off idle adjustment on IDFS(china)
Page: Previous  1, 2, 3  Next
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Thu Jun 19, 2025 9:39 pm    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
Thanks sled
Im in agreement. I read somewhere you want to be at 6mm under your intake valve size.
I have never cared to much what the idle afr was, i was more or less using that to judge how far i was from LBI. John from aircooled used to say he would dial in LBI then turn out a half turn because LBI is not stable. I've found that to be somewhat true. I don't have half a turn before it starts choking on a rich mix. So i tend to like about 1/4 or less. Just for comparisons sake, i keep track of the afr at idle when i tune. Not because i want a certain afr but because i know it does better. I hope that makes sense. Seems like my engine likes it a little closer to 12. LBI usually gets me around 13 everytime. I can also watch the afr to see if i have a cylinder that is a little of from the others. The afr will bounce more. If I can get the bounce to cover only a 0.3 spread instead of the 0.9 spread i tend to get on the initial setting. I've actually gotten pretty good at focusing on the engine sounds and getting the right spot.
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
Alstrup
Alstrup is offline
PostPosted: Fri Jun 20, 2025 5:11 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
You didnt mention anything about 38 venturis from the beginning Rolling Eyes The classic "I have this problem, what could it be?" and then leave out vital information.
YES, reduce venturi size to 36. Mikes explanation about collapsing airspeed is probably 40% right. The rest is the fact that a wimpy ignition can´t ignite what ever comes in, because the mix is too poor.
The comment on the venturis needing to be 4-6 mm smaller than the intake valve is an old viwes tale. It is not correct. The venturi size should be what the engine needs to perform accordingly to the rest of the package. If you start working with the problem, like really dive in to it instead of just doing what the next guy tells you, you will be amazed as to how small venturis some engines can perform with and at the same time you wiull be surprised as to how large venturis other engines need to perform their best.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 8:41 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
Why do you keep picking on my ignition?? Is a Ford EDIS system weaker than the single coil VW setup everyone else is using?
Brian H.
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 8:45 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
I typed a long rebuttal to your post but I'm not going to let you take me there again. I got little time for negative life sucking people. You obviously have a lot to share, but you can't be nice about it. You also haven't said anything we all weren't already thinking.
Brian H.
sled
sled is offline
PostPosted: Fri Jun 20, 2025 9:00 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
I'd probably track down some 34 vents as well and play with those. Yes, they're a little small in a 44 carb, but it might be an interesting experiment. How high do you want to rev this engine? no point in using a vent that will allow it to rev higher than you want. Stronger vacuum signal is beneficial in a few ways.
what's trans gearing and tires do you have?
drive your split.
Alstrup
Alstrup is offline
PostPosted: Fri Jun 20, 2025 9:01 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
Your EDIS system is only as strong as your coil. I may be wrong, but it looks like a regular blue Bosch. If I´m wrong I appologize. But then you should have said so, so there was no doubt.
The reason for my negativity is that we CANNOT help you when you do not tell everything. And even thoigh I try to stay away from incomplete questions I apparently fall into the trap sometimes anyway.
But the rest still stands as such.
MAYBE, just maybe, you need to go all the way down to 34 mm venturis to get the signal strength you need for the engine behavior you want. I saw somewhere that your camshaft was around 288 seat. (No brand) That can be a challenge to get to pull well down low, which can result in you needing the even smaller venturis. The not overly large headeris definitely a positive aspect in that quest.
Alstrup
Alstrup is offline
PostPosted: Fri Jun 20, 2025 9:03 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
Ohh, fair enough. I´ll put a cork in it.
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 9:22 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
I'd rather you didn't. I value everyone's input. Just remember, this thread just started off as a general question about dealing with off-idle hesitation. I was looking for all causes to start ruling them out. Then it turned into a troubleshooting thread. So initialy I didn't expect a lot of specifics even if I made it seem like it. Sometimes I go back and read what I type and it's not how I remember saying it. I think I'm a little dyslexic or something.
Brian H.
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 9:33 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
I was thinking of saying I'd do that, but then I didn't because I thought maybe I was being a little too reactionary.
This is my baja engine. I had hoped it'd be a stump puller, but I managed to turn it into more of a top end engine. I didn't realize at the begining that IDFs tend be designed for WOT and I think that's where I failed. I'm determined to try to make them work. A lot of people do so why can't I? I understand I'm only going to be able to make the IDFs perform so well. But right now we're just working on road manners. Not twisting through the trees in first and second gear.
