Two quick window questions
sharpstick
sharpstick is offline
PostPosted: Sat Jul 12, 2025 4:21 pm    Post subject: Two quick window questions Reply with quote
I replaced the rubber and felt on my windows. What holds the vertical window scraper on the fixed window at the top? I know the bottom is held in place by the bracket that has the window latch openings. If there was something at the top it might have gotten tossed.
The felt kit is from Jbugs. There’s a lot of vertical movement in the windows. Is this because of the kit? Should I have ordered from Wolfsburg instead?
BarryL Premium Member
BarryL is offline
PostPosted: Sat Jul 12, 2025 6:35 pm    Post subject: Re: Two quick window questions Reply with quote
This at the top. It's a rubber block. The bottom is held by the bottom felt/rubber.
'67 they changed to a metal pointed piece. Wolfsburg West sells that style.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211837455
@Buswerx
@Buswerx is offline
PostPosted: Tue Jul 15, 2025 1:03 am    Post subject: Re: Two quick window questions Reply with quote
If you’re referring to the window divider, there is a small clip that attaches to the top of the window divider tab. It is pushed into the felt for a tight fit
tasb
The Distributor Distributor
tasb is offline
PostPosted: Tue Jul 15, 2025 4:27 am    Post subject: Re: Two quick window questions Reply with quote
This?
Roads Scholar
Member# 2059
@Buswerx
@Buswerx is offline
PostPosted: Tue Jul 15, 2025 8:19 am    Post subject: Re: Two quick window questions Reply with quote
tasb wrote:
This?
CORRECT
