Jeremiah's 73 412 restoration project
Page: Previous  1, 2, 3 ... 12, 13, 14, 15, 16, 17  Next
Jeremiah Berger
Jeremiah Berger is offline
PostPosted: Sat Jul 12, 2025 2:48 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Looking at the price of a used MPS vacuum tested at an average of $300- $450 and refurbished ones at $1200 ! makes me wish I just got some flipping carbs or a new efi to start. This thing is making me broke.
Pepperbilly
Pepperbilly is offline
PostPosted: Sat Jul 12, 2025 2:53 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Well, that is a bummer. We are type 4 people so we know that we can’t give up!
I would get ahold of Jim Adney. He rebuilt my original fuel pump and it works flawlessly. I understand he also rebuilds the MPS.
I can also send you the instructions I have for dealing with the MPS. I will mail it to you. I have your address.
Bill
raygreenwood
raygreenwood is offline
PostPosted: Sat Jul 12, 2025 10:21 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
What is the part # on your MPS? I will check my stock of parts. really, all the diaphrams are the same....just the setting varies. Ray
Jeremiah Berger
PostPosted: Sun Jul 13, 2025 5:03 am    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
There are two numbers not sure which is part # you need
0280100049
022906051E
Pepperbilly
PostPosted: Sun Jul 13, 2025 1:13 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
I like my mityvac vacuum tester. Also shown are the 2 adjustment tools if you remove the epoxy and unscrew the plug. If you are just replacing the diaphragm and set up the adjustment fitting as it was originally, you won’t need the tools. Shown here is a good MPS holding vacuum at 10 in. Hg for at least 5 minutes. If I remember correctly the test is good if it holds for 3 minutes.
Here are the tools if you remove the epoxied plug. They fit into the MPS and the tools slide into one another to make the dual adjustment.
Bill
raygreenwood
PostPosted: Sun Jul 13, 2025 1:31 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
0280100049
022906051E
I will get by my storage unit later. Going to rant for a few minutes here anyway! Laughing
So...back in...1995 to about 2001 I was living in Dallas, driving my 412 as my daily and clocking massive miles and about once a year or so, the diaphragm in whatever heavily used MPS I was rocking at the time would crack/give out.
So for a period of time I was living off a large collection of spares and really trying to find a way to reproduce the diaphragms so I could get spares. For me, having a diaphragm that was a little either more or less responsive, would not have been a problem because over the decades I have gotten pretty good at driving and tweaking, driving and tweaking.
Along those same lines, I have been able to readily use MPS that were not part numbered to my system and simply adjust them....AS LONG AS...the configuration was the same (meaning long snout versus short snout on the spring end etc.).
So, I made a few of these diaphragms....like five. First I was really worried about getting that same exact corrugated ring shaped crimp pattern. Then I found that there were several different diaphragm crimp patterns spanning the same part #. Then I found those with both the rings of crimp and maybe 4-5 spoke shaped, straight line radial crimps that I realized were put in to keep the diaphragm from twisting.
And, swapping them around ....they all ran the same when adjusted.
So, I came to the conclusion...proved it to myself if no one else (and this was before I was on any forums)...that the crimping pattern while some of it may be necessary for some flexibility....does not really matter...a.s long as the material and thickness and baseline springiness are similar enough.
I also saw a couple of the few I could afford....of "re-man" MPS's, usually from Beck Arnley....that had stainless steel diaphragms. None of those ran or adjusted right. Too stiff it was obvious.
It became clear that the thickness and overall spring/flexibility of the metal plate was all that was REALLY important. The crimping detail is not that important. And....keep in mind that they only flex about maybe 0.060"...maybe a little more depending on how your outer full load stop is adjusted.
I had also learned just how pretty much the same a lot of these are. For instance the 039 part # used in the 2.0 Porsche 914...is 100% identical to the E series MPS used in the Porsche 914 and 411/412 1.7L.....the ONLY difference being that there is a steel shim ring that goes between EITHER the copper diaphragm and the outer back cover....or between the copper diaphragm and the inner main body of the MPS. On 914 2.0....its on one side of the diaphragm and on 1.7L its on the other.
