Snoopy1971 Samba Member
Joined: May 15, 2020 Posts: 311 Location: Parkville, Maryland
Posted: Tue Jul 01, 2025 3:27 pm Post subject: Help With Stripped Engine Bolt |
Ok so putting my engine back in ... tightened the bottom 2 engine bolts and then moved on to the top 2.
Is the top left engine bolt supposed to catch on the casting in the transmission? Because my bolt just spins, but I can't get a socket on it because it hits the transmission casting. It looks like it's supposed to catch there, but maybe mine is worn away some.
Was able to barely get some vice grips on the bolt and got it tightened down.
Now in to my problem... The "D" engine bolt that goes through the starter, it must be stripped because the nut just keeps turning and turning and turning and never tightens down. It is snug up against the firewall and there's no play in the bolt whatsoever, but it just won't tighten.
Kind of weird because it was a brand new bolt when I put it in 5 years ago, and it literally has only been taken out and tightened and loosened about 3-4 times. Crappy aftermarket Empi bolt.
I still have my original bolt.
What should I do? Is it ok to leave? Since its the starter bolt, I kind of want to get it out and replace with my original one.
But I have no idea how to get the nut off ... it's not like there's any room behind the fan shroud to work.
Anyone have any thoughts on this? _________________ 1968 Bug |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33104 Location: Hot Arizona
Posted: Tue Jul 01, 2025 4:40 pm Post subject: Re: Help With Stripped Engine Bolt |
Snoopy1971 wrote: |
Is the top left engine bolt supposed to catch on the casting in the transmission? |
Yes, with 1971 and newer engine cases. These have a pressed in captive nut which can be added to earlier engine cases.
Engine Case Nut Insert Captive Nut press-in nut:
https://wolfgangint.com/case-components/2883-engine-case-nut-insert-111199102.html
I like to use a 10mm x 1.5mm x 70mm metric allen head bolt for upper left instead of a hex head bolt (Ace Hardware).
Snoopy1971 wrote: |
Anyone have any thoughts on this? |
I've ALWAYS been able to get my hand behind the fan shroud and loosen the upper right stater bolt's nut with a 17mm socket and ratchet. Nowadays I might even try a 17mm gearwrench.
The older VWs used a plain old hex head bolt and nut for this, one just needed a helper to go under and hold the 17mm on the bolt head from underneath. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4495 Location: viroqua wi.
Posted: Tue Jul 01, 2025 5:39 pm Post subject: Re: Help With Stripped Engine Bolt |
Can you feel threads with your fingernail? Are the threads on the nut gone? Is the nut the right size? |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 873 Location: Moreno Valley
Posted: Tue Jul 01, 2025 5:59 pm Post subject: Re: Help With Stripped Engine Bolt |
maybe loosen the two you tightened , put the jack back under there with just a little lift n see if you can get the top bolt started , i never fully tighten anything till i get all the bolts started first ???
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79569 Location: Sneaking up behind you
Posted: Tue Jul 01, 2025 6:05 pm Post subject: Re: Help With Stripped Engine Bolt |
Snoopy1971 wrote: |
Pull the bolt out and look at the threads and the nut. Or just replace both. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4934 Location: Stuck in Ohio
Posted: Tue Jul 01, 2025 7:25 pm Post subject: Re: Help With Stripped Engine Bolt |
Snoopy1971 wrote: |
Now in to my problem... The "D" engine bolt that goes through the starter, it must be stripped because the nut just keeps turning and turning and turning and never tightens down...
Are you saying the nut also won't rotate off when tying to loosen it? That is a tough situation.
Are you sure the D bolt is not spinning? Can you have a friend try to loosen the 17mm nut while you lie under the car and reach up there with your hand to feel if the D bolt is spining? _________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
Posted: Tue Jul 01, 2025 7:34 pm Post subject: Re: Help With Stripped Engine Bolt |
bsairhead wrote: |
How would I feel the threads on the nut, when the nut is on the bolt? ... But yeah it's the right nut, as it came with it in the set. _________________ 1968 Bug |
Posted: Tue Jul 01, 2025 7:35 pm Post subject: Re: Help With Stripped Engine Bolt |
Glenn wrote: |
Snoopy1971 wrote: |
Pull the bolt out and look at the threads and the nut. Or just replace both. |
I cant pull the bolt out ... the nut just keeps spinning in both directions ... it never comes off. _________________ 1968 Bug |
Posted: Tue Jul 01, 2025 7:36 pm Post subject: Re: Help With Stripped Engine Bolt |
Buggeee wrote: |
Snoopy1971 wrote: |
Are you sure the D bolt is not spinning? Can you have a friend try to loosen the 17mm nut while you lie under the car and reach up there with your hand to feel if the D bolt is spining? |
Correctamundo ... it wont rotate off ... the D bolt isnt spinning. I was sitting there watching it as my friend turned the wrench on the nut in both directrions _________________ 1968 Bug |
Posted: Tue Jul 01, 2025 7:41 pm Post subject: Re: Help With Stripped Engine Bolt |
Cusser wrote: |
Snoopy1971 wrote: |
Snoopy1971 wrote: |
The older VWs used a plain old hex head bolt and nut for this, one just needed a helper to go under and hold the 17mm on the bolt head from underneath. |
I think I confused people by asking about both bolts/nuts . I dont have the captive nuts ... those are on a doghouse engine correct? What I meant, was does the bolthead of the upper left bolt, "catch" the casting in the tranny housing, like the D bolt does on the starter. I ask because I cant get a socket on it, as it there is a part of the tranny housing blocking me from getting it on ... it looks like there was something there to catch the bolt head but maybe it wore away, as the bolt head spins when turned from the other side.
