Shift elbow drilled out?
ProbablyNotIan
ProbablyNotIan is offline
PostPosted: Mon Jul 07, 2025 7:31 am    Post subject: Shift elbow drilled out? Reply with quote
This weekend, we did a full overhaul of the shifter system. When we installed the GoWesty shift elbow, we noticed that the old shift elbow had a bolt that went through the top and threaded into the bottom instead of using a roll pin. At the time, we didn't think much about it (the focus was more on that fricking pin).
We put it all up, install everything, and start working on the alignment. That's when we realized the hole in the shift rod was bigger than the roll pin and almost all of the movement was being taken up by that.
After pulling everything back off and removing the GoWesty elbow, it would appear that the shift rod and elbow were drilled and tapped.
Either that or there was a weird case where the elbow didn't use a roll pin that I can find no record of? Maybe it's an aftermarket elbow?
Here are some pictures:
Any ideas?
The Brown Van
Senior Platform Engineer | USSF Grassroots Educator | USSF National C License
MarkWard
MarkWard is offline
PostPosted: Mon Jul 07, 2025 8:35 am    Post subject: Re: Shift elbow drilled out? Reply with quote
I have read of them wearing and owners get creative. If you have a welder friend, it could be easily welded and redrilled. Or you could shift it forward or backwards and drill a new hole. Make up the difference in the spline section. Bummer, but not the end of the world.
Sodo
Sodo is offline
see this post: Vanagon REAR shifter slop
You could split one leg of the VW elbow for a pinch-clamp arrangement.
Everyone who has pounded out that roll pin should do this because it's a lot easier to service the shift rod.
I don't remember if the original pin is 5mm or 6mm. If it's 5mm then perhaps the cup can be simply threaded
But it looks like yours is drilled for an M8 bolt.
I'm pretty sure there's space inside the VW cup for an M8 bolt-head.
....KTMs, GasGas, SPOT mtb
ProbablyNotIan
PostPosted: Mon Jul 07, 2025 9:15 am    Post subject: Re: Shift elbow drilled out? Reply with quote
Not sure how you picked that out, but you're dead on.
What I think I'll probably try is the "Deluxe" shift elbow from GoWesty. I think there's enough clamping force there that it should eliminate the play and make it more serviceable down the road without having to drop $200 on the rear rod.
The Brown Van
MarkWard
MarkWard is offline
PostPosted: Mon Jul 07, 2025 9:21 am    Post subject: Re: Shift elbow drilled out? Reply with quote
I thought you were attempting to fit an aftermarket GW shift elbow. My mistake. I’m not familiar with the clamping style, but without some splines wouldn’t trust it to stay in position.
Sodo
Sodo is offline
PostPosted: Mon Jul 07, 2025 9:41 am    Post subject: Re: Shift elbow drilled out? Reply with quote
It's an old shade-tree VW repair. Probably more than a few out there.
But it still has slop because there's no clamping
-because they don't split the hoop.
Your shift rod already has an M8 hole drilled.
That GoWesty elbow will have to be:
drilled to M8,
and split
and bolted.
You're only 5 minutes & a hacksaw away from trying that on your existing elbow.
ProbablyNotIan
PostPosted: Mon Jul 07, 2025 9:42 am    Post subject: Re: Shift elbow drilled out? Reply with quote
I had the "standard" which still uses solely the roll pin.
I think this new one just came out recently and uses the clamp style with a bolt where to roll pin would be to locate it.
Seems like a good way to get both things at once.
