removing old bed liner
jtauxe Premium Member
jtauxe is offline
PostPosted: Sun Jul 13, 2025 1:55 pm    Post subject: removing old bed liner Reply with quote
The previous owner sprayed bed liner on the bed and inner side of the gates on my 1975 pickup. The black material is now dry and flaky, though stubborn in spots. Rust is working beneath it. I hate this stuff. I want to remove it all and repaint the bed properly.
I've tried aircraft paint thinner (works, but is messy and tedious), wirewheel on a grinder (effective but tedious), scraping (not effective), and finally a needle gun, aka a pneumatic scaler. We used these at sea to refinish ships. Noisy as all get out, and lots of vibration, and requiring a good compressor, but very effective, especially in the hard-to-get-to corners of the gates. Also tedious, of course. All methods are going to be tedious. Rolling Eyes
So before I continue with the needle gun approach, I have concerns about the finely-pecked surface that it leaves. Is this something to be concerned about?
I started a thread about it on the Body/Paint forum, with pictures, but it has attracted no responses.
PLEASE FOLLOW UP WITH RESPONSES IN THAT FORUM, so that I am not guilty of reposting the same thing in different places. Everett, feel free to lock this post in order to encourage people to go there. Smile
https://www.thesamba.com/vw/forum/viewtopic.php?p=10405818
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Jul 13, 2025 6:48 pm    Post subject: Re: removing old bed liner Reply with quote
you know, you gave me a ton of shit years ago about a comment I made and I'd much rather watch you suffer thru trying to remove it, but one thing we do have in common is hatred for spray on bedliner.
That said, how much are you willing to spend to remove it? That will depend on my next statement.
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
lil-jinx
lil-jinx is offline
PostPosted: Mon Jul 14, 2025 4:02 am    Post subject: Re: removing old bed liner Reply with quote
when removing liner from my wheel wells i used most of what you have tried plus a dremel oscillating tool which worked ok,but still a tedious job.
1968 Dune Buggy sold dec 2024
1974 parts bus
busdaddy
busdaddy is online now
PostPosted: Mon Jul 14, 2025 7:22 am    Post subject: Re: removing old bed liner Reply with quote
I'd avoid the needle scaler on the gates, it could distort the thin metal and gates are hard enough to get straight as it is.
Слава Україні!
jitbba
jitbba is offline
PostPosted: Mon Jul 14, 2025 8:05 am    Post subject: Re: removing old bed liner Reply with quote
Heat gun and scraper to use as a spatula
My other ride is a Zildjian
jtauxe is offline
PostPosted: Mon Jul 14, 2025 2:14 pm    Post subject: Re: removing old bed liner Reply with quote
Well, they're not very straight as it is. But point taken.
How about the resulting pitted surface for paintability?
I have some other metal that I will experiment with in the short term.
I'll be trying this soon. Have you done it yourself?
skills@eurocarsplus wrote:
...how much are you willing to spend to remove it? That will depend on my next statement.
OK. I'll bite. What is your next statement?
John
http://vw.tauxe.net
jitbba
jitbba is offline
PostPosted: Mon Jul 14, 2025 2:18 pm    Post subject: Re: removing old bed liner Reply with quote
Back in my bodyshop days, this was the best method to not distort the sheetmetal. Heat it up just enough to NOT be gummy, then it pried off relatively easy. Still labor intensive though.
my59
my59 is offline
PostPosted: Mon Jul 14, 2025 2:42 pm    Post subject: Re: removing old bed liner Reply with quote
You might look at peel away by Dumond. They make a variety of paint stripping products, including some for urethane based paints. It depends on what the bedliner was made with.
Ive used their peel away 1 for removing old lead based oil paint, but they have other formulations.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Jul 14, 2025 7:19 pm    Post subject: Re: removing old bed liner Reply with quote
how much are you willing to spend? serious question. 100 bux? 1,000?
Jake Raby wrote:
Brian wrote:
aeromech
aeromech is offline
PostPosted: Mon Jul 14, 2025 7:56 pm    Post subject: Re: removing old bed liner Reply with quote
I bought a needle scaler last year for the first time and I did a really ugly bus engine compartment. It worked great. That said, I did leave craters in the moderately strong steel that makes up the engine compartment
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
jtauxe is offline
PostPosted: Tue Jul 15, 2025 7:30 am    Post subject: Re: removing old bed liner Reply with quote
For the purposes of exploring the options, what would you suggest if I were to spend $100?
How about $1000?
John
http://vw.tauxe.net
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Jul 15, 2025 7:57 am    Post subject: Re: removing old bed liner Reply with quote
Do you have a local dry ice blasting business?
Robbie
www.airschooled.com
type241
type241 is offline
PostPosted: Tue Jul 15, 2025 8:37 am    Post subject: Re: removing old bed liner Reply with quote
I use a heat gun and NEW paint scraper or wood chisel(no nicks in blade). It will turn bondo and paint soft, then it just scrapes off. Keep the heat moving around, heat gun in one hand heating and scraping with the other. Goes pretty quick and no dust.
I just stripped a vintage wood door of 6 layers of paint with heat and scraper. First time on wood and it worked great.
Wildthings
Wildthings is offline
PostPosted: Tue Jul 15, 2025 10:00 am    Post subject: Re: removing old bed liner Reply with quote
Robbie
I was thinking the bed liner might just flake off on a 10°F winter's day.
airschooled
Air-Schooled
PostPosted: Tue Jul 15, 2025 10:11 am    Post subject: Re: removing old bed liner Reply with quote
Wildthings wrote:
Robbie
I remove tarboard/sitcky insulation sheets with speckled dry ice, but that's easy on the floors of bugs, rear cargo areas, etc. I don't think it would be as useful for a thin paint-like product on a vertical surface.
www.airschooled.com
