Cylinders 1 and 2 not firing
Page: 1, 2, 3  Next
Tbrier100
Tbrier100 is offline
PostPosted: Mon Jun 23, 2025 7:34 pm    Post subject: Cylinders 1 and 2 not firing Reply with quote
I have a 1979 bus with a 2.0 motor and dual carb set up. Just installed the motor the other day. Bench set the carbs empi hpmx 40, has spark but won’t run on one and two. I rechecked gap in plugs and reset the idle and mixture screw, any recommendations? Thank you
Wildthings
Wildthings is offline
PostPosted: Mon Jun 23, 2025 9:12 pm    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
Maybe dump some fuel injection cleaner down into the bowl vent on the 1-2 carb and let it sit for a day or two. If the cabs sat for months with ethanol laced fuel rotting in the bowls, disassembly and cleaning may be required. Which gasket did you use between the manifolds and the heads? The thick fuel injection style gasket can end up sitting on the tin sometimes causing a vacuum leak.
Ignition wise have you checked for a cracked distributor cap? If the 1-2 wires are crossed it should backfire badly.
1vwjedi
1vwjedi is offline
PostPosted: Tue Jun 24, 2025 2:53 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
Sounds to me you may have an intake leak. It’s tough bolting dual carbs down. Easy to end up with them sucking air on one side or the other. Use carb cleaner or brake clean. Spray all mating surfaces if it’s sucking air. It will tell you where.
Happens all the time. Easy fix.
Tbrier100
PostPosted: Tue Jun 24, 2025 4:32 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
They are brand new carbs I went thought and bench set everything and cleaned them.
Tbrier100
PostPosted: Tue Jun 24, 2025 4:37 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
I did pull the plugs and they smelled of gas, if there was a leak would it not ignite the gas? I’ll try it [/s]
wagen19
wagen19 is offline
PostPosted: Tue Jun 24, 2025 4:52 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
Is there fuel inside the 1-2 carb for sure and the acceleration pump system also operates properly?
The firing order is correct?
Are only the carbs new on that engine, or more ignition parts?
Valve adjustment OK?
Tbrier100
PostPosted: Tue Jun 24, 2025 5:36 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
The top end of the engine was rebuilt, new pistons, rings, jugs, heads and new valves, bottom was solid. I rechecked the valve adjustment. the lifters are hydraulic and I bled them before putting them back in. I bought a 123 ignition distributor but couldn't get it to fire right so borrowed my friends extra distributor and now we have it running on two cylinders. the carb I did not check that. the pump system works good, when I pulled the plugs on that side to check them they smelled of fuel.
lil-jinx
lil-jinx is offline
PostPosted: Tue Jun 24, 2025 5:54 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
how does the compression feel for those two cylinders.
1968 Dune Buggy sold dec 2024
1974 parts bus
Tbrier100
PostPosted: Tue Jun 24, 2025 5:57 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
from just turning the motor I can feel it. but the rings are not bedded in yet so I haven't done a compression test
wagen19
wagen19 is offline
PostPosted: Tue Jun 24, 2025 6:27 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
Is the feeling of compression about the same on all 4 cylinders?
What is with the dizzy and I-system before new built up?
(dizzy shaft bent, contact not opens on 2 cylinders?)
Tbrier100
PostPosted: Tue Jun 24, 2025 6:37 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
Shaft doesn’t seem to be bent. How would I i know that? Compression feels pretty close on all from what I can tell. Contacts on distributor?
Tbrier100
PostPosted: Tue Jun 24, 2025 7:43 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
you think I should do a compression test?
lil-jinx
lil-jinx is offline
PostPosted: Tue Jun 24, 2025 8:04 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
maybe spray a little fuel into the carb while cranking,a drop of oil in the cylinders may help with compression,use a blow gun in the spark plug hole to blow the oil around in the cylinder
1974 parts bus
wagen19
wagen19 is offline
PostPosted: Tue Jun 24, 2025 8:23 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
My thinking is to check, if the contact in dizzy opens properly on all 4 cylinders.
I had once issues, sparks not on all plugs, because the contact in dizzy had not opened on all cylinders. (due to wear in bearing of dizzy and slightly bent shaft.
After a compression test on all 4 cylinders, you would have clear insight of inner pressure and mechanical condition.
Of course OK must be:
1.) mechanical parts, valves, compression
2.) ignition, timing, no too hight resistance in spark plug wires and connectors
3.) fuel, pump, lines, carb, air filter (not plugged)
4.) exhaust system not plugged (very rare issue, but not to forget)
I had several times issues with one not opening or semi plugged needle valve on dual carb set ups.
Tbrier100
PostPosted: Tue Jun 24, 2025 10:53 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
I will try all this tomorrow and report back, thank you
aeromech
aeromech is offline
PostPosted: Tue Jun 24, 2025 11:29 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
Look down the carb throats using a mirror while the fuel pump is running or just after shut down. See if fuel is just dumping into the engine. If so, the extra fuel will drown out any attempt at combustion.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tbrier100
PostPosted: Tue Jun 24, 2025 11:32 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
I will check, I’m not new to cars but I don’t know carbs at all or much old school stuff. I have a fuel pump that puts out 2.5-3 psi of fuel. I will check that. Thank you
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jun 24, 2025 11:41 am    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
check your plug wiring again. Most likely 1 and 2 are reversed. If not spray a little berryman's b12 down the carb and see if all 4 run for a second.
aeromech
aeromech is offline
PostPosted: Tue Jun 24, 2025 3:12 pm    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
Just yesterday we were working on a Porsche 356 kit car based on a 1967 Ghia. It’s been parked in a garage for several years. Once we drained the tank, replaced the Facet electric fuel pump, and installed new fuel lines and filter we tried to start it.
It ran but not very well. Checking the carb synch using a snail, we found that 1&2 side Weber had almost no flow while the left carb was working. On further inspection we found that the right side carb was missing the idle adjustment screw. We believe this caused the throttle plates to be completely closed and is the source of the problem.
One call to Justin at Blackline Racing in Idaho and we have a new screw and spring in the mail due Friday. Thank you again Justin.
I’ll try and get back here soon with any results we come up with.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
timvw7476
timvw7476 is offline
PostPosted: Tue Jun 24, 2025 5:44 pm    Post subject: Re: Cylinders 1 and 2 not firing Reply with quote
There's an excellent HPMX set up guide on You Tube. It goes into detail about idle set up at minute 5:00 or so.
The Redline Instructions mention shoving a .004" feeler gauge into the carb base to set the throttle blade(s) via the idle stop screw. All else is done via mixture screws & jetting changes.
Page: 1, 2, 3  Next