The Brown Van
MarkWard
MarkWard is offline
PostPosted: Mon Jul 07, 2025 9:52 am    Post subject: Re: Shift elbow drilled out? Reply with quote
I’m guessing you don’t have a friend that’s a welder. Would be much quicker vs return shipping, credits, more shipping turn around time etc. Even someone with torches could braze or weld it up. The holes don’t need to be completely filled. Just enough to drill back to the correct size for the pin.
vanis13
vanis13 is offline
PostPosted: Mon Jul 07, 2025 10:41 am    Post subject: Re: Shift elbow drilled out? Reply with quote
This solution in this link is slick!
vanis13
vanis13 is offline
PostPosted: Mon Jul 07, 2025 11:26 am    Post subject: Re: Shift elbow drilled out? Reply with quote
I don't believe the OEM/pint ones have splines (the center U-joint does have splines) so the clamper solution is even tighter with a vertical metal rod (bolt) AND clamping force.
vanis13
vanis13 is offline
PostPosted: Mon Jul 07, 2025 11:28 am    Post subject: Re: Shift elbow drilled out? Reply with quote
and if the socket was drilled bigger so was the rod so both would need to be re-filled.
I don't see a down-side of the 5-min hack-saw SODO solution clamping idea...none of SODO's solutions are hack jobs Laughing
ProbablyNotIan
PostPosted: Mon Jul 07, 2025 11:38 am    Post subject: Re: Shift elbow drilled out? Reply with quote
That is slick, but it's a different elbow.
It looks like an aftermarket elbow of some sort.
It doesn't feel like the stock elbow has enough meat on the bone to actually clamp like that. Maybe it's enough, but it's not as much as that link.
The Brown Van
vanis13
vanis13 is offline
PostPosted: Mon Jul 07, 2025 12:28 pm    Post subject: Re: Shift elbow drilled out? Reply with quote
yes its a diff elbow BUT what have you to lose to try? you're already going to toss that elbow. AND your shaft hole is too big now anyway after being drilled out to use the OEM/GW fastening .
This is a good guy to listen to. his background is very close to the other definition of the USSF you have in your signature.
drilled to M8,
and split
and bolted.
do.dah
do.dah is offline
PostPosted: Mon Jul 07, 2025 12:33 pm    Post subject: Re: Shift elbow drilled out? Reply with quote
Just an fyi, I recently bought the delux GW shifter rebuild kit;
https://gowesty.com/products/shifter-system-overha...3253566832
My shifting WAS wonderful. My only real issue was the rod bushings would occasionally cake up with either mud or ice cuz I didn't have the bellows.
Also, I have tired of replacing the ball and cup boot/gaiter along with the boot/gaiter on the shift shaft outta the tranny.
I feel the kit is well put together, and the delux elbow/cup just seems to be a far better design than OEM. And I'm hoping the bellows/boots/gaiters will last for more than a year or 2???
But dammit, for the life of me, I cannot get the shifting clocked correctly. I've NEVER had an issue with getting the shift rods clocked before. But something is amiss now..
Before installing the kit, I measured and compared all my old parts to the new parts. My original ball and cup/elbow was quite worn and fit together very sloppily.
I can only think, that the new boots/gaiters and bellows are so stiff and tight, that they're mucking up my shifting? Or, perhaps I slightly bent the ears while replacing the plastic tabs? Or, or??
Anyhoo, just a cautionary tale, if something is working, DON"T GO FIXING IT!!
Sodo
Sodo is offline
PostPosted: Mon Jul 07, 2025 1:41 pm    Post subject: Re: Shift elbow drilled out? Reply with quote
[That is slick, but it's a different elbow.
I think that’s a GoWesty elbow from 2015.
I bet the M8 bolt ovalizes and thus clamps your existing potmetal elbow but cutting one side might clamp better.
If it doesn’t work,
well,
that elbow you have doesn’t look like a family heirloom. Wink
Cut it and test it.
ProbablyNotIan
PostPosted: Mon Jul 07, 2025 1:54 pm    Post subject: Re: Shift elbow drilled out? Reply with quote
If it doesn’t work,
well,
Cut it and test it.
The problem is that if I cut it and it doesn't work...I'm then out a shifter until I can get new stuff anyways.
Maybe I didn't make it clear, but the GoWesty elbow didn't work at all. There was too much play in the connection due to the oversized hole. So I had to reinstall the original, modified one.
