kpf Samba Member
Joined: March 01, 2017 Posts: 1060 Location: California, US
Posted: Tue Jul 02, 2024 4:59 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
How is the outside of the fuel tank completely rusty?
_________________ 1971 Super Beetle |
Busstom Samba Member
Joined: November 23, 2014 Posts: 4579 Location: San Jose, CA
Posted: Tue Jul 02, 2024 5:39 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
kpf wrote: |
Maybe from years of leaking fuel out of the fuel gauge sender cover, which it's apparently still doing to this day...imagine the smell  _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
cory464 wrote: |
if you aren't perfectly centered in the hole you will have issues when you tap it. |
consvws  Samba Member
Joined: April 07, 2009 Posts: 1002 Location: Roseburg, OR
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2549 Location: Seekonk,Massachusetts USA
Posted: Wed Sep 25, 2024 8:33 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
APPLEGREENVW wrote: |
Local to me. $16k For a 73 Sport Bug, with the black decal blocking the rear grill below the rear window.  |
Almost deserves a spot in the abortions thread. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
cory464 wrote: |
Posted: Thu Sep 26, 2024 12:41 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
Busstom wrote: |
Almost deserves a spot in the abortions thread. |
 _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
vamram  Samba Member
Posted: Wed Oct 16, 2024 2:40 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
I've seen this in person, it's not as bad - not quite - as it appears at first site
https://bringatrailer.com/listing/1976-volkswagen-beetle-8/ _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79494 Location: Sneaking up behind you
Posted: Fri Nov 08, 2024 7:07 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
I'm rebuilding a FI engine and converting it to carb. I needed to replace the FI breast plate (no heat riser and too many holes), to one with heat riser and 2 fresh air holes. So I bout an aftermarket one and the 2 small tins to cap off the heat risers.
Wheat I got was a breast plate with cutouts for the hear risers but no wrap around to connect the 2 small tins.
Can't they even produce a exact copy of of the sheetmetal, not like it's rocket science
This has the correct parts.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2042 Location: Wichita, KS
Posted: Fri Nov 22, 2024 1:09 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
Brand new Beru coil, purchased from Rock Auto back in June of this year — malfunctioning right out of the box.
Once installed, was experiencing lots of engine misfiring when cold - barely able to hold an idle. Once engine warmed up a bit, started running a little smoother but still experiencing mis-fires, even after fully warmed up.
Swapped back in the old Bosch blue coil (Brazilian) to compare, and it worked flawlessly - engine running completely smoothly w/ no mis-fires when using that one, both cold and warmed-up. Went back and forth between the two a couple times (just to make sure I wasn't missing something, and/or maybe knocked something loose), but got the same results each time -- old Bosch worked fine, but new Beru caused lots of mis-firing & hesitation.
So “caveat emptor” on the new Beru coils, sadly (at least for me)…
_________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
vamram  Samba Member
Posted: Tue Feb 11, 2025 10:25 am Post subject: Re: Official whine about Late Model/Super and parts for sale |
Here's a nice looking exhaust "designed" by JBugs. Comes already painted w/a heat resistant coating, not cosmoline or cheap transport rust protective paint, and correctly plumbed for working pre-heat. I *really* wanted the sound promised by its fatter-than-pea-shooter stainless steel tips. You'd think at my advanced age, delayed gratification and trusting your hunches would take over the impulse to buy. Alas, not so.
As usual w/a muffler, everything is left loose during the initial mounting in order to be able to line up all of the ports, pipes and heat risers. That done, I started tightening things down.
- the muffler's pipes for the #2 & #4 ports were far enough out-of-whack that I was unable to re-tighten down the #1 & #3 connections of the heat exchangers flush against the heads, resulting in massive and loud exhaust leaks.
- the nicely built heat riser pipe on the 1-2 side extends straight out toward the front much more than stock before curving right, and prevents re-installing the stove pipe tin for the carb pre-heat.
So...I removed it and yesterday reinstalled the factory style muffler & pea-shooters. Live and learn$.
