Throttle lever setting?
CoastalBug
CoastalBug is offline
PostPosted: Sat Jun 28, 2025 4:32 pm    Post subject: Throttle lever setting? Reply with quote
I’ve searched and watched and googled but I can’t find much information on this part. I believe it’s called a throttle lever according to what I’ve been able to learn. IF this thing is closed at startup, my engine will flood. If it’s open it will start right up. What’s the proper adjustment and where should it be on startup, and running?
liquidrush
liquidrush is offline
PostPosted: Sat Jun 28, 2025 4:40 pm    Post subject: Re: Throttle lever setting? Reply with quote
That's the fast idle cam. There should be a choke thermostat on the opposite side of it. Sounds like you need to adjust it. When adjusted properly it'll start up on fast idle and as the choke thermostat warms up the cam will drop down to normal idle speed.
CoastalBug
PostPosted: Sat Jun 28, 2025 4:58 pm    Post subject: Re: Throttle lever setting? Reply with quote
thanks! Off to google adjustment procedures.
rayjay
rayjay is offline
PostPosted: Sat Jun 28, 2025 5:06 pm    Post subject: Re: Throttle lever setting? Reply with quote
https://www.youtube.com/watch?v=dTSekv82ZMQ&t=66s
CoastalBug
PostPosted: Sat Jun 28, 2025 5:15 pm    Post subject: Re: Throttle lever setting? Reply with quote
Thanks Ray.
Now I'm wondering if it really was the trailering, or if *I* actually flooded the engine when we got home. I pumped the accelerator before I knew they actually didn't need that. Because when my engine is cold, and you hit the accelerator, the lever actually goes ALL the way down and the butterfly is completely closed. cutting out most if not all the air to the carb.
rayjay
rayjay is offline
PostPosted: Sat Jun 28, 2025 7:21 pm    Post subject: Re: Throttle lever setting? Reply with quote
You are doing it correctly. You give the pedal a pat to allow the fast idle cam to set to the cold start position. This also gives a shot of gas out of the accelerator pump to help prime the cylinders. Then hit the key an the motor should fire right up and idle fast. Another pat on the throttle allows the choke pull-off diaphragm to pull the fast idle cam to a lower rpm setting.
For the summer time I would adjust the choke bimetal coil so that the choke butterfly has about 1/4'' of air gap. Adjust the fast idle to about 1200 rpm. This all takes some tinkering to find out what your combination needs to give you fast starts but not be prone to flooding. You also have to experiment with starting techniques.
I would also check the fuel level in the bowl to make sure it's in spec. It sounds like it may be a bit high which makes it easy to flood the engine.
Don't get exasperated. Nobody is born knowing this stuff. Step by step.
CoastalBug
PostPosted: Sat Jun 28, 2025 7:24 pm    Post subject: Re: Throttle lever setting? Reply with quote
I was wondering about this. I bought this car from an hour north of Ft Worth, and I live about 10 miles off the Gulf on the coast. I was curious to know if ambient air temp means I am going to have to adjust the choke seasonally.
And there's NO gap whatsoever if you hit the gas pedal and set the choke. It goes to completely closed. So I definitely need to adjust it.
Alstrup
Alstrup is offline
PostPosted: Sat Jun 28, 2025 11:54 pm    Post subject: Re: Throttle lever setting? Reply with quote
The butterfly control screw looks to be in way too much
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
CoastalBug
PostPosted: Sat Jun 28, 2025 11:57 pm    Post subject: Re: Throttle lever setting? Reply with quote
It's ALL the way in. That's how it was when I picked it up on Thursday. I haven't turned a single screw in that engine yet.
rayjay
rayjay is offline
PostPosted: Sun Jun 29, 2025 6:09 am    Post subject: Re: Throttle lever setting? Reply with quote
Your car has a lot of POP!!!!
Prior
Owner
Problems
Buy the Bentley manual if you didn't get one with the car. Then start going through the car one end to the other. First is the carb. Then the distributor. Then adjust the valves. Change the oil. Inspect the entire brake system. Normal stuff on any used car.
CoastalBug
PostPosted: Sun Jun 29, 2025 9:51 am    Post subject: Re: Throttle lever setting? Reply with quote
Prior
Owner
Problems
Haha! First time I’ve heard that one!