I guess I could modify the GoWesty one since it's currently doing nothing, but it seems like I could probably hang on to that or sell it on instead of just taking a gamble and cutting it up.
It's workable as it is (thanks all new everything else in the shifter assembly) so I think I'll probably think about it for a bit and worry about it when I get back from a camping trip I have at the end of the month. I figure that elbow worked for a long time before this, it can get me through another couple of weeks.
The Brown Van
MarkWard
MarkWard is offline
PostPosted: Tue Jul 08, 2025 11:49 am    Post subject: Re: Shift elbow drilled out? Reply with quote
Ok, I think we agree not to modify the current GW one. It likely has value for trade with GW or to another member.
Ive always run stock shifter parts. They work pretty well for me. Aftermarket parts often look pretty, but what problem do they solve? This is across the entire aftermarket business for all makes. We spend a lot of time making aftermarket parts work.
While probably not high on your list, reassemble the stock part as was. Maybe some green Loctite and call it a day if it was working before.
Having made a living fixing cars, nothing is more frustrating than coming across what should be a straightforward repair and finding someone has been there before and the parts as ordered won’t work. That’s why I was placing emphasis on repairing the stock shaft. Tom is pretty smart and in no way was I suggesting hack repairs. I also stated I was unfamiliar with a clamping elbow and like the ujoint splines would work better in a clamping fix. Obviously if it’s through bolted that’s not going to slip.
Sodo
Sodo is offline
PostPosted: Tue Jul 08, 2025 12:06 pm    Post subject: Re: Shift elbow drilled out? Reply with quote
Of course the GoWesty CNC elbow requires modification to fit with your 8mm drilled shift rod.
I see four options:
    1) put it back together with the original VW elbow and M8 bolt (....as you wrote)
    2) original elbow, but cut one leg so the M8 bolt clamps the shift rod tightly, eliminating slop at the shift rod. You still have the worn area inside the old VW cup. Stick youf finger into the cup, you will feel the worn area where the ball has ovalized the socket. Thats some shift slop right there.
    3) drill out the GoWesty CNC cup to fit your 8mm bolt and shift rod, and assemble. Shifting will be tighter because the cup diameter is not ovalized.
    4) Cut one leg of the GoWesty CNC elbow and further eliminate slop at the shift rod.
I'd go directly to #4 then your van will have the best elbow and least shifting slop.
For enlarging the 6mm to 5/16" (=8mm) I recommend a "step-bit" for the bottom hole because the step-drill is self-centering. For the inner hole I bet the step-drill can reach it from the cup-side. Maybe you need an extension.
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Tue Jul 08, 2025 1:37 pm    Post subject: Re: Shift elbow drilled out? Reply with quote
Seems to me the easiest solution is to use the new pinch clamp style of GW Deluxe Elbow. Since it's just a chunk of machined aluminum there should be sufficient material to tap the threaded center hole to fit the larger diameter center bolt to match the larger hole in the shift rod.
The four pinch bolts will hold it securely.
https://gowesty.com/products/shifter-selector-leve...5445917861
Maybe give GW a call about the idea of tapping the center hole and how quickly they can ship to your address.
Or you might look for a sleeve to insert into the shift rod to enable the use of the correct size bolt supplied with the elbow.
Currently:
All that's needed for evil to prevail is for good people to do nothing.
Sodo
Sodo is offline
PostPosted: Tue Jul 08, 2025 5:25 pm    Post subject: Re: Shift elbow drilled out? Reply with quote
GoWesty is nuts
Two different products on one page, might be efficient for the web guy.
But for the sales manager, the confusion = sales decrease.
The confused customer buys nothing.
Looks like its threaded for M6.
Ian/Not would have to re-thread the deluxe to M8 to center it on his 8mm shift rod hole.
Maybe could just thru-drill 8mm and put a nut on the bottom.
being in-hand,,,, #4 is still the most efficient method to get shifting in topshape.
