PYE Samba Member
Joined: June 14, 2010 Posts: 133 Location: Shropshire England
Posted: Fri Jul 18, 2025 9:59 am Post subject: Rear lock up |
| A week or so ago I reversed off my drive, when I came to drive forward my rear drivers side wheel was locked up, I reversed a bit and it freed up. Today I was driving down a gravel drive at about 10mph and the same wheel locked up. I reversed for a while then it was ok. I took the drum off, There does seem to be a lot more wear at the top of the shoes by the adjuster but everything else seems ok.??????? I put the drum half on and spun the axle in neutral and that seems fine. Not sure where to go from here. |
thom Samba Member
Joined: October 12, 2000 Posts: 6315 Location: Sacramento
Posted: Fri Jul 18, 2025 10:08 am Post subject: Re: Rear lock up |
Had you applied the brakes immediately before the lock-up? Or were you rolling when it locked up? I've had a brake lining come loose and wedge against the drum, locking up the wheel; in my case it locked in reverse and freed up going forwards. If it's locking up without applying the brakes, then it's either something loose in the trans or reduction box; I had a car once where the ring gear bolts had come loose and would momentarily wedge themselves - that was not a pretty teardown. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Clara  Samba Member
Posted: Fri Jul 18, 2025 11:59 am Post subject: Re: Rear lock up |
If your brake shoes have uneven wear, they aren't adjusted frequently enough.
Adjust the brakes every 3K miles, same interval as valve adjustment.
Lube the beam/spindles/all zerks at the same time.
tranny oil should be checked/topped up every 6K miles (or every year if driven infrequently.)
Is this a bus that is driven regularly? Or had it been sitting for months?
I had a tranny which would freeze up momentarily in long drives in hot weather. My solution was to replace the trans. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
PYE Samba Member
Posted: Fri Jul 18, 2025 12:13 pm Post subject: Re: Rear lock up |
| thom wrote: |
| Had you applied the brakes immediately before the lock-up? Or were you rolling when it locked up? I've had a brake lining come loose and wedge against the drum, locking up the wheel; in my case it locked in reverse and freed up going forwards. If it's locking up without applying the brakes, then it's either something loose in the trans or reduction box; I had a car once where the ring gear bolts had come loose and would momentarily wedge themselves - that was not a pretty teardown. |
I was rolling |
PYE Samba Member
| Clara wrote: |
I had a tranny which would freeze up momentarily in long drives in hot weather. My solution was to replace the trans. |
The bus is driven regularly |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 950 Location: Eastern north carolina
Posted: Fri Jul 18, 2025 2:39 pm Post subject: Re: Rear lock up |
| Possibly a wheel bearing going bad? |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1928 Location: Warren, PA
Posted: Fri Jul 18, 2025 4:15 pm Post subject: Re: Rear lock up |
Pull the other drum and see if you have a leaking axle seal. It can cause the dry one to lock up and grab. Backing up forces the brake pads back and allows it to roll. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2694 Location: Phoenix AZ
Posted: Fri Jul 18, 2025 9:00 pm Post subject: Re: Rear lock up |
Broken spring, shoe pin or maybe shoe lining separated from its backing
Sounds like the "front" shoe is catching and getting wedged then freeing up when reversing _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15483 Location: Casa de Oro, California
Posted: Sat Jul 19, 2025 6:10 pm Post subject: Re: Rear lock up |
| PYE wrote: |
| Today I was driving down a gravel drive at about 10mph and the same wheel locked up. I reversed for a while then it was ok. |
Locked up like totally skidding?
I had a broken tooth in the top RGB and it would do that until a final catastrophic failure. |