Its a spacer that allows the 2.0L system to make the diaphragm flex more in one direction and enrich more. Thats the only difference. I can take a 1.7L MPS, open it up...flip the spacer shim to the other side of the diaphragm...close it up and do a main armature tweak...and voila...runs like normal in the 2.0 914.
So I am saying I learned a lot about what works in this period of time.
So, I went to a metals shop in Dallas. Got about three feet of (going off memory now) either 0.0035" or 0.005" annealed copper foil about 4" wide. It was scrap. I could not get Beryllium copper at the time.
I agonized for a long time about how to press this and shape it. I finally took an old diaphragm (with a crack no less) and coated it in mold release and cast each side with JB weld about 1/4" thick on a piece of 1/8" steel plate. I took the copper plate and laid it across the mold and put it in the hydraulic press at work and got a pretty fair stamping. Not quite as distinct in the ribbing of the corrugations....but pretty good. I got five before the JB weld mold cracked.
Then I had to figure out how to get a clean hole in the center and for clean holes in the right places for the screws without bending this thing up. I still destroyed two of them. More on that below....
So if you look closely at how the bushing in the center is attached to the copper plate....it has the inner threaded bushing flange that comes from the inside. There is a washer on the outside I think I remember....and a very thin L-shaped crimp ring thet is swaged around the outside to keep this stack together. If you carefully take a dremel tool and grind away that crimp ring that is maybe 0.020" thick....the whol stack comes apart....and....if you can find away to put either a new crimp ring on....you can reuse the center threaded part.
I may post some detail pictures later.
So I disassembled a plate, used that for marking the center hole, the outer perimeter and the four screw holes.
The outer perimeter was easy. I simply cut that with very sharp scissors and duburred the edge with a diamond file. The center holes I literally scored and rescored with a sharp exacto until it popped out. Destroyed one plate getting impatient. 30 minute job to do it right.
The four small screw holes were a bitch. Destroyed the second plate using a drill bit that sucket the plate into a wad.
I found that a flat tipped cheap, 1/8: diamond bit from Harbor Freight in a dremel lubed with water will very quickly grind a perfect hole in brass, copper or very thin steel.
I attached the diaphragm back to the center hub on the first two by clamping them together and running a smooth bead of JB weld around them. Worked fine....lasted longer than the diaphragm did. More on that issue in a minute.
The third diaphragm I did a little surgery on the hub section with a dremel and a very skinny abrasive cut off wheel and made a shallow groove. I was able to clip it together with a thin E-clip. I say thin because I had to lap an E-clip on a whetstone to make it fit the groove. Then just sealed it with RTV. Worked fine.
But the gist is that I got about 25-35k miles out of each COPPER diaphragm...because they were COPPER. If they had been beryllium copper....they would probably still be in business. Annealed copper very quickly work hardens at the flex area and either cracks form work hardening or fatigue. Beryllium copper does not do this as readily.
So, I quite playing with making my own because Tangerine Racing came out with their kits to rave reviews. The price for what it is was reasonable. I always meant to pick up a couple of kits.....and now they are no longer made.... Rolling Eyes Sad ....and in a year or so I may finally have my car on the road again and may need one.
I have gotten better abilities and knowledge since then. I can now get Beryllium copper foil easily.
I can now make a more useful die with some radial ribbing (does not have to match just needs to be close enough). I can now buy Beryllium copper foil for a handful of dollars online. I now own my own crappy but useful 12 ton press.
I might make a few of these now to try my hand at it.
Ray
Pepperbilly
PostPosted: Sun Jul 13, 2025 3:10 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Wow Ray, you certainly have my attention! Good for you. Yeah, for those of us that want to keep our D-Jets in business we’re certainly in need of these diaphragms.
Bill
Jeremiah Berger
PostPosted: Mon Jul 14, 2025 5:49 am    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Funny that's exactly where my mind went when I started thinking about it. Seams like such a simple thing that could be replicated with some time and patience...but more importantly the right material.
That's all way to much for me as someone who is just getting a grasp on how the thing works though.
Hopefully you are successful or Tangerine starts making them again.
I have been reading and trying to understand the DJet in further depth and found these right ups very informative.
