Chunky_t Samba Member
Joined: June 11, 2025 Posts: 8 Location: Marlborough New Zealand
Posted: Fri Jul 11, 2025 9:25 pm Post subject: Unusual case cracks |
Hey guys,
Just cleaning up my engine for a 65 beetle (F case) and noticed what looks like a rather large crack stemming from the casting mark on the top of the case at cylinder 1.
What's got me stumped is the marks around it, is it an old repair? Casting flaw? Doesn't leak to my knowledge.
Photos for reference. Possibly a devastating find as it's not a huge budget build.
Anyone have any ideas or seen cracks here before? |
modok Samba Member
Joined: October 30, 2009 Posts: 27663 Location: Colorado Springs
Posted: Fri Jul 11, 2025 9:35 pm Post subject: Re: Unusual case cracks |
I doubt those are cracks |
Posted: Fri Jul 11, 2025 9:38 pm Post subject: Re: Unusual case cracks |
modok wrote: |
The one in the photos looks very crack like, not sure what else it is. Seems odd however. |
modok Samba Member
Posted: Fri Jul 11, 2025 11:15 pm Post subject: Re: Unusual case cracks |
Take a 1/2 ball or oval carbide burr and grind until it's smooth, then check again.
You don't need to do the whole thing, just pick the spot that you are most sure is a crack and hit that.
Soak with wd40, wipe it off, Pass a torch over it.
Or just fully degreasing with any aggressive detergent (12ph jetwash detergent) also tends to make cracks visible. |
74 Thing Samba Member
Posted: Fri Jul 11, 2025 11:44 pm Post subject: Re: Unusual case cracks |
Put a torch on it like suggested above and if there is a crack you should see it with the heat and case expansion. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3317 Location: Hamble, Hampshire, UK
Posted: Fri Jul 11, 2025 11:49 pm Post subject: Re: Unusual case cracks |
Looks like a casting flaw where metal flows into the mold but cooled before filling it fully. It has always been there.
Yes it is potentially a weakness in the case but because of its location (maybe over a thick part of the case) it has not leaked or done anything else for well over 50 years.
I would ignore it. Or if you like put JB Weld in the depression to make you feel better about it. _________________ Ancient vehicles and vessels
RWK Samba Member
Posted: Sat Jul 12, 2025 5:19 am Post subject: Re: Unusual case cracks |
Yes, casting flaws, we call them knit lines in the plastic molding business. same thing happens in the die casting industry. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