I bought the John Muir bible. I’ve only owned it for three days now so I’m going to start adjusting the engine tomorrow on my day off. Engine and brakes are my first tasks!
jinx758
jinx758 is offline
PostPosted: Sun Jun 29, 2025 10:04 am    Post subject: Re: Throttle lever setting? Reply with quote
Disconnect NEG of coil
Air cleaner off
Key on
Amount of time needed for choke to fully open -
3 to 5 minutes (3=summer & 5= winter)
Adjust accordingly
THEN set fast idle cam screw
unscrew the PO's "screw up"- off the cam
screw should JUST touch cam then 1/4 turn, no more
DO NOT TOUCH AGAIN
Fuel, air, & idle are done using the screws on left side of carburetor
Works for :
30PICT/3, 30PICT/4, 31PICT/3, 31PICT/4, & H30/31
Reader ? Samba search
Visual ? U-tube search
TONS of info out there !
Good luck ... stay safe
jinx
" It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor
CoastalBug
PostPosted: Sun Jun 29, 2025 10:10 am    Post subject: Re: Throttle lever setting? Reply with quote
jinx
Thanks! I watched a BUNCH of carb adjusting videos last night. I believe this is an aftermarket carb. I hope to replace it with an original Solex as soon as I figure out which one this engine actually came with.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sun Jun 29, 2025 11:13 am    Post subject: Re: Throttle lever setting? Reply with quote
Coastal as a 68 US market car that probably originally had a solex 30 pict-2. If it was a California car it might have been different. That being said since it is still a single port head car you could use the stock carb from a 67 bug which was a 30 pict-1 with 105-1 stamped into the base. I have used many of these over the years and have found it to be a simple and trouble free carb once you set it up correctly. There is a guy in the Pacific Northwest who can rebush and rebuild these for you. Some of the other members will tell you who that is. Good luck Bob
jinx758
jinx758 is offline
PostPosted: Sun Jun 29, 2025 11:46 am    Post subject: Re: Throttle lever setting? Reply with quote
Coastal ...
Awesome on the research !
I've watched a few for setting up/using a manometer (water in hoses & bottles to sync multiple carburetors as a few car club members have duals). Doesn't apply here tho.
A couple of them were useful to figure out if lean or rich. These were for tuning motorcycle carburetors - think about releasing the throttle grip & it slams shut. All should return to a steady idle without lagging or stalling.
Some on U-tube have no clue what they're doing.
Had to replace the ignition in my '04 honda pilot. It has 2 safety screws (heads break of after torquing). Dude paused video saying it took almost an hour. I figured it out in about 15mins.
You can tell who has experience & who is just posting cuz they did it once so be wary.
jinx
PS :
In Tx the choke adjustment can be minimal but it'd be different between Amarillo & McAllen. I close mine a little bit for Dec & Jan but I'm outside San Antonio so fairly temperate.
On a "cold" engine I always press go pedal once, turn key, & drive away. These systems are made to get you places & are very reliable when set up correctly. You should not have to wait - unless the choke is wired open or if something is amiss.[/vimeo]
1971 Standard Bug
1776cc dual port
034 distributor
oprn
oprn is offline
PostPosted: Sun Jun 29, 2025 3:39 pm    Post subject: Re: Throttle lever setting? Reply with quote
Adjusting the choke seasonally is mandatory here.
One of the few things I take issue with in the "Keep your VW alive" book is John's opinion and treatment of the choke. He is completely out to lunch on that issue! If I could reach back through history I would grab him by the bong and drag him and his chokeless car up here to Canada in the dead of winter and video him trying to get it started! It would be hilarious!
CoastalBug
PostPosted: Sun Jun 29, 2025 4:25 pm    Post subject: Re: Throttle lever setting? Reply with quote
It was sold to me as a 1500, but I believe I just discovered that the engine is a 1600 from 1970. The engine number is B6292404, and according to Jbugs, B6 is a 1600 dual relief single port from 1970.
Looks like the forum technical pages agree. Looks like it was built in Dec '69 for the '70 model year.
Bobs67vwagen
PostPosted: Sun Jun 29, 2025 4:49 pm    Post subject: Re: Throttle lever setting? Reply with quote
That was a good motor I had one brand new. That came with a 30 pict-3 originally. The pict 1 and 2 both fit that intake.