This guy is a Jaguar guy I think but especially knowledged with the DJet.Wich most of it is obviously applicable across model differences especially with parts like the MPS.
https://members.rennlist.com/pbanders/manifold_pressure_sensor.htm
I tried my local connections and don't think I have any available. Daniels says he possibly has some hidden in the attic of parts but think it's not a part he thinks he ended up with a lot of because he was rarely taking anything that wasn't already removed from vehicles and the fact this is mounted to the vehicle and not the engine in most situations he didn't end up with many.
Gonna try the other tomorrow when he returns from his summer break but that's a hit or miss for sure.
I'll keep my fingers crossed.
Jeremiah Berger
raygreenwood
PostPosted: Mon Jul 14, 2025 8:21 am    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Many years ago, around 1999 to 2001, I spoke to Brad Anders once or twice. At that point in time we were both searching for ECU connectors and trying to get around the IP lock that Amp had on the 25,000-ish connectors they had in stock.
We spoke about MPS details at one point. Brad Anders is the most knowledgeable person regarding D-jet electronic function and original design specification. If anyone at all is close to him regarding knowledge of inside the ECU and how each component works, it would be the guy that runs the Dr. D-jet site. He is mostly Mercedes oriented.
However, I do have some fundamental disagreements with Brad. And that does not mean he is incorrect in any way.
Brad approaches D-jet from an nearly strict engineers point of view. He knows what is going on in the ECU and what it can and cannot do. I have always known, even though I work in the industry that makes printed electronics and circuit boards....that I will never have the knowledge to be able to tweak or adjust or repair a system from the ECU function direction. So I worked from the outside (the engine) toward the inside (the ecu)
BUT..... having put probably 700,000 + hard miles on D-jet cars and worked and tweaked on them all along the way, ....I learned and have proven to myself (again if no one else) that just like the thousands of semi-analog equipment I have worked on in factories around the world.....one can do an awful lot of adjusting by tweaking with the mechanical parts of the engine that changes what the electronic part sees. I can change vacuum signature (and therefore what the MPS sees)....and/or tweaking with TS-1, TS-2, trigger points timing (not duration), vacuum leaks by design, mix and match of any of those sensors from other cars....and adjusting the MPS.
Keep in mind....like Brad Anders states, you cannot go beyond the parameters that the ECU is capable of but you can go a long way toward lying to the ECU about timing, temperature and vacuum. It only sees what the sensors show it. You can modify what these sensors do if you get creative. Because the ECU has ranges of voltage, amperage and induction that are set....all you can do is modify the what and when data is sent within those allowable ranges.
I actually learned a lot early on when I was tweaking parts in my very first 411....years before I actually KNEW how the system worked. I remember when I found out by accident....in high school no less....that when I accidentally knocked the hose off the MPS ....while driving at highway speed....and it greatly increased enrichment and output. I was already running lean because I had a fuel pressure problem I was working with. I knew I needed a new FPR but did not have the money that week.
But when at 65 mph I suddenly found the engine just wanted to climb in rpm and speed....at a very low throttle crack.....I was very quickly at 80 mph.
I slowed down and pulled over and it stalled a minute later. Opened the hood and saw that hose off and the lightbulb went off in my head. "Oh....so that's how that thing works!".
I went to a pet shop and bought a fish tank air valve and installed it in inline with the MPS to make an "engineered" adjustable vacuum leak. I found it amazing how much drivability could be adjusted in by simply changing an orifice to tweak the MPS response. I tried it with a Tee bleeding in outside air to the MPS vacuum and in-line to slow down onset of vacuum and release or vacuum. Two very different effects and very enlightening.
One of many calculated shade tree tweaks over the years.
But back to the diaphragm. This is one of those parts that in later years when I knew a lot more about machines, physics, chemistry and manufacturing...I thought would be super critical in tolerances and virtually impossible to produce differently than the factory to get a response that I could adjust to near factory tolerances.
Years later, I realized that there was actually quite a lot of variation in the diaphragm. As long as it's flexibility, tension/temper and range of motion were within what was required....most of the rest could simply be adjusted into the stack up in the MPS.
If it's too stiff like the stainless one....it does not have the range of movement and has poor response.
If it's too soft....like the couple of rubber ones I made just to see what could be done.....it moved too much and oscillation and was not stiff enough to drive the armature stack up even with very high vacuum.
