veedubbed314 Samba Member
Joined: October 19, 2005 Posts: 9 Location: Atlanta, GA
Posted: Fri Jul 18, 2025 12:07 pm Post subject: Door Seals |
This may belong in the stupid question section, but I have a 68 that I am just getting started on the resto of, and I really want to get the door seals replaced since the car sits outside mostly for now.
My question is, are all door seals the same? Or are the ones from WW better than the rest, or is there another company that have better door seals that are better?
I want to buy full door reseal kits with the windows felt and scrapers as well as door seals.
Ive been out of the aircooled game for over 20 years, but its so good to be back!! Ive got some catching up to do! |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2044 Location: Wichita, KS
Posted: Sat Jul 19, 2025 6:16 am Post subject: Re: Door Seals |
I got the “German” door seals from WW about a decade ago, and think that they are of excellent quality. They have held up well through the years, without any discernible distortion or hardening so far — I like them very much!
Some people prefer the “Brazilian” seals however, as they reportedly tend to allow the doors to close a bit easier initially. Not sure how well they hold up over time though — may harden and crack after a few years (?). _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4149 Location: Georgia
Posted: Sat Jul 19, 2025 7:22 am Post subject: Re: Door Seals |
I used West Coast Metric for all the rubbers on my Ghia.
They were installed in 1994 and are still in great shape today.
The only issues I’ve had are with the door wedges which crumbled about a year ago and the trunk seal which is showing signs of dry cracking in the corners.
Not bad for 30 years though. _________________ Volkswagen!
(Compression 8.7:1) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33083 Location: Hot Arizona
Posted: Sat Jul 19, 2025 10:14 am Post subject: Re: Door Seals |
jeffrey8164 wrote: |
Not bad for 30 years though. |
Doesn't WCM rubber have lifetime warranty? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1413 Location: San Diego
Posted: Sat Jul 19, 2025 1:24 pm Post subject: Re: Door Seals |
Cusser wrote: |
Doesn't WCM rubber have lifetime warranty? |
For those particular seals, WCM is selling Brazilian and German products at this time. I think the warranty applies to the products they make themselves. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Mon Jul 21, 2025 8:18 am Post subject: Re: Door Seals |
I just ordered the WCW "german" door rubber. I didnt do the full kit, just the main seals on the outside of the door. Ill have to do the rest of the window stuff later. I really just need to make sure the door seal now, the windows seal OK for now.
Thank you everyone for the input! |
Chinaclipper Samba Member
Joined: October 03, 2019 Posts: 810 Location: Somewhere in the great Midwest
Posted: Fri Jul 25, 2025 6:54 am Post subject: Re: Door Seals |
WCM and WW both have, I think, good rubber seals, altho I have found there is still a significant "break in" period they don't tell you about when you install the door seals.
It takes about a week or longer to "break 'em in"; until then you will find doors have to be "firmly" shut until they do.
Hehehe first time I replaced the seals I thought I had bought the wrong ones, but then, sure enuff, they "broke in" and now they're like butta' _________________ China Clippers Official 1971 Super Beetle Project!
https://www.thesamba.com/vw/forum/viewtopic.php?t=728089&highlight= |
bomberbob Samba Member
Posted: Wed Jul 30, 2025 8:14 pm Post subject: Re: Door Seals |
There is a difference between the german seals, and the Brazil variety. I should have taken photos of the cross sections before I did my doors.
German seals are solid, and have more seal material in them. I tried to install new German seals, seals prevented the doors from shutting. I even tried taking a razor and cutting them up to remove material (ruining them) to get the door to shut. I finally gave up and ordered the cheaper Brazilian seals. They appeared to be hollow, where the German seals were solid. Put the Brazil seals in, door shuts fine. Possibly later when I have time I will circle around and attack this again, but for now I am running these cheaper squishy seals. _________________ 1968 Beetle torn apart again
1990 Jetta GLI megasquirted, burning E85 (currently in storage)
2004 Jetta turbo GLI
Marion, Iowa |
talljordan Samba Member
Joined: January 10, 2012 Posts: 1099 Location: San Francisco, CA
Posted: Wed Jul 30, 2025 9:31 pm Post subject: Re: Door Seals |
Bob that is interesting to hear. Where did you order your brazilian seals from? I have been SUFFERING with my german seals. Can not get the doors to close unless I SLAM them. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
Posted: Thu Jul 31, 2025 6:03 am Post subject: Re: Door Seals |
talljordan wrote: |
Bob that is interesting to hear. Where did you order your brazilian seals from? I have been SUFFERING with my german seals. Can not get the doors to close unless I SLAM them. |
talljordan:
Pse refer to my post above. It takes a while for the seals to "seat" ..
"Patience my liege...".....I was there once.... _________________ China Clippers Official 1971 Super Beetle Project!
Posted: Thu Jul 31, 2025 8:34 am Post subject: Re: Door Seals |
This is all good to hear. My seals now are so bad the door has about 1/4 or more of play when closed! The seals are just mashed and rotten. Since I live in the southeast, humidity and moisture can be an issue, so I want to keep the interior as dry as possible for as long as possible. I already got the seals from WCW, just need to install them. I got some silicon spray and a plastic putty knife to help make the job easier(hopefully). |
Posted: Thu Jul 31, 2025 9:23 am Post subject: Re: Door Seals |
Chia.
It's been 3 months, I even trimmed away at the edges of the seals. The issue persists.
It's time for me to try different seals. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Thu Jul 31, 2025 11:14 am Post subject: Re: Door Seals |
I don't want to point anybody at a particular supplier, but I got mine at J Bugs. Brazilian seal for left door is $16.96, German seal is 48.41. So you get what you pay for.
Description of the seal on their website says "This is the best Brazilian seal available, but does not offer the same quality or lifetime warranty that you get with the German seal. This seal is recommended for short term use."
All I can say is I fought with the German seal for hours, even going so far as to start cutting seal out to try and get the door to close without slamming it hard. I gave up. The forum experts will say the door needed aligned, possibly so.
Prices are as of right now, when the tariffs kick in prices will probably go up. Get em while they are hot. _________________ 1968 Beetle torn apart again
Marion, Iowa |
