VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11198 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3349 Location: Memphis
Posted: Sun Jan 21, 2024 9:41 pm Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
Thanks for the links and photos! _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
glassbuggy Samba Member
Posted: Sat Feb 03, 2024 6:32 am Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
Saw this on Facebook under type three army's page. Tesla electric compressor. Might be what we need to eliminate the engine problem and make these old units functionable.
Posted: Sat Feb 03, 2024 2:28 pm Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
12 volt electric AC compressors are really starting to take off..
I've been watching the prices come down for years.
That's the route I plan if the trend continues.
They are almost as cheap as a serpentine belt kit now.
The biggest issue is the amperage requirements.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Tue Feb 06, 2024 5:22 pm Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
The post author mentioned having a separate 100ah battery alongside his regular Battery. If I can find it again, I will edit with better detail |
Posted: Wed Feb 07, 2024 5:23 pm Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
Found the post again, Here is the conversation. I edited it for content.
Tim Seward
"Tesla" electric air conditioning compressor installed! Tomorrow just wire it up and fill it with non-conductive R-134a refrigerant. Type 3 air conditioner unit inside is from Gilmore Enterprises, but everything else is custom from parts I put together. Total cost $1400 not including the 12v 100ah lio-ion battery to power the A/C that I'll be rocking under the back seat next to the main battery.
You'll need to get crafty with the condenser unit (radiator like unit). Im putting mine up front and putting the fan in the rim of the spare tire and punching exhaust holes in the spare tire cradle. This kind of shows the placement. The spare tire seals off the fan so you only need to make exuast holes. Im just popping the inspection cover off the front apron as an intake..
Q: What size alternator is needed to keep up with this system?
over 60amps. Id get the 90amp versions especially if youre running a moderate stereo system. If youre mixing your main battery Lead Acid (AGM) and li-ion as a secondary battery you need a battery isolator. I use the battery doctor. I run the system off my secondary battery to take the load off the main battery. The alternator only charges the secondary battery when the main battery is full and the secondary battery can not charge main battery or mess with your alternator. Anyway i have a 75amp alternator in my Brasilia that has this same setup. The AC runs off the secondary li-ion battery just fine.
Q: Where did you source the compressor?
I got a bunch of parts off ebay and amazon. I'll make a write up for people soon
Comment: Don't use Li ion with a stock alternator. It needs a special one for Li Ion. Chance for a nice fire up..
lol.. I am an electric vehicle designer. Im using a battery Isolator and this isnt my first rodeo I built this system before in my VW Brasilia. Thanks for the concern though. |
mr.vman Samba Member
Joined: February 06, 2016 Posts: 12 Location: Arizona
Posted: Tue Jul 08, 2025 5:38 pm Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
Trying to contact, Gilmour VW Air conditioning in Las Vegas. No response to phone call or, emails. I under stand there was an operation of Sean the owner, that was some time ago. Is he alright? Nice guy and knowledgeable when I talked to with him. Curious if and when he will be back? Thanks, Steve |
Stockholm VW Samba Member
Joined: July 02, 2020 Posts: 361 Location: California
Posted: Tue Jul 08, 2025 7:45 pm Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
mr.vman wrote: |
Sadly, I just learned he has passed. _________________ 1966 Volkswagen 1300 Sedan, 1641 cm³, 12 volt conversion, L456 Ruby Red, Platinum leatherette.
Posted: Thu Jul 17, 2025 4:30 pm Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
Don't want to, Hijack this thread. For engine driven AC compressors and kits; Gilmour AC no longer has a web site. Website is for sale. If you phone, mail box is full. Does anyone know what is going on? No more air cooled VW AC kits? Unfortunate, nice guy on the phone. Where to post this information? thanks, MrV |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33225 Location: Hot Arizona
Posted: Thu Jul 17, 2025 4:41 pm Post subject: Re: All about dealer installed a/c in a 61-67 beetle |
mr.vman wrote: |
It was "Gilmore", searching is "a little bit easier" with correct spellings !
See this: https://www.thesamba.com/vw/classifieds/detail.php?id=2744508
See this thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=802427&highlight=gilmore _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