But....there is a lot in between those two choices....that I knew could be worked with. I KNEW that because across many MPS that I have taken apart over the years....and measured the thickness of the copper diaphragm and counted the corrugations/rings....and noted the variations in the stamping and rudely tested flexibility with stacks of gram weights and a dial indicator....later I actually used vacuum and a dial indicatoron some....(there are variations in all of these).....many times in the same part # MPS......I realized that the copper diaphragm was NOT all that super precise.
It accuracy/precision....falls within a range. The rest is adjustment to spec.
In terms of adjustment....again from long experience when I had nothing else. There were no books but I had to do something.....so I locked down parameters, measured, tested while driving, adjusted, made notes....repeat, repeat, repeat.
This is another area where I KNOW what I have proven to work....and I diverge from what Brad Anders does (and again he is not wrong). Brad approaches adjustment of D-jet from the whats possible from the design point of view. He likes to adjust MPS to the known factory numbers he has discovered over the decades by bench setting with an induction meter and vacuum source. Then any extra tweaks while running are done with a wide band 02 sensor.
The problem with this method....if you read a lot of threads across a lot of forums.....is that while many have emulated this method....the success rate with good running....is about 50/50 to 60/40 successful.
Why is that?
It's because the rest of the engine is no longer similar enough to original factory to produce an exact enough vacuum signature. And/or.....there are some age related variances in the MPS, ECU, TS-1, TS-2 and TVS....and especially wear in the distributor and ignition.....not to mention changes in the fuel.
If you approach from the other direction.....the mechanical end.....make your engine, fuel supply and voltage as sound and uniform as you can (same for TS-1 and TS-2)....but get some variable resistors to have on hand in case you need to ballast/tweak......you get left with adjusting the MPS for drivability....by hand....by effect. Then you can check the 02.
The gist is that the function of the copper diaphragm is narrow and specific. It has to flex a limited amount at certain vacuum points.....but does not provide constant adjustment through the whole driving range. It is as some people say....a wide open throttle function. Yes it does that. But it also moves about the same distance for a very short amount of time (a second or less) when you crack the throttle off the line and when you have a shift point. It moves between the inner and outer stop...from one to the other...and does not float around in between.
It is not that precise of a part. It's adjustment is fairly precise.
When I finally realized it was beryllium copper and not copper....I also realized that making one of these is more subtle than making one of copper. Copper is a bit more...soft and elastic.
When pressing copper into a mold....more force and energy can and should be used. But where you press a rib or groove in with copper....it compacts the metal. It's partially work hardens it. If you do to much....it needs to be annealed to remain flexible and and not crack. That's not hard to do.
With beryllium copper.....it already comes "solution annealed". Its ready to go. But when pressing it to shape.....IF....you can avoid pressing too hard and deep and compacting the cross section (work hardening it).....then you do not have to anneal it. But if you do press it too hard.....the baseline annealed process is a lot more involved. Not what you want to do.
I believe....due to the very limited flex that this diaphragm needs to do....maybe 0.090" at the most.....that a straight up flat beryllium copper plate at the thinnest thickness I have found in these plates....about 0.003".....could work just fine. Ray
Jeremiah Berger
PostPosted: Mon Jul 14, 2025 9:57 am    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Definitely really in depth right ups on the djet and really helps someone like me get an initial understanding of the system.Ive also checked out Dr. D-jet jet as well .I truthfully until recently had no idea it was used in so many other models. Pretty cool to have some collective information from all over the world.
But your approach makes a lot of sense and I was considering that aspect when reading about tuning it to the exact stock specifications.
We all know that a 50 year old engine is no longer operating on all those same parameters, and a newly built engine is certainly not either.
In my case I have introduced a new cam better flowing exhaust slightly different compression etc. and to my understanding may have ended up needing to make an adjustment to the mps to obtain an optimal AFR.
And more on that later after I get the initial tuning all dialed in I plan on getting an AFR gauge and really dialing in the tuning.
I did get a vintage speed exhaust and I am very happy so far. It's has a bung on either side of exhaust for o2 sensor not sure which is better place to put it? but it is very nice quality and sounds good. pretty classic air-cooled sound not to throaty or crazy but sounds good.
