TheRookie Samba Member
Joined: September 24, 2022 Posts: 116 Location: Western Cape
Posted: Wed Jun 18, 2025 2:27 pm Post subject: Dialing in your Cam |
Hi Guys
I watched a video with a guy dialing in his cam on his new CB Performance engine,How ever he has an adjustable cam gear
It seems a long process and I can see it's worth the effort
My question is what's the point in dialing in a cam if you have a fixed cam gear .You can't advance or retard the cam. Once the cam is bolted to the gear it's fixed, All you can really do is install.
Am I missing something here or not ??? |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7846 Location: Videbaek Denmark
Wreck Samba Member
Posted: Wed Jun 18, 2025 2:37 pm Post subject: Re: Dialing in your Cam |
to make sure the cam is ground correctly is the main one , I do it on all four lobes after getting a Scat cam that had one lobe a lot bigger than the other 3 , (10 degrees at 0.050") |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 542 Location: South Bay LA, California
Posted: Wed Jun 18, 2025 3:04 pm Post subject: Re: Dialing in your Cam |
Wreck wrote: |
Yikes!!! |
Posted: Wed Jun 18, 2025 3:06 pm Post subject: Re: Dialing in your Cam |
TheRookie wrote: |
Hi Guys
One of my CB cams measured out to need 2* advance and the other was dead nuts, with the same gear. To get them aligned with the cam cards, anyway.
Gotta get the adjustable gear… |
modok Samba Member
Joined: October 30, 2009 Posts: 27678 Location: Colorado Springs
Posted: Wed Jun 18, 2025 3:12 pm Post subject: Re: Dialing in your Cam |
The point of checking the cam timing, is to check your cam timing.
There are no warning lights in the space shuttle for things the astronauts can't control, its true,
but we aren't in space are we?
If it is too far off there are many ways to do something different. |