Can be yours for a steep discount if you have the tools and patience to beat it into shape! _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 860 Location: Ontario, Canada
Posted: Tue Feb 18, 2025 2:10 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
vamram wrote: |
Can be yours for a steep discount if you have the tools and patience to beat it into shape! |
Too bad the stove pipe doesn't fit. I just bought this with high hopes of using it. Preheat isn't absolutely critical for me. I'll give it a try. _________________ 74 Super
84 Westy |
vamram  Samba Member
Posted: Tue Feb 18, 2025 2:16 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
boxer74 wrote: |
Too bad the stove pipe doesn't fit. I just bought this with high hopes of using it. Preheat isn't absolutely critical for me. I'll give it a try. |
The stove pipe for me was a problem, but running the heater hose from the shroud to the heat exchanger was a bigger issue. I *must* have working heat.
Thinking about the installation, it's possible the issue I had w/the exhaust leaks at the #1 & 3 ports *may* have been due to me tightening the muffler to heat exchanger clamps before the #1 & 3 exhaust nuts. But that's just speculation, and the preheat issue was a big deal for my setup.
Hope you have better luck! It is a very nice looking exhaust and the finish seemed excellent.
Oh, and to JBugs' credit - they gave me a full refund RMA for it even though I had opened and installed it. _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
PiperFixer Samba Member
Posted: Mon Apr 21, 2025 6:23 am Post subject: Re: Official whine about Late Model/Super and parts for sale |
After a year of ownership and lots of parts thrown at the car, I finally got something that was not perfect.
New 'heavy duty Dansk' muffler from a place in Western Canada (whom I've had zero problems with before tbh.) Could not get the right heater tube attached for the life of me. Fought it and fought it, bending and prying for a good while. Finally got one of the two bolts threaded. The last bolt hole was about 2mm off and I ended up reaming it and putting a regular bolt through with a lock nut. Works fine but what a pain. _________________ Orange 72 Super
A&P IA |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33083 Location: Hot Arizona
Posted: Mon Apr 21, 2025 7:07 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
New chinese coupler was not large enough to go over the shift rod. I used its bushings in the original coupler. How hard would it be to copy an original one???????
For my 1998 Frontier, the replacement (only one available) protruded 5.5 mm too far into the compressor and wouldn't seal; at least the O-ring channel was in the right place, and I shortened the fitting to match the factory one.
No one in China can compare to an original part side-by-side????????????????
On the other hand: I can't figure out if being a police sketch artist in China is the world's easiest job, or the most difficult !!!!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
vamram  Samba Member
Posted: Wed May 14, 2025 4:06 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
Ok, not a rant. But WOW!!!! I don't wanna hear any rat-rodder raggin on Supers!!!
https://bringatrailer.com/listing/1972-volkswagen-...gn_3530296 _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71522 Location: Phoenix 602
vamram  Samba Member
Posted: Wed Jun 25, 2025 12:12 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
The rare "sportier" version!
https://www.thesamba.com/vw/classifieds/detail.php?id=2734293 _________________ "Men are qualified for civil liberty in exact proportion to their disposition
Click to view image
Save the Supers!! |
Cusser Samba Member
Posted: Wed Jun 25, 2025 2:54 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
Apparently his sportier version has "new tie-rod bearings installed". My VWs don't even have tier-rod bearings !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
finster Samba Member
Joined: May 26, 2012 Posts: 10027 Location: not far from the madding crowd
Posted: Thu Jun 26, 2025 6:27 am Post subject: Re: Official whine about Late Model/Super and parts for sale |
a 79 cabrio 1303 with 3.5 miles on the clock for sale by auction in uk. currently at £46,500 and the reserve is near... is it worth it? what do you do with it, just look at it and polish it? disconnect the speedo and drive it?
https://www.carandclassic.com/auctions/1979-volksw...new-n9oXz8
_________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
CoastalBug Samba Member
Posted: Sat Jun 28, 2025 10:45 pm Post subject: Re: Official whine about Late Model/Super and parts for sale |
I can play! Even being a beginner.
If the 21 millionth Beetle rolled off the line in 2003, then how is this 1970 a "21 Million Edition?"
https://www.facebook.com/share/1BemgDeaXc/ |