So I'll have more questions on that later. One thing at a time though.
raygreenwood
PostPosted: Mon Jul 14, 2025 10:15 am    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
So...how is that exhaust working? Which model/part # is it?
Ah!...wait...I found it on their site:
UPC: 155-208-R3500
I have been agonizing for years about what to do when I finally get to my exhaust when I get back up off the ground. With all of the tuning and build changes I made over the years that really helped my 1.7L run much better than stock:
42 x 36 valves with unshrouding work
8.5:1 compression
Web #73 cam
40Kv coil, triple electrode plugs and points replacement module..much better grounding and voltage all around
Adjusted timing of trigger points
Too slack out of distributor and set up adjustable advance unit
Lots of little tweaks to TS-2, TS-1 and MPS adjustment
Much better fuel pressure stability...big difference
And....the final piece (but it did not really go far enough) was an Ernst muffler which was about 12% higher internal volume and made enough difference in tuning that it required a fuel mixture adjustment.
All in all this made about a 10hp difference and a LOT of throttle resonse difference.
But....the Ernst exhaust, as much better as it was than the other stock mufflers....was only enough better due to a slight internal volume icrease and bigger and more well distributed perforations inside.
It was still the same design as any other stock muffler inside. It still had unequal lengths left to right and still had some restrictions.
I have been designing a slip together and tack-weld 4 into 1 for years for my car.
I ahve also long ago taken note about what jake Raby said about the basic Thunderbird 4 into 1 header. That it was a pretty good improvement over stock (even though build quality is still shit). And...EMPI makes a stainless verion of it....but then you still have to find a muffler and it still has a length imbalance.
Or....from what Alstrup states, the Vintage speed exhausts are pretty good for smaller displacement engines. If it works well it could be so much simpler to just buy one of those. Ray
Jeremiah Berger
PostPosted: Mon Jul 14, 2025 3:46 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Gonna try to post in sections for some reason this post won't go through...
So far I haven't got to a really gotten much time behind the wheel since I've got these tuning issues I only took it out a couple times and stopped driving and running it since I figured out my mps was bad. But I definitely have gained power and it is overall happy and seems to be breathing well.
Like I said it has that classic sound but a little tad louder. The Quality is top notch and the welds are very nice. Quality hardware & installation. Looks wise, what you would expect for how much you are paying.I got mine from Heritage parts. They have it listed as so ..
Vintage Speed Sports Exhaust, Std Tailpipe, Bay Type 4 87089235
They also carry a type 4 sports dual tip one that is rated for 150hp...
Thanks for the feedback on the fine-tuning. Ive already been thinking about and looking into some of those things.
Jeremiah Berger
PostPosted: Mon Jul 14, 2025 3:54 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
(I figured it out .. apparently I can't use the degree symbol?)
1 Many things I've read about the 9590 cam and the djet working well and according to Jake I want to get about 14* at idle and limited to 28-32* total which is obviously not gonna happen without modification. So I'm definitely interested in hearing more about the adjustable advance...
2 I've been realizing that I probably want to consider a better coil. I actually have a crane cams fireball xr700 but Ive misplaced the coil over this whole thing and I set it up with a new German coil. But running into problems getting it started my spark seamed week so I put points a and condenser on, didn't turn out to be my problem but I just kept the points in after reading and being confused on which coil I needed to run with the fireball...
Not sure if that is a good points replacement to go with but if it is it always worked good before I took it off.. maybe you could help me figure out what coil I need to get? Online it says I need a 1.5 ohm coil or a 3 0hm coil with a ballast resistor. Electrical is not my thing... It didn't have a ballast resistor before. Looking online I can get a 1.5 ohm 40,000w flamethrower like I have on my bug for my petronix. Seams like this is what I want but I just wanna be sure
3 Fuel pressure. What do I want my start fuel pressure to be? Increasing the fuel pressure also enriches the AFR correct? A combination of the MPS band width the timing of the injectors and the fuel pressure correct? So is this something I wait for my AFR gauge and then dial in or do I want to check it and adjust it to start to a certain point as a first step? And then go on to other extents for enrichment if needed?
raygreenwood
PostPosted: Mon Jul 14, 2025 6:38 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
I will get more detailed at some point.
