edbee Samba Member
Joined: October 15, 2009 Posts: 52 Location: BC, Canada
Posted: Tue Jul 22, 2025 5:48 pm Post subject: Syncro: questions about bearing-like noises |
Hi,
I have a '91 syncro. The transaxle and front diff were rebuilt by AA sometime around 2011 but I have only put maybe 30,000 miles on it since then. The vehicle is used primarily for summer trips. After running it for about 1000 miles I refilled the transaxle with Swepco 210.
Recently I noticed 2 new noises. First sounds like a wheel bearing noise (noticed this one late last summer before cancelling insurance for winter, seems to be getting worse as time goes on): seems to be present anytime vehicle is moving, engine running or not. It doesn't change when turning or braking and I can't hear anything with a stethoscope with all 4 wheels jacked up and listening at wheel bearing housings. So, I don't think it is a wheel bearing even though it sounds similar to wheel bearing noise. (front and rear wheel bearings were also new about 30,000 miles ago). Seems like it is something that moves at wheel speed: front diff maybe, output shaft(s) of transaxle (either where power goes out to rear CV shafts or where power goes to driveshaft to front diff)? Any suggestions on a likely culprit?
The other noise I just noticed is a soft whirring noise I can hear at idle when the clutch is out. When I push the clutch the noise goes away. You can hear the noise in this video:
Any suggestions on what is likely responsible for that noise? I think this noise is relatively new.
I wanted to check the transaxle drain plug magnet for metallic debris and read that if I parked the van on a steep incline facing downhill (such that the floor was at at least a 13 degree angle) I could pull the drain plug without oil coming out. The plan was to pull the plug and photograph the metallic bits stuck to the magnet. That didn't go exactly according to plan as when I opened the plug oil started pouring out. I was able to stop it with my finger but taking a good photo of the plug/magnet with oily hands while laying under the vehicle with my finger acting as the drain plug was a bit challenging
Sorry the photo isn't well focused but the debris was all very fine particles that seemed to almost soak into the cloth I used to clean the drain plug before putting it back in. I think I lost maybe a cup of oil.
We are supposed to leave for a short westy trip in a few days and given the lack of chunks of metal on the drain plug magnet, I am inclined to go (can't change trip dates, would have to switch to tent camping if we left westy home). Hopefully I won't regret my decision. _________________ 1991 Syncro Westfalia - Bostig Zetec
1989 Syncro Doka - Volvo powered
other misc vehicles including a '46 M16 1.5 ton truck (Studebaker) |
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 2113 Location: Huntington, WV for now
edbee Samba Member
Posted: Wed Jul 23, 2025 9:51 am Post subject: Re: Syncro: questions about bearing-like noises |
Ceckert64 wrote: |
The clutch in/out noise that comes and goes is the mainshaft bearing. I’ve had a lot of issues with it on my cars and that’s the exact symptom. |
Thanks Ceckert64. I will need to learn about transaxle internals to see what might be possible sources for the noise that sounds like a wheel bearing noise. I am still hoping it might be something other than the transaxle but I suppose if the mainshaft bearing needs to be serviced then I'll need to pull the transaxle anyhow.  _________________ 1991 Syncro Westfalia - Bostig Zetec
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18736 Location: Retired South Florida
Posted: Wed Jul 23, 2025 10:40 am Post subject: Re: Syncro: questions about bearing-like noises |
How short a trip? Being a syncro, I’d want to do some more investigating. Why? Because the parts are rare and expensive when you find them.
Sounds are indications of something not being happy. We had to cut a trip short because 4th gear was sticking engaged. No noise, but knew something was wrong. Decided to turn around. The logic was the closer to home, the smaller the logistics problem.
A short trip say 2 tanks isn’t likely going to add much to the damage. If the wheel’s aren’t rocking and the noise isn’t getting worse, you’re probably fine. Turn around if it gets way worse. Fingers crossed for you. That’s a bigger Christmas tree than I’d like to see. Maybe change the fluid and check when you return. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10634 Location: Western WA
Posted: Wed Jul 23, 2025 1:04 pm Post subject: Re: Syncro: questions about bearing-like noises |
I had trouble, lots, with 10-20,000 mile gearbox rebuilds back in 2012.
Thanks for reporting that oil still comes out at 13° nose-down.
Another guy reported that oil came out at 14.5° in a 2wd.
It helps a lot to get feedback on tips.
Maybe you have to "wait a bit" for the oil to flow forward ????
Maybe need a carrot or something (or a 1" rubber plug) to quickly plug the hole, so you only lose a little.
I was hoping there would be more discussion to refine the tip, but it didn't come so you're 'the guy'.
Is that magnet afro just 1000 miles since the last oil change?
I suppose yes,,,, since you wanted to check the magnet without draining the oil.
30,000 interval is much too long.
Don't wait 30,000 miles to change gear oil on a rebuilt.
Rebuilts can have a LOT of really old parts re-used, and you could un-knowingly be driving thousands of miles with a toxic wasted dump circulating inside your gearbox, further reducing the possible lifetime.
That's an awful lot of metal to see after only 1,000 miles.
That looks like a 15,000, or even 30,000 mile afro.
That volume suggests a bearing is coming apart fast.
Or there was a lot of metal still in the gearbox that didn't drain out last time.
But noise suggests that anyway, and the magnet confirms it.
Driving that trans is ruining parts that (perhaps) could be re-used in the next (better?) rebuild.
Anyway I think you got your answer..... a bearing or something is shedding steel fast.
Is the oil black already? Or is it just dark blue Swepco? _________________
....KTMs, GasGas, SPOT mtb |
edbee Samba Member
Posted: Wed Jul 23, 2025 4:31 pm Post subject: Re: Syncro: questions about bearing-like noises |
Sodo wrote: |
Hi Sodo, thanks for the feedback. My phone said the floor of the van was at 14 degrees.
I should have been more clear: that drain plug/magnet had not been removed for somewhere in the neighbourhood of 25 or 30 thousand miles (although that is a bit of a guess) prior to yesterday when I took that photo. After the transaxle was rebuilt I ran it for maybe 1000 miles , then put the swepco oil in and hadn't done anything to the transaxle until pulling that plug yesterday. The oil itself still has a nice red colour.
The trip we are about to leave on is only about 250 miles round trip. (local camping). The first camp spot is only 55 miles away so my current thinking is I see how things go on day one and if the noise gets any worse we come home after that first campsite and maybe load up the F250 with a couple of tents and start the trip over again. And I suppose if things get really worse, I have BCAA RV coverage so I should be able to get it flat bedded home for free or cheap. I hope it doesn't come to that. _________________ 1991 Syncro Westfalia - Bostig Zetec
