Low oil pressure after front seal change etc.
aztecair
aztecair is offline
PostPosted: Sun Jul 20, 2025 3:01 pm    Post subject: Low oil pressure after front seal change etc. Reply with quote
Hello VW gurus etc.
My 1971 dual port motor is giving me a fit, I pulled it for an unstoppable front seal leak and did the following while I was in there -
1. drilled a 3/16" hole in the case at about 6:30 position behind the front seal
2. Before I installed the new seal, I cut about 3/4" off of the spring and reattached the ends.
3. Installed the seal ALL the way in to the stop in the case
4. while I had it out, I reset the end play from a whopping .015", down to .004"
5. Adjusted the valves
Sounds pretty good, eh? - Well now the thing is running very hot, and and scaring me to death as I drive it around with the oil light on after about 5 minutes of running - and forget the freeway!
I'm stumped, could resetting the end play have changed the distributor timing at all?
It runs purfect, just hot as hell -
What say you, oh great minds of the Samba?
busdaddy
busdaddy is offline
PostPosted: Sun Jul 20, 2025 3:13 pm    Post subject: Re: Low oil pressure after front seal change etc. Reply with quote
Without a doubt.
Слава Україні!
SGKent Premium Member
SGKent is offline
PostPosted: Sun Jul 20, 2025 3:29 pm    Post subject: Re: Low oil pressure after front seal change etc. Reply with quote
why did you drill a hole. The case has a drain for the front oil seal already.
As Mark suggested, check your timing first.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Jul 20, 2025 6:20 pm    Post subject: Re: Low oil pressure after front seal change etc. Reply with quote
how many threads did you post?
https://www.thesamba.com/vw/forum/viewtopic.php?t=804543
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jul 20, 2025 6:28 pm    Post subject: Re: Low oil pressure after front seal change etc. Reply with quote
Looks like 3 Rolling Eyes
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
aztecair
aztecair is offline
PostPosted: Sun Jul 20, 2025 7:16 pm    Post subject: Re: Low oil pressure after front seal change etc. Reply with quote
Thanks folks - I will check the timing, I tend to agree, and hope and believe this could be my demon !
RE: Why did I drill the hole? I believe the drain slot (passage) to be clogged probably from sealant during assembly - I had changed the seal at least twice and can't stop the leak, so this is my "Hail-Mary" having read a lot of folks doing just that - drilling the hole - GoWesty even makes a tool to do it for type 4 motors, I have to admit it took me a lot of thinking to 'bite the bullet' and drill it - scary, to say the least... I'm still hoping that was OK to do - I'm not in the mood for new short block $$$$
SGKent is offline
PostPosted: Sun Jul 20, 2025 8:42 pm    Post subject: Re: Low oil pressure after front seal change etc. Reply with quote
you also need the o-ring between the flywheel and crankshaft. Is that good? Have you tried a dye in the oil and black light to see exactly where it is leaking from?
Wildthings
Wildthings is offline
PostPosted: Sun Jul 20, 2025 9:25 pm    Post subject: Re: Low oil pressure after front seal change etc. Reply with quote
You can not tighten the endplay on an engine with a loose thrust bearing, assuming the thrust bearing shell is loose in it's saddle (which is very likely) if you try and tighten the end play you may seize the crank to the bearing.