1. Yes, the web 73 wants right at 10°. Some need 12° but with good compression you should be fine at 10° with a 73.
I have a 9550. Probably one of the last Jake sold before going to 9590. I have not run it yet but IIRC he said about 12° at idle and idle at 900-1000 just before mechanical kicks in.
The 9590....if Jake says 14° he is probably right. But start at 12°. Tune it out, see how it idles and drives. It's nothing to add 2° more if needed.
This is exactly the type of tuning that the adjustable advance is made for. If you cannot find one but have a good single or double advance unit, I think I already have a how to for installing it. It will look and work like factory.
If it becomes an issue I can installed the nut insert for you. It takes about 15 minutes.
2. Crane is a good system. We should be able to look up what coil resistance it requires. Then just get a Pertronix 42kv coil in that resistance. They also have some excellent small footprint square coils. I will pull up my coil cheat sheet and post some choices.
3. Start at stock fuel pressure. Buy an accurate gauge. I have a list of accurate gauges as well. The key that really makes these more tuneable is very stable fuel pressure. Brand new pumps new or old are stable enough but with age the volume of bypass increases and we get some needle swing.
Each added 1 psi of change starting at 28 psi is 3.57% extra across the board. The injectors become unreliable and leak at 35 pai....So start at stock 28 psi, get everything smooth.....and only after finding out after all else that you need a little bump....then you can add 1 pai at a time up to ~33 psi. Ray
Jeremiah Berger
PostPosted: Thu Jul 17, 2025 1:14 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Well I have not had any luck locating any MPS units locally. I scoured eBay and found a few that might be decent options.
There is a sealed one epoxy and rivets. Same part # looks good .$140..but not vacuum tested ( says in the add that they don't have any way of testing it but they are a Porsche parts supplier selling multiple MPS's so that's kinda red flag)
https://www.ebay.com/itm/152965860924
Then there is an equivalent that is vacuum tested $295!
https://www.ebay.com/itm/267055175039
Then there is one that is remanufactured for $645!!!
https://www.ebay.com/itm/355599208833
I could put a whole new efi on the car for the price of a new OEM unit .. Really wish I could get one of those kits somewhere...
raygreenwood
PostPosted: Fri Jul 18, 2025 10:34 am    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
I can get you taken care of.
I have a total of four "E" series MPS. One is the one that wa adjusted to my l;ast engine with a web 73 and lots of tweaks and is in my car. The other three:
1. One E series with epoxy intact but it sucks air all the way through. It obviously has a cracked diaphragm.
2. One E-series that vacuums down but leaks down fairly quickly. I believe its actually the o-ring but I will check since all of these have screws and not rivets. This one has the expoxy removed.
3. One E-series that vacuums down great. Good diaphragm and seal...but it is a frankenstein. It is made of the rear section from one unit bolted to the front of another E unit. Yes, I have driven on this one and it works but will need adjusting....or you can pull the copper diaphragm out of it, adjust the center load screw and bushing stop to match what you have and install it in your MPS.
I also have some other MPS's that are worth a thought. I have a "C" and two "B" series. They are all from 1.7L 411.
The C and one of the B's has the epoxy intact. All have good disaphragms and hold vacuum. And...I have driven on both C's and B's with an E series system. Yes, they need a basic fuel mixture tweak and the outer full load stop adjusted (the big outer screw).
Too many sites, mostly Porsche purists and type 3 sites ....whose opinions do not really count Wink Very Happy ...because their letter codes mean different things as they have three complete different systems....say these different letter codes cannot be used/interchanged. That is incorrect. I have driven on these.
1. The diagphragm and aneroid chambers between all three of these letter codes...are identical.
2. The coil system and its resistance are identical.
3. The differences are:
A. The length or tension setting on the main spring in the snout at the vacuum end....and that is not always a given. The E uses the same snout length and spring as the B. The C has a longer and softer spring.
B. Because of the spring length, there "may" be a slight difference in main spring adjustment....but they were ALL used on 1.7L D-jet engines and not type 3 engines....so they will work with some adjustment.
C. The adjustment of the main mixture center screw and the outer full load stop are slightly different.
D. Inside of the MPS unit at the vacuum tube end...and you can only see this part if you remove the coil.... which requires desoldering ....is a leaf spring loaded part that can only be described as a vacuum limiter or brake.
