Running Boards
ssquires68
ssquires68 is offline
PostPosted: Sat Apr 17, 2021 6:07 am    Post subject: Running Boards Reply with quote
Thinking about replacing my running boards on my 66. Has anyone purchsed the mexican one's from Jbugs?
My car is not a "show" car so they don't need to be OEM stuff but I would like something that looks good without costing me a fortune.
https://www.jbugs.com/product/113898500HD.html
TIA
Airstream65
Airstream65 is offline
PostPosted: Sat Apr 17, 2021 6:45 am    Post subject: Re: Running Boards Reply with quote
I bought a set a year ago. They are pretty decent quality for the price.
ssquires68
PostPosted: Sat Apr 17, 2021 6:56 am    Post subject: Re: Running Boards Reply with quote
Did you have to do any trimming anywhere to get them to set in fully?
aa390392
aa390392 is offline
PostPosted: Sat Apr 17, 2021 8:05 am    Post subject: Re: Running Boards Reply with quote
Are you existing one original? Remakes from my understanding are more rounded on the top
If possible recondition your OG's .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
FL-Frank
FL-Frank is offline
PostPosted: Sat Apr 17, 2021 8:52 am    Post subject: Re: Running Boards Reply with quote
Five years ago, I bought and mounted a new pair on my ‘67 from WW, and I’m pleased with the fit and finish.
“Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD
Airstream65
PostPosted: Sat Apr 17, 2021 4:21 pm    Post subject: Re: Running Boards Reply with quote
I did not trim anything, they fit pretty good, but I will probably buy a set from WW eventually.
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Sat May 08, 2021 10:30 am    Post subject: Re: Running Boards Reply with quote
A few minutes ago I installed a left-side Wolfsburg West running board on my '66.
It fits absolutely perfectly.
Well worth the 75 bucks. Very Happy
Schnitzelfuss
Schnitzelfuss is offline
PostPosted: Tue Jun 17, 2025 7:24 am    Post subject: Re: Running Boards Reply with quote
I don’t recommend the low cost Mexican boards. One side was 11mm shorter than the other. Driver side fit just fine. “Some trimming required” for the passenger side as JBugs says. I guess trimming to them means closing a half-inch gap with custom metal fabrication and welding. And sourcing a spare new rubber mat so I can cut a slice from it and toss the rest. And elongating the fender mount holes too. And all the 6mm openings for the heater channel nut plates required major surgery.
zerotofifty
zerotofifty is offline
PostPosted: Tue Jun 17, 2025 7:33 am    Post subject: Re: Running Boards Reply with quote
The stock VW boards are made of thicker, much more ridged metal than many of the aftermarket types.
the shiny trim is much wider on the early stock boards that many of the aftermarket.
if your stock board is not mangled bad other than the vinyl cover, id be thinking best bet is to recover it
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Ggiomett
Ggiomett is offline
PostPosted: Tue Jun 17, 2025 7:48 am    Post subject: Re: Running Boards Reply with quote
They’re not OEM, but hey, they bolt on, look the part, and don’t cost a kidney. What more can you ask from some glorified foot shelves?
zerotofifty
PostPosted: Tue Jun 17, 2025 6:00 pm    Post subject: Re: Running Boards Reply with quote
Some of the aftermarket boards are so flimsy that they can bend if you use them as a step. they get all out of wack and them look horrible. the chinsy trim on them is also thing and dents very easy.
As stated, if the only issue on an original is the vinyl being bad, recover them verses the junkie, poor shaped, thin narrow trim , reproduction junk that is as cheap as a dented 16 oz. can of kidney beans
Words to live by.
meranda
meranda is offline
PostPosted: Wed Jun 18, 2025 4:03 am    Post subject: Re: Running Boards Reply with quote
I think your problem is the RHS guard is too short,it should almost touch the vertical seam on the body which yours does not.
Currently filling the garage
1961 beetle cabrio
1971 Superbug
1974 Porsche 911S Targa
1968 1500 Beetle A Project!
Past Garage fillers dozens of type1 &type3 VWs
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan
Schnitzelfuss
PostPosted: Wed Jun 18, 2025 4:19 am    Post subject: Re: Running Boards Reply with quote
Thanks- I’m assuming RHS means right hand side, but what “guard” are you referring to?
slave1pilot
slave1pilot is offline
PostPosted: Wed Jun 18, 2025 6:21 am    Post subject: Re: Running Boards Reply with quote
By guess would be the fender itself.
I assume you measured the running boards themselves though
Currently:
1959 pan with a 64 body and a 63 ragtop grafted in Herbie replica
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
zerotofifty
PostPosted: Wed Jun 18, 2025 7:04 am    Post subject: Re: Running Boards Reply with quote
yeah, the gap is too big cause the fender is too far forward
Words to live by.
Schnitzelfuss
PostPosted: Wed Jun 18, 2025 10:08 am    Post subject: Re: Running Boards Reply with quote
Hmmm. The inboard trailing edge of both left and right front fenders measure the same distance from the A Pillar protrusions- about 17mm. But the outboard edges measure differently. On the left side, which is the side the running board fits nicely, it’s about 30mm to the outboard trailing edge. On the right side, it’s 40mm. That’s my gap. Both fenders are up tight against the car body (not to assume the car body is straight and correct). I can’t move the right fender any further rearward or it will be offset noticeably at the front of the car where it abuts the apron. No apparent signs of collision damage or repair to the right front fender. It is visually identical to the left other than the trailing edge measurements. Also note after adjusting the front RHS fender as much as I could, the inboard trailing edge of the running board now touches the fender - it’s the outboard fender edge that slopes away from the outer edge of the running board by 10mm. Could I have fenders from two different model years?
Schnitzelfuss
PostPosted: Wed Jun 18, 2025 10:21 am    Post subject: Re: Running Boards Reply with quote
After fender adjustment and adding metal to the front of the running board. With the added metal I can join the fender and close the gap. But that leaves me with a how to trim it dilemma. I’d rather not have to add the metal and cover it with something but I don’t think I can hammer and dolly 10 additional millimeters into that outboard fender edge.
zerotofifty
PostPosted: Wed Jun 18, 2025 4:29 pm    Post subject: Re: Running Boards Reply with quote
Many aftermarket fenders are of poor fit.
I believe the stock running boards were the same size through near the entire time of production of the Bug, thus the fender detail where it meets the running board should all be the same.
Words to live by.
meranda
meranda is offline
PostPosted: Wed Jun 18, 2025 8:19 pm    Post subject: Re: Running Boards Reply with quote
We call them mudguards you call them fenders, In Australia a fender is the rubber tyres on the sides of a Tug!
1961 beetle cabrio
1971 Superbug
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan
2type2
2type2 is offline
PostPosted: Thu Jun 19, 2025 7:06 am    Post subject: Re: Running Boards Reply with quote
Recently put some of these on my '65,are Mexican made , starts with "K"(?) Do they fit? Yes, considering how my fenders may not both be OG. Had to widen a couple screw holes to better fit. For about $100 they are worth it but don't set your expectations too high. If your car isn't left out in the weather and you are not a complete perfectionist they will serve sufficiently. Like most aftermarket cheap parts, don't expect perfection in fitment or longevity.
"A life of peace and happiness depends on your own gratefulness"
