maco70 Samba Member
Joined: March 16, 2011 Posts: 494 Location: Montréal, Québec
Posted: Sat Jul 12, 2025 4:11 pm Post subject: Engine lid foam |
Hi to all,
Is some of you have ideas for replacing the foam (full of dust and oil) under the engine lid ?
_________________ Martin from Montréal
1986 Vanagon GL full camper westfalia
(brown/tan interior) |
Vanagonsgoslow Samba Member
Joined: April 18, 2019 Posts: 120 Location: E Dorado Hills, CA
Posted: Sat Jul 12, 2025 4:13 pm Post subject: Re: Engine lid foam |
I would remove the foam and replace it with Dynamite adhesive backed sound deadener and heat insulation. |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1185 Location: PNW — Washington
Posted: Sat Jul 12, 2025 4:32 pm Post subject: Re: Engine lid foam |
Try the search feature for “engine cover insulation”. As always, others have attempted this project before you! _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
maco70 Samba Member
Posted: Sat Jul 12, 2025 5:15 pm Post subject: Re: Engine lid foam |
Very kind reply, thanks my friends !
Martin _________________ Martin from Montréal
do.dah Samba Member
Joined: August 27, 2015 Posts: 799 Location: Washington
Posted: Sat Jul 12, 2025 5:28 pm Post subject: Re: Engine lid foam |
You could also use a good dishwashing soap, I am a believer in JOY, do a really good cleaning on the underside of that lid. Rinse really really well. DO NOT USE A PRESSUREWASHER. Then let dry really really well.
Then, use a rubber spray, or a brush-on rubber under-coating.
Made my original stuff look new. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11093 Location: Oregon
Posted: Sat Jul 12, 2025 5:57 pm Post subject: Re: Engine lid foam |
do.dah wrote: |
Isn't Dawn Dish washing liquid soap the choice of animal rescue teams when there is an off shore oil spill?
If it's safe for cleaning oil off of Ducklings, it should be safe enough for cleaning that engine cover foam.  _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
do.dah Samba Member
Posted: Sat Jul 12, 2025 6:40 pm Post subject: Re: Engine lid foam |
Ahh, the power of advertising...
"Dawn" tends to donate for the publicity and goodwill.
And while I do use Dawn, if I really wanna degrease something, JOY is what I turn to.
I use to be involved in the maritime industry. Both engine crew and deck crew demanded JOY. Fine,,, but if they're wanting many cases of the stuff,, questions were raised about crew hiding sloppy practices in violation of US maritime laws..
Ducklings are traumatized, fragile living things. Engine deck lids,,, not so much...
67rustavenger wrote: |
do.dah wrote: |
If it's safe for cleaning oil off of Ducklings, it should be safe enough for cleaning that engine cover foam.  |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8405 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Jul 12, 2025 8:12 pm Post subject: Re: Engine lid foam |
Vanagonsgoslow wrote: |
I would remove the foam and replace it with Dynamite DYNAMAT adhesive backed sound deadener and heat insulation. |
Just to be clear. Semantics, semantics…
I’ve considered doing this for years but haven’t “pulled the trigger” yet.
BE CAREFUL OUT THERE, KIDS!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sun Jul 13, 2025 7:46 am Post subject: Re: Engine lid foam |
dhaavers wrote: |
- Dave |
I knew the spelling police would see that!  _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Icebox500 Samba Member
Joined: October 09, 2021 Posts: 226 Location: Louisiana
Posted: Mon Jul 14, 2025 4:35 pm Post subject: Re: Engine lid foam |
I’m confident he meant “Dyno-mite!”
Red Ryder wrote: |
dhaavers wrote: |
- Dave |
I knew the spelling police would see that!  |
_________________ 87 Westy 2WD “Van Geaux”
2.2 Rebuilt WB
AZ Transaxle + Peloquin Manual Transmission
GW lift springs, solar, Burley front disc, etc...
New Orleans, LA (previously CO, WA, and CA)
Past
87, 90 Westys
64, 65 splittys + various air cooled |
Kdj Samba Member
Joined: January 28, 2017 Posts: 272 Location: Naptown
Posted: Mon Jul 14, 2025 4:58 pm Post subject: Re: Engine lid foam |
Just did this on my engine swap. Mine was just falling into crumbs. If you are going for removal, know that there is a kind of chicken wire embedded in the foam. You will have to cut some of it. I used a flapper sanding disc on an angle grinder. It was a super dirty job wear eye and lung protection. I was amazed how thick it was. Used adhesive sound deadening pad to go back together. |
pbrown Samba Member
Joined: July 15, 2008 Posts: 495 Location: Seattle, WA
Posted: Mon Jul 14, 2025 6:04 pm Post subject: Re: Engine lid foam |
Dynamat does have a product that would work well. It's on my project list.
https://store.dynamat.com/products/the-hoodliner
The issue with the old stuff is that it's old. It starts to break down and sheds small foam bits all over the engine. _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2717 Location: Philly, mang
Posted: Tue Jul 15, 2025 4:45 am Post subject: Re: Engine lid foam |
i used a few cans of plasticoat and it works well. it absorbs into the existing foam and becomes a dense mass and deadens the engine noise considerably. _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
Posted: Tue Jul 15, 2025 8:52 am Post subject: Re: Engine lid foam |
dabaron wrote: |
i used a few cans of plasticoat and it works well. it absorbs into the existing foam and becomes a dense mass and deadens the engine noise considerably. |
I’ve thought about this, but no action yet. Glad to hear it can work! …after a good cleaning, I’m sure.
"The WonderVan"
GreggK Samba Member
Joined: May 17, 2008 Posts: 1019 Location: Colorado/Philidelphia
maco70 Samba Member
Posted: Sat Jul 19, 2025 6:40 am Post subject: Re: Engine lid foam |
Very good thread shared, many thanks !
Dynamat will be my way ! _________________ Martin from Montréal
khughes Samba Member
Joined: July 13, 2013 Posts: 881 Location: Phoenix AZ
Posted: Sat Jul 19, 2025 7:36 am Post subject: Re: Engine lid foam |
Mine was flaky and getting dusty so I coated the whole foam insert with several coats of spray on undercoating from FLAPS. Sealed everything up nicely and looks about the same as when I put it on. That was close to 20 years ago. _________________ '86 Westy FAS GenV Turbo (Marvin) |