Here is that part fully installed and held in place with a leaf spring
here is the part removed and you can see four little vacuum bypass notches. Brad Anders noted at one time that across VW and Porsche he has seen a handful of different variations of this little valve. Some with three notches, some with four, more or les vent slots etc.
Here is the valve itself. It is a little poppit valve. Its purpose is...along with the bypass notches shown above....to limit how fast the unit vacuums down going from enrich to lean.
The leaf spring part also governs how fast the unit vents its vacuum when you open the throttle.
This little part inside governs how fast the MPS vents and vacuum down (response time) taking off the line, at shift points and when slamming the throttkleshut on deceleration. A good portion of this valves purpose (from conversations 25 years ago with Brad Anders) is to damp pulsations in the MPS.
So, I will look inside of teh slowly leaking E series and if the plate is good and its just the seal I sill see if I can fix it. You can have that one to either use of steal the diapgrahm.
And....also if you want you can take one of these B series and try that and adjust it. If you do not use the B series just return it.
Ray
Jeremiah Berger
PostPosted: Fri Jul 18, 2025 12:01 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Thank you Ray, I would be very thankful for either option. If it happens to have a bad diaphragm Bill has offered to let me have the extra diaphragm that he has if I can't find anything. He has also sent me a copy of the Tangerine racing instructions Incase I end up going the route of rebuilding...I think I could easily make the tool. If I need to make adjustments to it then that is something I'm sure I can figure out.
I did mention that I messed with the screws and noticed the outer screw moved, but wasn't sure if I had moved it already...I may have slightly moved it, i think it is very close to where it was but I may end up needing to adjust my full load stop( outer screw). I know exactly how many turns on the inner one ....
raygreenwood
PostPosted: Tue Jul 22, 2025 11:18 am    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Sorry for the delay. I should have these in the mail tomrrow. I amd doing a couple of things to them that should help you. Let me 'splain....
1. As I noted, I have driven my 411 and 412 cars with great success using a late model "E" ECU and system using E-series, B- series and C-series MPS. Yes, the B and C took a few tweaks.
2. All three of these MPS's were used in 411 and 412 cars with 1.7L D-jet systems. Yes, there are small differences inside the ECU in the effective programming (and probably if I asked Brad Anders there are details of construction electronically)....BUT...as I noted, with regard to these three differently numbered MPS's side by side, outside of some spring tuning, vacuum damper tuning and adjustments.....they are all nearly mechanically identical.
By this I mean, the reactive parts....the aneroid chamber and the beryllium copper diaphragm are EXACTLY the same. Just how much spring tension is put on it and therefore how it reacts to vacuum and atmospheric pressure are tuned by the three adjustments on the back half.
But factually, they WILL all three run a 1.7L engine with D-jet and can all be adjusted to interchange with a good degree of performance.
3. Yes, there are other little internal adjustment differences in how they are built, keeping in mind that while each coil assembly is wound and designed to be the same resistance within a tolerance, there are small differences in each and every coil to the inductance that are adjusted for by the person building these on the bench at the factory with an inductance meter and scope.
There are differences early and late inside of these MPS's like what type of leaf spring bearing suspends the armature rod. Outside of longevity and smoothness these differences do not matter.....too much.
And, if you have ever fully dissected one of these that was too damaged to work with...you will see that in the different part numbers, the armature rod has a little cap with shims and a lock screw adjustment that allows a different spring pressure and depth adjustment setting if needed. A lot of that is probably part of the bench adjustment to get each MPS to a theoretical zero point.
These differences may or may not be a critical difference to these three series numbers that are essentially all driving the same exact engine...same size, same cam, same compression ratio, same heads, same valve size, same stroke....slightly different tuning at the ECU and MPS and ignition advance.
So...what I am doing to/with these MPS's before I ship them out to you:
First, both of these MPS that I am sending to you still have the epoxy plug on the outside. They are untouched...never been adjusted. If you don't mind...I am going to remove that epoxy but I will leave teh adjustments untouched.
I am taking the back section off of each one to do several things:
1. I am cleaning them out with circuit cleaner. You can tell which MPS's were the early ones that ran with engines that had oil bath air cleaners because they have oil inside of them from the oil vapors from the oil bath cleaner. Over time this gets acidic and is what can hasten the corrosion inside.
