Malakite Samba Member
Posted: Yesterday 5:19 am Post subject: Valve Grounding |
Hi everyone - I have the engine out of my beloved Beetle (1974 1200cc) for some routine maintenance seeing as I needed to take the Transmission out to change the seals.
This is a 2 part Q;
1) I was going to clean the carbon off the pistons and valves, and wondered the best way you would all do it and if I am ok to re use the original Valves as these are obviously the VW originals and best? Should I clean up as well as re-ground too? Would you clean the Cylinder head too? If so again, what would you use?
2) I need to change the inner seals of the Driveshafts as these were leaking - any ideas at all? I was also going to replace the end driveshaft bearings, but boy oh boy - bearing pullers seem to rare - any ideas on one that is compatible at all? I believe I need to take the end ones out first before removing the whole shaft in order to get the new washers/seals into place? Any ideas or "how t's" at all?
Thank you all so much in advance |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1013 Location: South Florida
Posted: Yesterday 12:23 pm Post subject: Re: Valve Grounding |
Malakite wrote: |
... some routine maintenance ... clean the carbon off the pistons and valves ... |
That's not routine maintenance.
Malakite wrote: |
... best way you would all do it ... |
Myself, I'd drive to nearest freeway and run my car with wide open throttle for awhile. But since your engine is out, my suggestion is to do a compression and/or leak-down test; because, you may not need to open up your engine at all. |
Starbucket Samba Member
Posted: Yesterday 1:44 pm Post subject: Re: Valve Grounding |
Do you have a swing axel trans.? the boots can be changed with trany. in car.
Marine supply stores sell a liquid carbon remover you spray down the carb. with the motor running.
Do a compression test on a warm motor with the throttle propped wide open and if your readings are good don't mess with it. |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6063 Location: 37.5N 77.1W
Posted: Today 7:39 am Post subject: Re: Valve Grounding |
Quote: |
clean the carbon off the pistons and valves |
Old school trick. Slowly pour water into the carb, slow enough the engine doesn't cut-off. Pistons and valves will get steam cleaned.
Ever see a water cooled engine with a 'blown' head gasket? The piston where the leak is will be shiny clean.  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
