Camper interior build on a 64 Kombi
Page: Previous  1, 2, 3 ... 26, 27, 28
sgellis
sgellis is offline
PostPosted: Fri Aug 30, 2024 10:50 am    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Added an electric water pump. Had one laying around so put it in. Installed a small waterproof switch that is not really noticeable behind the hand pump.
Old hand pump still works but the electric pump is much less work and I can fill the coffee pot in the morning without waking up the wife. Smile
The pump is not self priming. Works great when the tank is full but starts loosing prime when at 1/3. I may get a self priming pump to try but I am not sure the hand pump will still work. Also concerned they will be loud.
I tried to find a check valve to keep it primed but they all have too strong of a spring for the pump.
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
BarryL Premium Member
BarryL is offline
PostPosted: Fri Aug 30, 2024 6:20 pm    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Supposedly one way the handle lays is "keep prime" while the other way is "drain back" for freezing temps. Is yours like that and still losing the prime?
sgellis wrote:
Switched out the AGM battery for an 100 ah LiFePO4 group 24]
Is the Lithium Iron battery about $700?
sgellis
sgellis is offline
PostPosted: Sat Aug 31, 2024 3:00 pm    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Possibly. The hand pump is not working great so I need to take it apart and see. It has always drained back but that could just be poor quality.
Got my battery on sale for under around 300. It is a LiTime from Amazon. They are good quality but lower price. Some of the brand name ones are over priced.
markham56
markham56 is offline
PostPosted: Wed Feb 19, 2025 4:26 pm    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
nlorntson wrote:
Install the usual springs that sit between the door and the back of the wooden panel and you should be fine I'd think.
How was this done at the factory? I'm replacing my old panels and this large gap just doesn't seem normal. I bought some springs from WW but they're not nearly strong enough.
sgellis
sgellis is offline
PostPosted: Sat Feb 22, 2025 2:41 pm    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Original panels were quite soft so the springs would keep them snug to the escutcheons.
sgellis
sgellis is offline
PostPosted: Tue Jul 01, 2025 4:48 pm    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Small upgrade to the solid state fridge today.
I wanted to move one fan from the cooler to the exhaust duct to improve efficiency exhausting the warm air. Also seems like a waist of good heat when the weather is cold so added a diverter flap to allow exhausting air behind front seat. I was planning to put a servo control to automate it with the heating system but didn't get around to ordering the parts. So a rod and knob on vent holds the flap in ether position. It will be awhile before we can test it in cold weather. I am curious how much difference it will make. The bus is quite well insulated and holds its heat.
The duct is printed out of PLA. It may not like the heat and I have a few tweeks to the design so will likely reprint it out of PETG and add the servo.
Also added a magnetic switch so it will notify me if the fridge drawer is not closed but will likely change that to a mechanical switch so I can tell if it is fully latched. Magnetic switch can not be set accurately enough.
I reinstalled the back panel with aluminum tape but plan to make a removable insulating panel for the back for maintenance and upgrades.
sgellis
sgellis is offline
PostPosted: Tue Jul 08, 2025 6:00 am    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Moving the fan resulted in a massive increases in efficiency. We just did a 800 mile 5 day trip and fridge stayed in the 2 to 4c range. On one night stays the bus would set 18 hours without any solar. After the 100 ah battery was still at 13.2v.
On the two night stay bus set for 42 hours with 3 hours of evening solar (maybe 200w gained) the battery was at 12.9v
I did notice the fridge did not cycle off when outside temp reached 30c and on low power mode. if the outside temp rises over 30 the fridge temp will start to rise unless I let it run in high powered mode when on battery only.
Solid-state fridges are quite inefficient compared to a good compressor fridge but they are cheep, light and compact. I am quite happy with this performance in the relatively hot weather we had.
Now I will improve the seals, do a few tweaks and tidy up everything.
harrywt
harrywt is offline
PostPosted: Sun Jul 20, 2025 11:36 am    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Have you ever posted the CAD files for the cabinets? I found your work that you posted on GrabCAD but I didn't see the cabinets
sgellis wrote:
What I am planning will be sort of a standard layout with the addition of a small cabinet in the left front. The bench seat will fold out into a bed. Upright cabinet on right rear. Custom fridge on right front with solid-state cooling. The electrical will be in the bottom front of the left front cabinet.
This are not quite current but close.
sgellis
sgellis is offline
PostPosted: Sat Jul 26, 2025 6:18 am    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
I haven't. I will share what I have to my grabcad. Camping in this thing so will get to it when we get back home.
The cad doesn't match exactly to what I built but is a good start.
Will update here when it is up.
sgellis
sgellis is offline
PostPosted: Mon Jul 28, 2025 5:49 am    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Uploaded the original cad drawings to grabcad. DO NOT USE DRAWINGS AS IS. Cabinets were modified/tweaked as I built the interior. I made patterns to fit parts to the chassis. These drawings are a good start but will not fit good enough to use.
https://grabcad.com/library/64-vw-camper-interior-1
For clarification I have two grabcad accounts. One for my personal stuff including this and another account just for my Nova Scotia Barndoor YouTube channel.
https://grabcad.com/the.nova.scotia.barndoor-1
sgellis
sgellis is offline
PostPosted: Mon Jul 28, 2025 6:15 am    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Had a chance to test the new fridge vent diverter.
Saturday night it was down to 13c outside so I switched fridge vent to inside. Bus was 19.7c in the morning so was some help. I estimate the interior stayed 2c over what it would have been without. Not much but was the difference between comfortable and chilly.
I have all the parts to automate the flap. Maybe I will get that done for next year.
junichi
junichi is offline
PostPosted: Mon Aug 04, 2025 1:01 pm    Post subject: Re: Camper interior build on a 64 Kombi Reply with quote
Just dropping in to say I used your drawings to make up my interior panels and they are amazing and spot on! In fact, they were so accurate I had to trim for the kilmat I had on my wheel arches. There are other posts on here looking for interior panel templates. I will post some links to your thread. These should be in a sticky or tech section somewhere if they are not already. Thank you again and amazing work on the drawings, and more importantly your amazing interior! Inspirational!
1964 Kombi- http://www.thesamba.com/vw/forum/viewtopic.php?t=640048
Sold: 1985 Transporter Doka,1978 Westfalia, 1975 bay x 2, 1986 syncro vanagon, 1965 beetle, 1980 vanagon, 1967 deluxe bus, 1988 golf
Page 28 of 28
