Big nut reduction boxes. Different?
[email protected]
vwlownslo69@hotmail.com is offline
PostPosted: Mon Jun 23, 2025 3:02 pm    Post subject: Big nut reduction boxes. Different? Reply with quote
Hey all, I just picked up these reduction boxes and I failed to notice that they are somewhat different. They are both big nut boxes and a quick count of turns tells me they are the same ratio. (I haven't pulled them apart to count teeth, I just marked the axle flange and the stubs and counted a revolution, if you will)
I noticed that one has the flat top to accept a bump stop and the other does not.
Does this mean that one is 3/4 ton and the other is 1 ton?
Any info is greatly appreciated
BarryL Premium Member
BarryL is offline
PostPosted: Mon Jun 23, 2025 6:23 pm    Post subject: Re: Big nut reduction boxes. Different? Reply with quote
Don't know when they went to the bump-stop but it shouldn't matter for fit and compatibility. Hardly ever does the bump-stop hit.
Chuey
Chuey is offline
PostPosted: Mon Jun 23, 2025 9:50 pm    Post subject: Re: Big nut reduction boxes. Different? Reply with quote
The one without the bump stop probably belonged to the guy who invented those Kong chew toys for dogs. Smile
Chuey
adriano
adriano is offline
PostPosted: Mon Jun 23, 2025 11:29 pm    Post subject: Re: Big nut reduction boxes. Different? Reply with quote
Stop bumper was introduced from chassis 215 036 651 MY 65
Clara Premium Member
Clara is offline
PostPosted: Tue Jun 24, 2025 8:10 am    Post subject: Re: Big nut reduction boxes. Different? Reply with quote
early 1 tons did not have bump stops
late 1 ton axle tubes do have bump stops.
If you are putting the tranny in a 61, or other bus w/o the upper stops for the bump stops, it doesn't matter.
If putting it in a late split that has the upper stops for the bump stops, I would use axle tubes with the bump stops, if I had the option.
Then again, I've taken the 66 kombi on Shasta a few times. Wink
you can see where teh bumpers stop against in this pic:
[email protected]
PostPosted: Tue Jun 24, 2025 9:12 am    Post subject: Re: Big nut reduction boxes. Different? Reply with quote
So for clarification, are you indicating that I have 1 early 1 ton axle and 1 late 1 ton axle?
Clara is offline
PostPosted: Tue Jun 24, 2025 9:28 am    Post subject: Re: Big nut reduction boxes. Different? Reply with quote
[img]https://www.thesamba.com/vw/classifieds/pix/10622210.jpg[/img
Well, actually, early 1 ton is the 63 little nut version, so you have one mid 1 ton axle/RGB and one late 1 ton axle tube/RGB
I can tell they are both 64-67 one ton as they both have the circle on the side that faces the spring plate. That's the plug you have to pull out to get to the inner nut for the lower inner bearing.
You can run those as a pair.
[email protected]
PostPosted: Tue Jun 24, 2025 9:42 am    Post subject: Re: Big nut reduction boxes. Different? Reply with quote
Thank you for the clarification Clara! I greatly appreciate your input and everyone else's on here! Cool