The only way I was able to get that bolt tightened was I barely got some vicegrips on it while my friend turned the nut on the other end _________________ 1968 Bug |
Posted: Tue Jul 01, 2025 7:42 pm Post subject: Re: Help With Stripped Engine Bolt |
I think I'm going to loosen the other starter nut and pry a screw driver behind it and see if the force will will let a friend get the nut off _________________ 1968 Bug |
Cusser Samba Member
Posted: Wed Jul 02, 2025 8:01 am Post subject: Re: Help With Stripped Engine Bolt |
Cusser wrote: |
Bring the VW to Arizona, I'll get that going !!! |
Too hot for me!! ... yeah yeah I know, it's a dry heat  _________________ 1968 Bug |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35916 Location: Conejo Valley, CA
Posted: Wed Jul 02, 2025 8:32 am Post subject: Re: Help With Stripped Engine Bolt |
Nothing to capture the bolt head on the upper left bolt. On older cars I have used vice grips, or a box end wrench wedged in.
Regardless, it is well worthwhile to clean, deburr, and lightly lubricate all engine mount hardware before using. Make sure the companion nut catches a thread and spins freely in your hand. Sometimes the slightest friction or burr will make the other part spin and come loose, causing endless frustration. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Sat Jul 05, 2025 11:17 am Post subject: Re: Help With Stripped Engine Bolt |
Whoah ... what an ordeal. I wanted to try a nut splitter, but after using the splitter on a test nut/bolt in my vice, I had to use so much force in it, my vice would spin, so changed my mind... I didnt want t put that much force on it in the car and risk damaging or cracking the case flange around the bolt hole.
I ended uo having to pull the carb off and lift the fan shroud and hold it in place and remove the generator/fan so I could see through the hole.
Had the grind the nut off with a dremel and carbide bit.
WTF is with that bolt. Damn chinesium bolt sheared the threads flat.
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11183 Location: Huntington Beach, CA
Posted: Sat Jul 05, 2025 11:44 am Post subject: Re: Help With Stripped Engine Bolt |
What does the bolt head face say? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Glenn  Mr. 010
Posted: Sat Jul 05, 2025 11:58 am Post subject: Re: Help With Stripped Engine Bolt |
VW_Jimbo wrote: |
What does the bolt head face say? |
I bet it says OUCH. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sat Jul 05, 2025 12:04 pm Post subject: Re: Help With Stripped Engine Bolt |
Glenn wrote: |
VW_Jimbo wrote: |
I bet it says OUCH. |
Totally agree!
But just maybe it is a grade 5 bolt. It would make way more sense than the 10.8 that should be there! _________________ Jimbo
TDCTDI wrote: |
Posted: Sat Jul 05, 2025 12:45 pm Post subject: Re: Help With Stripped Engine Bolt |
VW_Jimbo wrote: |
It was the D bolt ... nothing on the bolt head. I believe it was this set I had ordered...
https://www.jbugs.com/product/9551.html _________________ 1968 Bug |
jinx758 Samba Member
Joined: October 04, 2014 Posts: 1033 Location: half a bubble from plumb
Posted: Sat Jul 05, 2025 3:56 pm Post subject: Re: Help With Stripped Engine Bolt |
What a bugger !
The simplest things can be SO frustrating.
Hah hah, you win !
Say that from having to break loose 3&1/2" gland nuts on hydraulic cylinders being held on with red Locktite. Some took a 12' cheater bar, rosette tip w/acetylene torc, & 4 guys hanging on cheater bar.
Sounded like a shotgun when it popped loose ! LOL
Good job ... stay safe
jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference ...
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
