Turn signal relay question
spacebiscuit
spacebiscuit is offline
PostPosted: Sun Jun 08, 2025 1:29 pm    Post subject: Turn signal relay question Reply with quote
Hi all - my bus has been laid for a year after having some work done. Turn signals are not working - just two green lights on the dash and I discovered the relay was loose - not connected.
I had a look at the wiring diagram - with just the blue/red and the white + plugged into the relay I was able to make the lights flash manually if I wiggled the wires - see this video:
Note that I don't have the brown wire connected - I did try it but it made no difference.
Is this indicative of a bad relay - I bought it a few years ago but the bus has not been used - just stored. I appreciate it is an after-market relay but would it go wrong having not been used?
Thanks in advance.
1972 Type 2 1600cc
1990 MKII Golf 1.6 CL
SGKent Premium Member
SGKent is offline
PostPosted: Sun Jun 08, 2025 2:39 pm    Post subject: Re: Turn signal relay question Reply with quote
you are saying that the outside lights do not light up?
Did it ever work with that relay?
George Carlin:
Skills@EuroCarsPlus:
spacebiscuit
PostPosted: Sun Jun 08, 2025 2:46 pm    Post subject: Re: Turn signal relay question Reply with quote
Did work previously yes. Correct, only the light on the dash light up but they are static, light themselves don't light.
They do work and light outside when I wiggle the wire per the video.
1972 Type 2 1600cc
Wildthings
Wildthings is offline
PostPosted: Sun Jun 08, 2025 4:17 pm    Post subject: Re: Turn signal relay question Reply with quote
Seems like it's time for a new relay.
SGKent is offline
PostPosted: Sun Jun 08, 2025 4:20 pm    Post subject: Re: Turn signal relay question Reply with quote
it is either a wire crimp or inside the relay.
George Carlin:
spacebiscuit
PostPosted: Mon Jun 09, 2025 2:17 am    Post subject: Re: Turn signal relay question Reply with quote
I think I have got the relay wired up wrong. the white (+) should go to pin 49 which is where I have the blue wire connected in my video. That is terminal 31 which should have the brown wire. the blue wire should be on the terminal which I don't have connected currently - I think Smile
The white and brown wires are just a 12v positive/negative feed as I understand it so using a multi meter I should get a 12v reading? The blue I guess is a switched live?
1972 Type 2 1600cc
Wildthings
PostPosted: Mon Jun 09, 2025 4:15 am    Post subject: Re: Turn signal relay question Reply with quote
This diagram for a '72 show J2 (the flasher relay) has having three connections, I would assume all three are necessary:
Double click to enlarge
The diagrams for later years essentially show the same thing. J2 is in current tracks #44 and 45:
spacebiscuit
PostPosted: Mon Jul 07, 2025 1:23 pm    Post subject: Re: Turn signal relay question Reply with quote
Issue was a bad ground - yes 3 connections are required. A live feed (49), the ground (31) and the live feed to the flasher hand switch control (49a) which presumably switches the feed on and off to give the flashing bulbs.
I changed the ground as well as the relay to remedy.
Thanks all.
1972 Type 2 1600cc
