Engine/Transmission removed where and how would you start?
Page: Previous  1, 2, 3 ... , 11, 12, 13  Next
poundman
poundman is offline
PostPosted: Wed Jul 02, 2025 6:27 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
@SGKENT thanks for the detailed response. Good luck with surgery. I pray it all goes well.
Restoring a 1972 Bay Window Bus that has not be registered for the road since 1981.
Sugar Land, Texas
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jul 02, 2025 7:02 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
they rescheduled it. I am home waiting for a call for a new date. Doctor was up last 24 hours on emergency surgeries and we thought it best to do it when he was fresh rather than risk an error if he was tired. So here I sit. But there is always a reason for things. Thank you for the best wishes. Live is so fragile. Yesterday my nurse for preop went to lunch while they were pulling blood, doing pre op tests. When she came back she was off, I could tell. I asked her if all was Ok and she was not. She eventually was Ok but while at lunch they found out her father in law's cancer that was in remission has come back and gone to the brain. So life is so fragile. They told me this morning that she would be in shortly to get me ready and I told them she probably took the day off. When they checked, yep, she took the day off. I would too. So then the doctor came in a couple minutes later and let me know he had been up 24 hours +. Seemed wise to just postpone until everyone is 100%. Just like working on a car. Don't dive in if you aren't 100% up to the task for lack of sleep or emotional strain. I am so anal when it comes to working on things because it is just too damned easy to miss a step, or do it and second guess later if one did it right. Take lots of photos. They are great to refer back to later.
Clatter
Clatter is offline
PostPosted: Mon Jul 07, 2025 8:25 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
You keep asking questions that are in the build thread in my sig.
Why not just read it?
I know it’s long and wordy, but there’s a few bits in it…
Bus Motor Build
It does not exist!
poundman
poundman is offline
PostPosted: Sat Jul 12, 2025 8:33 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Thanks Clatter, I have skimmed thru the thread.
Update:
Question, I am putting the engine back together, enough to get it test running on the bench. What engine tins do I need to get on before other parts to avoid undoing something. I did get the bottom deflects that are under the tubes, but I think there are a few more than should be fitted.
I did some test fits today and determined the tin between cylinder 4 and oil cooler is the only one that is hard to get in with cooler in place. I will put that one in before I install cooler it is #3 in diagram.
PS. I left out the metal shims between head and jug, I think was advised by a few people. This might increase compression a little. Shim under the jug remains because I did not remove the jugs.
Another question, I can remember where this tin goes.
Sugar Land, Texas
poundman
poundman is offline
PostPosted: Sat Jul 12, 2025 5:28 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Another odd question, any better way to remove these rivets beside just drilling them out? They hold the tray below the insulation above the engine. I am fitting a engine hatch and need to remove the old tray before I start.
Sugar Land, Texas
busdaddy
busdaddy is offline
PostPosted: Sat Jul 12, 2025 6:15 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
3/16" drill, there is no other option.
Слава Україні!
poundman
poundman is offline
PostPosted: Sat Jul 12, 2025 7:32 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Someone mentioned using sealant on push rod o-rings, something with teflon which I can't seem to find. What about one of these?
Sugar Land, Texas
lil-jinx
lil-jinx is offline
PostPosted: Sun Jul 13, 2025 6:54 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
RTV silicon sealant is the proper thing to use,just a very thin coat ,it will lubicate the ring for easy install and it will help with the sealing.teflon provides a anti friction property,and it may not stick to a silicone oring,non stickiness is also a property of teflon.
1968 Dune Buggy sold dec 2024
1974 parts bus
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sun Jul 13, 2025 9:36 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Type 4 pushrod tube seals with engine oil or non-hardening sealant only. No way I’d let RTV near mine.
Robbie
www.airschooled.com
busdaddy
busdaddy is offline
PostPosted: Sun Jul 13, 2025 10:49 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
X2, they have to be able to move.
I use grease, and polish the bores in the heads so they slide smoothly.
Слава Україні!
Wildthings
Wildthings is offline
PostPosted: Sun Jul 13, 2025 11:28 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Teflon pipe thread sealant works very well for this job. Since its a lubricant it makes the tubes slide into place very easily thus greatly lowering the chance a seal will be pinched and cut as you push the tube into place in the head.
lil-jinx
lil-jinx is offline
PostPosted: Sun Jul 13, 2025 11:38 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
i was going by what is in tom wilson's book,he says use rtv silicone or permatex 3H,
1974 parts bus
poundman
poundman is offline
PostPosted: Sun Jul 13, 2025 6:51 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Ok I got my heads installed with push rods, rockers and started to adjust the valves. I ran into a bit of an issue with #4 exhaust valve. It appears the exhaust valves don't have the same amount of travel as the intake valves. Is that correct?
I am using the instructions from the Bently Manual. I marked TDC before I put the heads on and I am rotating CCW and watching distributor move 90deg for each cylinder, doing 1-2-3-4. However, only they last one I did, which was #4 seem to have less travel. I managed to it it adjust but the rockers screw is almost all the way out.
Any tips? I did remove the rocker to make sure the push rods were seated correcting in the lifter tab and the arm. Could the lifter be stuck? I was not able to get all them out, but I think it had travel when I was trying. How can I fixed the lifter issue? If I remove that push rod tube and try and move the lifter?
Unless I hear from someone I will likely it it test running and hope it settles in when I get oil and movement going. I will do some research. Here are a few pictures
Sugar Land, Texas
Wildthings
PostPosted: Sun Jul 13, 2025 8:35 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Your pushrod is likely not seated correctly in the lifter. Twist it around a bit and it might pop in, if not you will need to loosen the nuts holding the rocker shafts to the head until there is no pressure on that particular pushrod and you can work pushrod into place.
poundman
poundman is offline
PostPosted: Mon Jul 14, 2025 7:25 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Thanks, I did take it apart to make sure it was seated on both ends, but I will do this again to double check. I thought about removing the tube and spraying some lub. I guess I could try my endoscope also.
Any other tips to check the lifter movement? I do know it is moving
Sugar Land, Texas
Wildthings
PostPosted: Mon Jul 14, 2025 9:19 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
As you tighten the rocker arms down, each pushrod will have it's critical moment when it is most likely to get hung up. Just slow up on this part of the job so you catch a problem pushrod as the problem occurs.
Willin
Willin is offline
PostPosted: Mon Jul 14, 2025 9:57 am    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
#4 exhaust is paired to #2. If there was nothing wrong with #2, then make sure you are on TDC in the firing position. Both rockers will be loose, of course. In the picture, it looks to me you're not.
I wouldn't fire it up till you figure out that #4 ex. Rotate engine forward and check each cylinder. With a timed distributor installed, look at where the rotor points.Should point to a wire terminal on the cap.
Have you gotten any peek of the cam lobes?
Have you checked your deck height? My engine had the head gaskets, which I DID NOT use. But I got different shims for the cylinder bases to reset my deck to @.040. The small increase in CR is said to be beneficial.
It's easy enough to pull the P+C's. Clean good first. Pistons can then be properly cleaned and checked. Your LAPS can loan you a cylinder hone and a piston ring compressor.
Don't get in a hurry at this point. Very Happy
73 bus. Org. 1700 with dual Weber 40 idfs, bus header with Empi qp muffler, CB magnaspark 2 " ready to run kit".
poundman
poundman is offline
PostPosted: Mon Jul 14, 2025 6:53 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
I think I might have figured out my problem with valve adjustment. I noticed that the rocker arm for exhaust on #4 (the problem child) has a different number than the other exhaust rocker arms.
#4 has a code 46 R 5
All other exhaust rockers have code 7 H 24.
It is very hard to tell them apart. Could this be the problem? I have search the samba and can't find reference to the rocker arm codes.
# 4 exhaust is the back rocker
# 3 exhaust is front rocker
Sugar Land, Texas
Wildthings
PostPosted: Mon Jul 14, 2025 9:19 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
The Type 4 engine requires 4 each of two distinctly different rockers. What you are likely seeing is casting numbers and not part numbers. If you put the differently numbered lifter on one of the rocker shaft right next to one of the other three similar lifters, does it appear to be dimensionally the same?
poundman
poundman is offline
PostPosted: Tue Jul 15, 2025 7:45 pm    Post subject: Re: Engine/Transmission removed where and how would you start? Reply with quote
Thanks for the explanation. They are same size. I did manage to get it seated and now have the .006 inch gap set on all rockers
Sugar Land, Texas
Page 12 of 13
