Subaru EJ25 Shortened Oil Pan Options
Page: 1, 2, 3  Next
MSGGrunt
MSGGrunt is offline
PostPosted: Mon Jun 30, 2025 11:31 am    Post subject: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Opinions and options on the shortened oil pans out there? My needs mean no off-roading. Aluminum cracks where metal bends, so metal would be easier to repair, but I feel this is a low priority. I am not sure I like the idea of a reduced capacity.
Van cafe
https://vancafe.com/subaru-conversion-shortened-oi...yCvaXGKF7c
Small Car Performance.
https://smallcar.com/ej22-ej25-subaru-conversion-5...gm-Nq5EbvC
Burley appears to be out of stock
https://burleymotorsports.net/product-category/subaru-conversions/subaru-oil-pans/
Specialized Parts, also out of stock.
https://www.specialisedparts.com/product/high-capa...mOu8L7RNS-
Kdj
Kdj is offline
PostPosted: Mon Jun 30, 2025 12:05 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
By no means a subaru expert. But the simple fact that the Van Cafe has baffles and a pick-up that seem like they were designed to work together would do it for me.
Franklinstower
Franklinstower is offline
PostPosted: Mon Jun 30, 2025 3:44 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
there is some good research out there why Subaru changed the design of their oil pans, windage trays and pick up tubes. I think Killer B has some videos why the changes were necessary. It boils down to even the stock pans (before they changed design) had oil starvation issues. And in my opinion, it is even a bigger issue in a vanagon constantly running at higher RPM's and angles when off roading etc.
I am really surprised we don't have better options for shortened, hi capacity oil pans.
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
dmaynes
dmaynes is offline
PostPosted: Mon Jun 30, 2025 3:55 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
https://www.north-westy.com/product/north-westy-high-capacity-oil-pan-for-subaru-conversions/
Requires the Notth Westy engine mount
87 Syncro Westfalia
MSGGrunt
MSGGrunt is offline
PostPosted: Mon Jun 30, 2025 4:02 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Well, I already bought Van Cafe's engine mount, so that's out. I looked at Van Cafe's oil pan and I like the concept. And given it is designed for the EJ25 swap into a Vanagon I would expect their exhaust would not interfere. Or have one custom made locally.
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Jun 30, 2025 5:02 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
The oil pan is cast from high-quality, locally sourced aluminum to ensure superior strength and durability.
Can I buy this at the Saturday morning farmers market? Laughing
Franklinstower
PostPosted: Mon Jun 30, 2025 6:19 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Another oil pan with no baffles, just like small cars...
No thanks!
Good info here
YITB
MSGGrunt
MSGGrunt is offline
PostPosted: Tue Jul 01, 2025 2:49 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Seems the Van Cafe pan is the best overall design? Retains the factory capacity and they say internally baffled with shortened dip stick and pick up.
Or if I am not worried about clearance run the newer style pan.
Crooked Designer
Crooked Designer is offline
PostPosted: Tue Jul 01, 2025 6:10 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
It’s made from 100% locally sourced Bud Light cans.
'85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
a914622
a914622 is offline
PostPosted: Tue Jul 01, 2025 7:23 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Dry sump system!!
All kidding aside, not sure why these pans are being made with out windage and baffles?? I remember seeing a video of the new Porsche engine being run on a dyno that simulated the conditions of the Isl of Mann. The engine was rotating and twisting almost upside down to simulate the G forces.
Not the same race conditions but the sloshing in a vanagon has to be happening.
Jcl
87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru
Franklinstower
PostPosted: Tue Jul 01, 2025 7:29 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
a914622 wrote:
Dry sump system!!
Jcl
The ultimate solution-better oil scavenging and clearance:
https://www.rallispec.com/eng_opu_rcm2668.html
YITB
4Gears4Tires
PostPosted: Tue Jul 01, 2025 7:40 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
This pan's for you!
Jake de Villiers
Jake de Villiers is offline
PostPosted: Tue Jul 01, 2025 11:18 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
I've been running the Outfront Motorsports shortened pan and pickup for over 85,000 miles with zero issues.
I went with those guys because they build reliable 500HP+ race motors and would seem to know what they are doing! Very Happy
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
shagginwagon83
shagginwagon83 is offline
PostPosted: Tue Jul 01, 2025 12:41 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Same here. I asked them to modify a new oil pan for a couple of bucks extra.
Instagram: @joannthevan
MSGGrunt
MSGGrunt is offline
PostPosted: Tue Jul 01, 2025 4:45 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
If you are not off-roading is there that much of a risk of hitting something with a stock pan? I am thinking the upgraded, 2009 and newer, OEM pan with the corresponding dip stick, dick stick tube, baffle and pickup can be had for under $200.00
syncrodoka
syncrodoka is offline
PostPosted: Tue Jul 01, 2025 5:24 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
I have heard of owners backing into a parking spot and punching a hole into the oil pan on a parking block. Think
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Jul 01, 2025 8:13 pm    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Zanzinger in Germany Cool
shagginwagon83
PostPosted: Wed Jul 02, 2025 8:05 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
https://www.zanzinger-automobiltechnik.de/LMB-OElwanne-gekuerzt-fuer-Subaru-EJ-Motoren/010-049
Their oil baffle kit -
https://www.zanzinger-automobiltechnik.de/OEl-Schwall-Blech-Kit-passend-fuer-Subaru-EJ/010-011
dobryan
dobryan is offline
PostPosted: Wed Jul 02, 2025 8:16 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Wonder what the depth dimension of their pan is?
Dave O
The Western Syncro build
skemems
skemems is offline
PostPosted: Wed Jul 02, 2025 8:35 am    Post subject: Re: Subaru EJ25 Shortened Oil Pan Options Reply with quote
Description says its 60mm reduction in height from stock pan.
Seem to be similar to the outfront motorsport pan (cut and welded) with fins for heat dissipation. Capacity is only 3.75L. Would not be my first choice.
87 VW Westfalia - EJ25
86 VW Westfalia - EJ22
85 VW Westfalia - WBX 2.1 project
Page: 1, 2, 3  Next
