Seatbelt latch thumb Knob
tjbayless
tjbayless is offline
PostPosted: Wed Jul 02, 2025 7:43 am    Post subject: Seatbelt latch thumb Knob Reply with quote
I’m in the process of cleaning up the seatbelts form my 71 Bus. Is there anywhere to source the white release knobs like the ones in the picture. I believe these are Beetle rear but the same.
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jul 02, 2025 8:48 am    Post subject: Re: Seatbelt latch thumb Knob Reply with quote
clean with WD40, if that fails lacquer thinner, is that fails acetone. Most seat belts are a unit because they are crash tested and certified as a unit. You can look here to see if a separate part is listed https://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-Main.html
tjbayless
PostPosted: Thu Jul 03, 2025 3:54 am    Post subject: Re: Seatbelt latch thumb Knob Reply with quote
Thank you for the response. Unfortunately I don’t have any to clean. The picture was just for reference on what I need.
SGKent is offline
PostPosted: Thu Jul 03, 2025 9:58 am    Post subject: Re: Seatbelt latch thumb Knob Reply with quote
contact Ken Madson at TheBusCo and see if he has a good pair of latches for a 1971 like that. Send him the photo as a sample.
The 1971 belts just lie loose, and the aftermarket style winders they could use are not very easy to find anymore. You could consider modern belts that have a winder in them, which makes it a lot easier to get in and out without having the belts get in the way. These are about $320 for left and right front but they are made by the same people who make belts for modern cars. Unless you are 6' and 280 or so, these will give lots of room to move around in. https://gowesty.com/products/3-point-retracting-se...6690375845
tjbayless
PostPosted: Thu Jul 03, 2025 6:14 pm    Post subject: Re: Seatbelt latch thumb Knob Reply with quote
I’m working on an upgrade to the original. My plan is to use the original latched with a modern retractable 3 point setup. Will require adding the original bus hardware to the new seatbelt webbing.
jtauxe Premium Member
jtauxe is offline
PostPosted: Thu Jul 03, 2025 8:42 pm    Post subject: Re: Seatbelt latch thumb Knob Reply with quote
While that may seems like a good idea, it is not. You would have to separate and then resew the webbing in a way that meets seat belt standards. Don't mess with them. Having the stock look is not worth a trip through the windshield in the event of a crash.
But do upgrade to a better three-point system. Make sure that your anchor points are solid and not rusted underneath in the wheel well.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
SGKent is offline
PostPosted: Thu Jul 03, 2025 10:34 pm    Post subject: Re: Seatbelt latch thumb Knob Reply with quote
^^^^ what John said.
W1K1
W1K1 is offline
PostPosted: Fri Jul 04, 2025 6:34 am    Post subject: Re: Seatbelt latch thumb Knob Reply with quote
I ordered new retractable ones from https://www.seatbeltplanet.com
The old ones were pretty gross condition
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
