.030 and .040 Under Crankshafts
satterley_sr
satterley_sr is offline
PostPosted: Tue Jul 01, 2025 2:33 pm    Post subject: .030 and .040 Under Crankshafts Reply with quote
Is there any downside to using rod journal cranks reground to third or fourth cut in high performance applications (6000 rpm plus]?
DDC racing
Brian_e Premium Member
Brian_e is offline
PostPosted: Tue Jul 01, 2025 2:43 pm    Post subject: Re: .030 and .040 Under Crankshafts Reply with quote
Smaller diameter means less surface speed at the bearing. A good thing for higher RPM.
Thicker bearing shells aren't terrible.
Downside would be loosing surface heat treat depth. Just like a case that has been line bored 3-4 times, it might have other hidden issues from a previous hard life.
Brian
So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts
