seat swivel
wholenole
wholenole is offline
PostPosted: Tue Jul 08, 2025 1:38 pm    Post subject: seat swivel Reply with quote
Can anyone help me out? What parts am I missing for the seat swivel? It appears that there should be a plate that mounts to the bus.
busdaddy
busdaddy is offline
PostPosted: Tue Jul 08, 2025 3:10 pm    Post subject: Re: seat swivel Reply with quote
Welcome!
Yeah, the welded on part is missing, have a look through all of these topics on swivelling to see some pics of what you need, maybe you can fabricate something yourself: https://www.thesamba.com/vw/forum/search.php?searc..._chars=200
Слава Україні!
Shonandb Premium Member
Shonandb is offline
PostPosted: Tue Jul 08, 2025 6:40 pm    Post subject: Re: seat swivel Reply with quote
Just happened to have mine off on my 76 Westy manufactured in Feb of 76.
Previous 1973 Panel Bus:
Click to view image
wholenole
PostPosted: Tue Jul 08, 2025 8:26 pm    Post subject: Re: seat swivel Reply with quote
Makes sense now…when I removed the seat there was a rotten piece of plywood with bolts in it under the seat. Previous owner must have engineered the base plate out of plywood. Unlikely I can find a used one before I start painting. Any ideas on an aftermarket base or a good replacement kit?
Shonandb is offline
PostPosted: Wed Jul 09, 2025 8:54 am    Post subject: Re: seat swivel Reply with quote
Not sure on aftermarket options but there must be some. If you can weld, you could buy an appropriately thick piece of metal plate and weld it in and add the fastening bolts. Alternately, reach out to Busted Bus (google them) and see if they can remove and send you one from their donor Buses.
Click to view image
blacka1vw
blacka1vw is offline
PostPosted: Wed Jul 09, 2025 9:18 am    Post subject: Re: seat swivel Reply with quote
Busted bus is where I got a piece for mine. If your buying that weld in piece separate I think there is a difference in diameter if the round plate and spacing on the studs.
64 SC truck.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet
wholenole
PostPosted: Wed Jul 09, 2025 10:17 am    Post subject: Re: seat swivel Reply with quote
Thank you all for the input! Greatly appreciated!!!
