early fusebox puzzle
human compass
human compass is offline
PostPosted: Sun Jul 13, 2025 4:44 pm    Post subject: early fusebox puzzle Reply with quote
Hey team, I'm hoping you can help me unify a fuse box issue to one circuit.
In my 84, my headlights, fuel pump, and rad fan is out. This happened after I had a no start issue, dropped the panel and found one of the line in pos wires was disconnected and after plugging it back I found that I had to leave the fuse box dropped to make the drive home or the headlights wouldnt stay on.
In the light of day I've inspected all connections to the fuse box and ground trees, and all appear normal. Everything was looking good so I bolted the box back up and lost all the aforementioned accessories.
I'm going to spend some more time tracking this down and was wondering if there was one circuit that could involve all three of these things??
I did quickly replace the ignition switch with no change.
Havent gone after it with a multimeter yet.
thanks electrical geniuses!
84 Westy Syncro- 3.3L SVX stage 2 tune,subaru gears 6speed with tbd, front locker, porche brakes x4, aux tank, radflo susp
Wellington
Wellington is offline
PostPosted: Sun Jul 13, 2025 8:01 pm    Post subject: Re: early fusebox puzzle Reply with quote
not an answer, but a direction and a bump.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7217370
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Jul 13, 2025 9:53 pm    Post subject: Re: early fusebox puzzle Reply with quote
In case it helps... I don't think the fuel pump is fused.
human compass
PostPosted: Mon Jul 14, 2025 5:15 am    Post subject: Re: early fusebox puzzle Reply with quote
thanks everyone.
yeah, the fuel pump part is a mystery. When I run 12v to the pump it works fine and the van runs fine, so the ecu is getting power. I tried swapping out the ecu for a known good and no change there either. fuel pump relay also swapped out for a spare and good. it's something under the dash....
jlrftype7
jlrftype7 is offline
PostPosted: Mon Jul 14, 2025 10:27 am    Post subject: Re: early fusebox puzzle Reply with quote
Looking the wiring diagrams, it appears that you have a Ign Switch [ 15 circuit ] that is pushed onto the incoming HOT side of the fusebox, on a terminal that is bridged with other terminals to provide fuse power . If that terminal, probably a Female pin, is spread open a bit, or loose on the mating male pin, then you'll have an open or loose connection.
With the key ON, to the normal RUN position, you should have 12 volts/battery power at Terminal 15 on the Ign Coil. Do you have that, consistently?
Wiring diagram shows Black/White wire at same Ign Coil Term 15 which is the feed wire for the Fuel Pump Relay COIL/CONTROL hot wire coming into the Fuel Pump Relay. So, if your Ign Coil is getting power, then the Fuel Pump Relay should get its power the Fuel Pump relay coil.
Load or 30, is another circuit
Ground Control of the Fuel Pump and Main Relay, also another circuit, but you already know this since you bypassed your wiring to get the fuel pump to run by directly powering it.
Get out your Multi Meter and see what readings you come up with.
‘84 Tin Top - Hilga....Auto
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Jul 14, 2025 1:22 pm    Post subject: Re: early fusebox puzzle Reply with quote
I see your comments but would suggest disconnecting all batteries then re inspecting the fuse panel very closely for any faults. e.g. a loose or suspect looking male connector on fuse panel.
Pics of parts in question would help but as a guess, it sounds like the wire in question is the one that connects starter battery positive to fuse box; it's the main positive source to the fuse panel; that wire is not fused. It can pull off where it connects to fuse panel when lowering the fuse panel. And, the insulator on that connector can suffer from heat damage. Look closely at the condition of that connector, feel if it's a loose or normal fit to male connector on fuse panel.
My guess is that leaving the fuse panel lowered while driving home enabled the wire from starter battery positive to make a better more stable connection to fuse panel.
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
human compass
PostPosted: Mon Jul 14, 2025 1:27 pm    Post subject: Re: early fusebox puzzle Reply with quote
Thanks so much! It's a subaru conversion, so no ignition coil and not quite sure where to test that the fuel pump relay is getting power. I do know the relay is located next to the ecu under the bench and that it's good. I'll have to start back tracking that circuit.
Some good news, You called it on the loose terminal. exactly as you said, it was splayed out and after correcting it, I know have radiator fan and headlights again!
I think I'm going to order a new fuse box and spend a fun weekend replacing that and cleaning up wires.
cheers!
human compass
PostPosted: Mon Jul 14, 2025 1:44 pm    Post subject: Re: early fusebox puzzle Reply with quote
will do, I think I'm going to take this opportunity to replace the 40 year old panel and clean up all wiring.
thanks!
Neil.
jlrftype7
PostPosted: Mon Jul 14, 2025 2:41 pm    Post subject: Re: early fusebox puzzle Reply with quote
cheers!
My Bad, I didn't see your engine swap in your vehicle description when I first posted.
Does the 3.3 have individual coils on each plug?, or a common coil like the 4 cyl Subaru engines normally used in engine swaps for the Vanagon?
human compass
PostPosted: Tue Jul 15, 2025 2:10 pm    Post subject: Re: early fusebox puzzle Reply with quote
No worries! It has individual coils. I think I must have an issue with switchable power getting to the relay since this happened while I was screwing around under the dash. I need to figure out where that switchable wire comes off the ignition switch and if it stops at the fuse panel. Again, changing the ignition did not solve the issue. At lease I have lights and rad fan now!