2. Once I have the back seperated and cleaned, before I remove the four internal screws to seperate the copper diaphragm for inspection (more on why in a minute).....
I have rigged up a quick way on the bench to find out how far the middle hex bushing is adjusted from the "inner stop plate" with the keyhole shaped hole in it.
In other words...I am finding out what the inner load stop adjustment difference is...if there is any...between the B, C, and E... MPS's that our cars use.
I have more than one of each series of MPS and will checking all of them to see if this inner stop position is the same in each series (meaning are all "B"'s adjusted the same?) or is this adjustment the same all three series B, C and E....or is this inner stop position different for each and every MPS no matter what series it is.....meaning it is a custom adjustment that is set on the bench at the factory to get the armature to coil "null"...at rest...position set nominally...meaning each is a custom adjustment.
I speculate:....that it "could" be custom for each and every MPS no matter the series...because the inductance of each coil could be that different....and this inner stop position is very important.....because....if the armature rod....at idle is too far in....you are too lean and you stall. If its too far out you are too rich and your whole enrichment range is thrown off.
I next "speculate": that if they are the same from MPS to MPS within a given discrete series...this would mean that they had to go through all of the coils and springs in a "lot" before assembly and seperate them into tolerance groups for each series...B, C or E. This is also quite possible.
I lastly "speculate":....that if I find that this inner stop setting is the same across all three series...B, C and E.....then the Germans did a damn great job of making the sub components, springs, coils etc...exactly the same and that all of the differences are simply the springs in the housing and the adjustments.
Why am I doing all of this?
Because....if we 411/412/914 people can find a SIMPLER way to take any of these three series of MPS and do just a couple minor starting adjustments to allow us to use ANY of them....it goes a LONG WAY toward having a lot more MPS's around to work with.
Its one of the issues I shake my head at with the type 3 guys...they had three separate versions of D-jet....with choices ranging from only one to maybe several MPS in each system version that would work with it.
These guys have to run around looking for "unicorn MPS's" to keep their cars running. This is also partly because early and late type 3 mps...had a single adjustment. There is not much they CAN adjust to make an MPS work with the early and late D-jet type 3 systems.
But....the middle years type 3 MPS's...are just like OUR type 4 MPS's and have three adjustments and a copper diaphragm....and I have factually used a type 3 MPS in my type 4 and yes it will drive....but really needs some serious adjustment compared to using a B, C or E model type 4 MPS.
An example of what I am finding when taking these apart and measuring:
I opened up and cleaned out an undisturbed B series last night. At first glance I was very hopeful that the middle hex bushing appeared to be snug right up against the inner keyhole stop plate....because if they are all that way from the factory that is REALLY an easy place to start. Just turn it in until its in contact...just touching.
Sadly, it turns out it is NOT snug up against the plate. It is standing off...maybe 0.003". I found this out by touching the center screw and the plate with my volt meter. No contact.
So, I set up a dial indicator stand to measure two things:
1. How far the inner hex bushing stop is from the inner keyhole stop plate.
2. To measure the outward stroke of the copper plate and how far it is from the big outer full load stop screw.
What I am to do with this information:
A. Once I have measured the inner and outer stop location on each series....B, C and E
B. I will remove the rear epoxy carefully and find out how many whole or partial turns from the inside the hex bushing is required to be turned to be at "factory" setting.
C. Once you set the inner stop you can set the number of turns for the outer stop plug.
All of this info will be gathered to tell someone ...."hey...if you have an E series system and all you have to work with is a B or C series MPS...here is how many turns you set up the inner hex bushing and the outer full load stop screw....to get that B or C as close as possible to the baseline of an E series....or vice versa...so at least you can start the car and make further tweaks with the outer full load stop screw and the inner fuel mixture screw.
More to come. Ray
Jeremiah Berger
PostPosted: Tue Jul 22, 2025 12:00 pm    Post subject: Re: Jeremiah's 73 412 restoration project Reply with quote
Awesome, that would certainly be a great help to keeping these cars on the road.
I will continue to wait patiently, I appreciate your help tremendously. Take your time. I'm taking a breather and enjoying summer a bit anyway.
Page 13 of 17
