Matt Biscotti Samba Member
Joined: August 23, 2006 Posts: 19 Location: Painesville,Ohio
Posted: Tue Jun 24, 2025 3:47 pm Post subject: CHINESE WEBER 40 IDF's |
I am working on a car for a friend. It is a 1972 Ghia. It came with a 1776 in it. The motor has compression the valves are are adjusted and the timing is set correctly on the bosch 009 distributor. My friend just bought the car, so I don't know the exact specs on the motor. He was told it has a w100 cam. The car with the idle by pass screws all the way in gets best idle with the idle mixture adjustment screws all the way in. This is with either.40 or .50 idle jets. With the .40 jets in and the idle bleed screws backed out 2 1/2 turns it idles really high. I normally just leave the idle bleed screws all the way in and jet from there. What would cause this condition? I am skeptic of Chinese Weber clones. Please advise- |
Stinky123 Samba Member
Joined: January 31, 2022 Posts: 231 Location: Grand Junction, CO
Posted: Tue Jun 24, 2025 8:47 pm Post subject: Re: CHINESE WEBER 40 IDF's |
I have no idea(r).
Your 7th sentence is sorta tough to decipher.
But, or course, screws all the way in means something is wrong....which jets is this with. This would tend to indicate that the jet is to big.
.40 Idle Jets and 2 1/2 turns sounds right. Can you turn the throttle stop screw in? |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4009 Location: Rapid City, South Dakota
Posted: Tue Jun 24, 2025 9:10 pm Post subject: Re: CHINESE WEBER 40 IDF's |
Is this a single center mount, or a pair of IDF’s?
When you said you set the timing “correctly” what is that? Most 009 distributors will need some tweaking of the advance stops to be correct, especially with dual carbs.
I find most dual carb engines prefer 10-12deg at idle, and 28-30 full advance.
Getting the idle timing up will help clean up the idle. 40’s also sound small. You might need to drill out the idle air holes, and then increase the size of the idles.
50-52’s should be about right for a mild 1776 with dual carbs.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
Posted: Wed Jun 25, 2025 12:21 am Post subject: Re: CHINESE WEBER 40 IDF's |
BRIAN:
Thank you for the reply. The timing is 30 degrees when it is all in at about 3000 RPM.What size would you drill the idle air holes to? These are the air inlets in the top of the carburetors, yes? |
Posted: Wed Jun 25, 2025 12:25 am Post subject: Re: CHINESE WEBER 40 IDF's |
These are dual 40 IDF copies. |
oprn Samba Member
Joined: November 13, 2016 Posts: 14809 Location: Western Canada
Posted: Wed Jun 25, 2025 3:50 am Post subject: Re: CHINESE WEBER 40 IDF's |
Brian_e wrote: |
40’s also sound small. Brian |
Really??
I am pretty happy with a set of 40s on my 1911 with 31mm vents. Pulls hard to 5800 RPM. _________________ Our cars get old, we get old but driving an old VW never gets old! |
BFB Samba Member
Posted: Wed Jun 25, 2025 6:17 am Post subject: Re: CHINESE WEBER 40 IDF's |
yeh that's it, guy doesn't understand his carbs well enough to know why theres an issue so recommend he drill holes in things.
air bypass can stay in, but if your idle mixtures are all all the way in ( closed ) something is wrong _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
oprn Samba Member
Posted: Wed Jun 25, 2025 6:54 am Post subject: Re: CHINESE WEBER 40 IDF's |
I could be wrong but I think the OP is talking about the idle AIR bypasses being screwed all the way in not the idle mixture needles.
What size are the chokes? That I believe is what matches the carb size to the engine is engine displacement and intake valve size as much as anything. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20809 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Jun 25, 2025 7:42 am Post subject: Re: CHINESE WEBER 40 IDF's |
IF Idle bypass screws are closed, this is normal, if idle mixture screws are all the way in and it still runs, that probably means he is on main jets and and needs to back down the throttle stop screws and open up idle jet adjustment screws.... OR insert And .40 jets seem to small....
One also has to wonder if one or both carbs may have butterfly's drilled.... _________________ “Fear The Government That Wants To Take Your Guns"
oprn Samba Member
Posted: Wed Jun 25, 2025 7:56 am Post subject: Re: CHINESE WEBER 40 IDF's |
Dale M. wrote: |
IF Idle bypass screws are closed, this is normal, if idle mixture screws are all the way in and it still runs, that probably means he is on the transfer ports and and needs to back down the throttle stop screws and open up idle jet adjustment screws.... |
There, fixed it for you! _________________ Our cars get old, we get old but driving an old VW never gets old! |
Fender38 Samba Member
Joined: April 11, 2015 Posts: 113 Location: Las Vegas, NV
Posted: Wed Jun 25, 2025 8:10 am Post subject: Re: CHINESE WEBER 40 IDF's |
oprn wrote: |
Brian_e wrote: |
Really??
I am pretty happy with a set of 40s on my 1911 with 31mm vents. Pulls hard to 5800 RPM. |
He was referring to the jet size being small, not 40 IDF's being small. |
Posted: Wed Jun 25, 2025 8:31 am Post subject: Re: CHINESE WEBER 40 IDF's |
Matt Biscotti wrote: |
BRIAN:
But what is your timing at idle?
And what is your elevation?
Yes, the small holes in the top of the carb that lead to the idle jet drilling. I think I drilled my last ones to 125, but I would get the timing dialed in before you start drilling. _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
oprn Samba Member
Posted: Wed Jun 25, 2025 1:19 pm Post subject: Re: CHINESE WEBER 40 IDF's |
Fender38 wrote: |
oprn wrote: |
Brian_e wrote: |
Really??
Ah! My bad! _________________ Our cars get old, we get old but driving an old VW never gets old! |