I have what I believe is just a basic type 1 trans. maybe 4.12? I should probably figure it out and write it down so I don't forget it. It's been a great trans. I had something like a 5.82( it was upper 5's) built by Petrucci when I bought it years ago but that was only good for dunes. I sold that (wish I hadn't) and a good friend GAVE me this clean IRS trans I've run this whole time. It thunks a little going into third, but it has been a dependable trans. I may go to bus when I restore the car in a few years, but I really don't have any issues with this trans except first gear being too short. When I get on the highway I feel like I could easily grab a 5th gear if it had one. I don't know all that much about gearing transmissions. I suppose I will have to learn when I upgrade eventually and have one built.
Brian H.
Dale M.
Dale M. is offline
PostPosted: Fri Jun 20, 2025 9:39 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
IDF's are not wide open carbs you are mistaking them for IDA'a.... IDF's are very diveable in all ranges....
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 9:43 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
oh ok. Well my carbs are confused then lol they self-identify as IDAs Laughing
Brian H.
chrisflstf
chrisflstf is offline
Here is my opinion. Idf float setting is 10 to 12mm, right? Chinese webers seem to be set at 14mm (mine were). So a 10mm setting means the fuel level is higher than a 12mm setting. Correct? If that is true, then modoks statement in regards to fuel level of the emulsion tube makes sense.
What modok wrote:
"Does changing the fuel level do anything for it?
If the fuel level is too high, covering the main ring of holes in the emulsion tube, it can cause a slight delay in the mains starting, followed by a rich spot.
OR, if the fuel level is too far below the holes, then the opposite."
One other item from my own experience is the drillings on chinese emulsion tubes are all over the place and sloppy as well
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 9:45 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
I wish I could keep all this stuff straight like you guys. I'm just a dumb electrician. Probably too many amps thru the knoggin.
Brian H.
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 9:50 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
I always find this interesting
the CB's are actually not consistent either if I'm seeing that right.
I have a couple sets of the chinese F11's. They are all the same surprisingly. I wish I had my jet kit at work today I'd take some pics. There was a time last year I was going thru them with a magnifying glass and checking for flashing or irregular shaped ports
Brian H.
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 10:12 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
I mentioned it before and I'm going to see if I can do it as an alternative to cracking open the carb since it's a big production to get inside my carbs now. but I'd like to see if I can unscrew a stack quick enough and pull it out to be able to see the gas line on it before it evaporated. Honestly, what better way could there be than actually seeing where the fuel level lands on the tube? Better than setting to some arbitrary distance and then hoping it's where you want it.
Brian H.
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 10:42 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
Maybe even putting a sharpie line down the side and reinstalling it and removing again to see where the line disappears...
Brian H.
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 10:48 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
Along this line of thought, I also noticed my fuel pressure gauge is reading lower than I like. It's around 2.6-2.75 psi. when I want it at 3. That is also hard to get at now lol. Something to play with this weekend. I'm sure fuel starvation isn't an issue when sitting still making a turn, but I get a lot of bouncing in my afr reading while I'm at a constant cruising speed on the smooth highway. Maybe the level isn't quite keeping up in that situation? Otherwise I have some inconsistency between my cylinders causing them to not burn equally at speeds greater than 60mph.
Brian H.
Dale M.
Dale M. is offline
PostPosted: Fri Jun 20, 2025 11:49 am    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
Think it's time for you to get EFI Subie....
ORANGECRUSHer
PostPosted: Fri Jun 20, 2025 12:08 pm    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
blasphemer!
Brian H.
SGKent Premium Member
SGKent is offline
PostPosted: Fri Jun 20, 2025 12:20 pm    Post subject: Re: off idle adjustment on IDFS(china) Reply with quote
The symptom: Brief hesitation off idle.
99% of the time wrong idle mixture and / or transition port mis-adjustment. They are as much or more important than the accelerator pump. If they are exposed too early or too late then either the wells are already drained or they do not come into play soon enough. A small movement opening the butterfly should exposed the transition ports to allow enrichment. This will happen long before the accelerator pump. Worse, if they are even a tiny bit exposed at idle, then the carb is running off them instead of just the idle enrichment. Hold your hand up if you do not know what these are and need an explanation of what they do.
Page 2 of 3
