Air Cleaner to Carburetor Tube Crummy Mold
BarryL Premium Member
BarryL is offline
PostPosted: Sat Jun 14, 2025 6:08 pm    Post subject: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Anyone bought one of these lately? This one I bought from WCM since they supposedly make the best “they themselves would use”. They are unusable as shipped.
Horrible flashing on all four mold seams.
So horrible I can’t imagine what damage the flashing would cause to the carburetor much less when it goes into the combustion chambers if it makes it past the valve seat. Three hours so far delicately scraping to get to this point.
At the bellows it is impossible to deflash the ribs. I don’t know how I’m going to get the flashing gone.
This is but a tiny fraction of flashing removed from the tube.
Total sheesh.
sub-hatchtim
sub-hatchtim is offline
PostPosted: Tue Jun 17, 2025 11:45 am    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Tbh if that stuff flaked off doubt it would cause damage
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
campingbox Premium Member
campingbox is offline
PostPosted: Tue Jun 17, 2025 5:49 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
I’m no engineer, but I can’t imagine a thin sliver of rubber would do much to the valve or the valve seat.
I’ve bought those new before and I’m not sure how they compare to yours - I haven’t really paid much attention to the casting flashing, but I fully support you deburring it. Is it flexible enough to be rolled inside out?
BarryL is offline
PostPosted: Tue Jun 17, 2025 6:33 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Impossible to turn inside out.
All I want going down the throat of my engine is clean air blended with atomized 91 octane gas.
70bus Premium Member
70bus is offline
PostPosted: Tue Jun 17, 2025 6:36 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
At least the gas and that flashing are from the same source!
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
PostPosted: Tue Jun 17, 2025 7:07 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Molding Reply with quote
I wonder how flexible it would be after boiling it in hot water?
Regardless I’m looking forward to seeing the flow bench specs - before and after.
BonTonRoulet
BonTonRoulet is offline
PostPosted: Wed Jun 18, 2025 1:09 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
A long stem fireplace/grill lighter would take care of the flashing on the inside of the tube if it bothers you that bad?
Never argue with an Idiot. They'll only bring you down to their level and beat you with experience.
Wade
Wade is offline
PostPosted: Wed Jun 18, 2025 1:39 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
It doesn't seem like a big deal at first glance, but I agree with the OP. For the same reason I don't use silicone gasket maker between my engine case halves, I wouldn't want this stuff floating around in my engine. I can only imagine the oil passageways it could clog up and the oil pressure issues that could result.
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Jun 18, 2025 3:30 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Any pieces of rubber that got by the piston rings would be super tiny. Also if one is running a quality oil filter pump, that is going to remove any tiny pieces of rubber and all the usual much bigger bits and pieces of metal shavings that do happen all the time in these engines.
In Stereo, Where Available!
BarryL is offline
PostPosted: Wed Jun 18, 2025 6:34 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Will try that.
BarryL is offline
PostPosted: Tue Jun 24, 2025 6:30 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
BarryL wrote:
Will try that.
Well, I tried it. My lighter is adjustable so I put it on med low about a 1/4" flame head. I bent the tube so I could see the bellows' flashing.
I was hoping it would shrink away like the shy girls at the Junior High dance but no. The flashing wasn't phased and merely caught smokey. It made my nostrils and throat feel like someone sprayed poop scented surfboard wax on it.
Any higher flame would have melted right through the wall thickness. I'm going to try to find another supplier.
Found it at VW Heritage
https://www.heritagepartscentre.com/us/211129627-remote-air-cleaner-to-carburetor-hose.html
How hard is it to get into the USA?
70bus is offline
PostPosted: Tue Jun 24, 2025 7:35 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Was made here. There probably is a US supplier.
Craig K
70 Neunsitzer
65 Pritschenwagen
HMVWNAB
HMVWNAB is offline
PostPosted: Wed Jun 25, 2025 5:06 am    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Did you consider a Dremel tool with sander bit, provided you can reach the flash in question?
BarryL is offline
PostPosted: Wed Jun 25, 2025 6:15 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
I did try that but the flashing becomes blind as soon as the tool approaches.
I tried it on the easy stuff at first but it was too hard to control even on low. What worked for the parts already done was a large rough rat-tail file with a squared off ending that was sharp and I could slide it lengthwise over and over not as a file but as a sharp pushing blade thingy.
BarryL is offline
PostPosted: Thu Jun 26, 2025 3:03 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Finally...I thought maybe if I beat on the bellows with a toilet plunger handle I could knock the flashing free and if it didn't fall out then I'd just put it on as was.
I beat it within an inch of its life but nothing came loose.
Then I realized I could squish the bellows to use my sharp file trick.
It was majorly hard to squeeze but I figured get it over with then recover from the injury.
Out of focus but you can see each flash seam had to be squished one cm at a time.
This is the combo that worked.
It took 6 hours. Just to teach it lesson I beat it with the stick again.
BarryL is offline
PostPosted: Fri Jun 27, 2025 11:35 am    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Anybody know which way the tube goes? Is it bellows to air cleaner or bellows to carburetor?
Edit never mind I saw this.
Eric&Barb
PostPosted: Fri Jun 27, 2025 12:06 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
Those ribs in the tube are for stress/flex relief due to the vibration of the engine. So better closer to the carb. One can just use a hose for that, but then the vibration against the carb and air cleaner can cause cracking of metal parts.
DanM
DanM is offline
PostPosted: Fri Jun 27, 2025 4:05 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
BarryL wrote:
It took 6 hours.
put down the pipe! (literally). Laughing
BarryL is offline
PostPosted: Sat Jun 28, 2025 6:14 pm    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
In The 63-67 Bentley section K-2 page 15 it shows two more photos with the bellows left.
Chuey
Chuey is offline
PostPosted: Tue Jul 01, 2025 10:11 am    Post subject: Re: Air Cleaner to Carburetor Tube Crummy Mold Reply with quote
A wire wheel as in the ones you can spin in a drill motor would knock loose any inner flashing that would be loose enough to *ever* come out. An extension shaft may need to be procured or devised.
I know you got it done but in case this is searched, this would be a “sub 6 hour” process.
Chuey
