2025 6:38 am    Post subject: Re: Fuel tank not filling…. Reply with quote
Thanks for your reply. I agree, it’s the odd man out and I suspect something there too.
Once we get home, that’s something I’m going to take a look at.
Not familiar with them either, frankly but it’s the latest variable and the only one that’s is timed right.
2.2 Rebuilt WB
Past
87, 90 Westys
Icebox500
PostPosted: Tue Jun 17, 2025 9:35 am    Post subject: Re: Fuel tank not filling…. Reply with quote
Appreciate all the responses and thoughts. Seems I’ll need to take a more serious look when we get home. May actually have more than one cause to this oddity.
Thanks
2.2 Rebuilt WB
Past
87, 90 Westys
?Waldo?
?Waldo? is offline
PostPosted: Tue Jun 17, 2025 9:48 am    Post subject: Re: Fuel tank not filling…. Reply with quote
It's not uncommon for the tube going from filter to tank outlet to develop a leak. When that happens, the tank will only flow down to the point of the leak (e.g. at 1/2 or 1/3 of a tank). The rest of the fuel just remains in the tank. That happened to me in my '91. It would only accept 7 or 8 gallons and would "run out of fuel" when the tank was still ~1/2 full. Replacing the tank is the simple solution.
AndyBees
AndyBees is offline
PostPosted: Tue Jun 17, 2025 9:51 am    Post subject: Re: Fuel tank not filling…. Reply with quote
This is a very good point. ^^^
And, not to take away from the OPs Thread here, but I believe that's what has happened to my aftermarket tank. When I get down to about 3 or 4 gallons, going through curves hard, it will suck air and shut down the TDI engine. I've had that to happen several times.
my3bugs
my3bugs is offline
PostPosted: Tue Jun 17, 2025 9:57 am    Post subject: Re: Fuel tank not filling…. Reply with quote
couldnt you fix just fix the tube instead of replacing the tank ? im not faniliar at all with Vanagons .
AndyBees
AndyBees is offline
PostPosted: Tue Jun 17, 2025 10:01 am    Post subject: Re: Fuel tank not filling…. Reply with quote
Replacing one of the pipes/tubes inside a fuel tank would be almost like changing the carburetor on a V-8 though the exhaust pipe.
Take a look at this thread... https://www.thesamba.com/vw/forum/viewtopic.php?t=630469
dhaavers
dhaavers is online now
PostPosted: Tue Jun 17, 2025 10:07 am    Post subject: Re: Fuel tank not filling…. Reply with quote
<see below>
?Waldo? wrote:
It's not uncommon for the tube going from filter to tank outlet to develop a leak...
I took this to mean the tube inside the tank, from the screened sump pickup (pictured above) to the outlet. No way in there without going in there.
Semantics… <shrug>
- Dave
"The WonderVan"
my3bugs
my3bugs is offline
PostPosted: Tue Jun 17, 2025 10:08 am    Post subject: Re: Fuel tank not filling…. Reply with quote
OK silly me !!! like i said i am not familiar with these and i see what you mean now !!! thanks steve
un serviceable !!!
