Yatabata Samba Member
Posted: Wed Jul 23, 2025 8:43 pm Post subject: 1965 1200 40h flywheel question |
I have this old VW engine that I have rebuilt and was getting ready to do the end play but the flywheel I have won't fit. when I got the engine the flywheel wasn't on it and the guy gave me a 36h that definitely wouldn't fit. I asked if he had a later one with the 4 8mm dowel pin holes that was also a 6v. I got it but it turns out it's for a later VW with a smaller crank end. my 40h crank end measures 2.108 diameter. The later flywheel inner opening with the O-ring measures 2.098 diameter. no go so what flywheel I'm I looking for then? |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6146 Location: 37.5N 77.1W
Posted: Thu Jul 24, 2025 7:00 am Post subject: Re: 1965 1200 40h flywheel question |
I did a quick check. Main bearings on the crank are the same for 1200s and 1600s. Have you tried to get the flywheel on without the dowel pins? That might be the 'hold up'. _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1024 Location: South Florida
Posted: Thu Jul 24, 2025 8:46 am Post subject: Re: 1965 1200 40h flywheel question |
Yatabata wrote: |
Sounds like you want the 6v flywheel that has a "step"
Posted: Sat Jul 26, 2025 12:25 pm Post subject: Re: 1965 1200 40h flywheel question |
yes you were correct on the 6v flywheel with the step. I found one on FB marketplace that was given to me yesterday on the old 40h engine he had that is locked up. parts are missing on it but will take apart someday down the road and go through it. You never know on these if they were rode hard or just had one issue and sat to the side for years. |
