MimosaSix Samba Member
Posted: Thu Jun 19, 2025 1:05 pm Post subject: What jack to carry for changing a flat tire? |
I have a 72 Super and it did not come with any type of jack for changing a flat. I was wondering what type of scissor or Bilstein jack do you carry for changing a flat while out on the road? Also is there a good spot on the car for even using a scissor jack without lifting the entire side? I need to get a jack just in case. I searched the forum and didn't find a great answer. Thanks! |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4489 Location: viroqua wi.
Posted: Thu Jun 19, 2025 1:24 pm Post subject: Re: What jack to carry for changing a flat tire? |
A small trolley jack that fits under the hood. Or the back seat. |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 870 Location: Moreno Valley
Posted: Thu Jun 19, 2025 1:30 pm Post subject: Re: What jack to carry for changing a flat tire? |
ya its like a mini floor jack , got mine at harbor freight for under 40 dollars . much more versatile . but i also have the original jack in the bug
i keep a short piece of 2 by 4 to set between the jack and car so it doesnt leave any marks . |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 357 Location: Eastern north carolina
Posted: Thu Jun 19, 2025 2:11 pm Post subject: Re: What jack to carry for changing a flat tire? |
I carry a small scissor jack which came on older Toyotas. On the front I jack on one of the end frames of the front suspension beam. For the rear I jack on the bottom of the shock housing. I also carry several short 2x4 blocks, a small square of plywood to go under the jack if on dirt. Has worked for me for over 55 years. Good luck |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2890 Location: HdG, MD & NJ
Posted: Thu Jun 19, 2025 2:53 pm Post subject: Re: What jack to carry for changing a flat tire? |
When are they going to make a trolly jack in aluminum! _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1425 Location: San Diego
Posted: Thu Jun 19, 2025 2:59 pm Post subject: Re: What jack to carry for changing a flat tire? |
NJ John wrote: |
When are they going to make a trolly jack in aluminum! |
https://www.amazon.com/Profile-Professional-Trolle...NX6L5?th=1
But it'll cost you twice as much. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Thu Jun 19, 2025 3:30 pm Post subject: Re: What jack to carry for changing a flat tire? |
I actually have that jack. I’m referring to the stubby ones. Sometimes their in a plastic case, but still weigh a bunch. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4150 Location: Georgia
Posted: Thu Jun 19, 2025 3:34 pm Post subject: Re: What jack to carry for changing a flat tire? |
I used to use a small scissor jack but eventually sought and bought an original Bilstein. I like it a lot better than the scissor and there’s actually a spot for it. Sure, it lifts one whole side of the car but, so what.
I haven’t had a chance to change a flat yet, but I have practiced putting the car up and down with it.
My biggest problem is putting the flat somewhere as my wheels are too wide to fit in the spare well. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Thu Jun 19, 2025 5:48 pm Post subject: Re: What jack to carry for changing a flat tire? |
Bobs67vwagen wrote: |
Where are using as a jacking point? Say if you need to change a front flat. |
vamram  Samba Member
Posted: Thu Jun 19, 2025 7:24 pm Post subject: Re: What jack to carry for changing a flat tire? |
I carry the original but am also on the lookout for a better option. A guy in my neighborhood has a '73 Super that his father bought new. He damaged it last year when the body metal buckled above the jack slot while doing some work on the car.. Real downer. I've had to use it on 3 occasions without problems, but definitely want an alternative. The aluminum one looks good, even if pricey. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
meranda Samba Member
Joined: August 09, 2015 Posts: 332 Location: Melbourne Australia
Posted: Fri Jun 20, 2025 3:47 am Post subject: Re: What jack to carry for changing a flat tire? |
The answer is NEVER have a flat tyre!!! _________________ Currently filling the garage
1961 beetle cabrio
1971 Superbug
1974 Porsche 911S Targa
1968 1500 Beetle A Project!
Past Garage fillers dozens of type1 &type3 VWs
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5553 Location: Lefty, CA
bugger-off Samba Member
Posted: Fri Jun 20, 2025 9:25 am Post subject: Re: What jack to carry for changing a flat tire? |
NJ John wrote: |
I actually have that jack. I’m referring to the stubby ones. Sometimes their in a plastic case, but still weigh a bunch. |
A bottle jack? |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11787 Location: Redding, CA
Posted: Fri Jun 20, 2025 10:20 am Post subject: Re: What jack to carry for changing a flat tire? |
I just used a Honda scissors jack. Put the head directly under the original jacking point and jacked it up. The scissors jack is lightweight, compared to a floor jack, and it's not rolling around and banging into your trunk lid. I also use a short 2x4 to place on the ground before placing the jack on it.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 625 Location: South of Raleigh
Posted: Fri Jun 20, 2025 11:04 am Post subject: Re: What jack to carry for changing a flat tire? |
It probably doesn't. Buyer beware. |
Posted: Fri Jun 20, 2025 11:17 am Post subject: Re: What jack to carry for changing a flat tire? |
bugger-off wrote: |
NJ John wrote: |
A bottle jack? |
No, just a small floor jack in a case. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Fri Jun 20, 2025 11:32 am Post subject: Re: What jack to carry for changing a flat tire? |
Mimosa6 if the flat is in the front I jack under the end portion on the front suspension beam that is down lower than the bottom tube. In the back I jack under the shock housing. I started doing this many years ago in the northeast( long Island) , because many of the bugs I had back then had rusted around the jacking points which would sometimes cave in when you tried to use them.Bob |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2864 Location: Thornton, CO
Posted: Fri Jun 20, 2025 5:38 pm Post subject: Re: What jack to carry for changing a flat tire? |
That's exactly what I have in my Beetle and Civic, wood and all, except I use pieces of 2x6. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch'
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79536 Location: Sneaking up behind you
Posted: Fri Jun 20, 2025 5:43 pm Post subject: Re: What jack to carry for changing a flat tire? |
I carry a can of Fix-A-Flat.
I have different size tires front and read (195/55-15 and 205/60-15) so neither will fit in the spare tire well.
My car is lowered so a stock 165-15 will hit the fender. The transaxle has a ZF-LSD so running different size tires left/right can damage the friction clutches.
I do carry a Porsche 928 scissor jack. It will fit under the lowered front, folds very small and is made of aluminum so it's very light.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
