Jeremiah Berger Samba Member
Joined: September 16, 2018 Posts: 173 Location: MAINE
Posted: Thu Jul 31, 2025 6:12 am Post subject: Re: Jeremiah's 73 412 restoration project |
Ok so I had no idea that there was an adjustment on the vacuum canister? Looking into the advance adjustment and realized I already have an adjustable can and had no idea. Unfortunately I tested it again out of curiosity and although it functions and move the advance like it should, it does not hold vacuum. It drops within 5 seconds. So I'm guessing that mean the vacuum diaphragm is shot and I need to replace the whole thing? Or can that be repaired?
If I do need a new vacuum unit is there options of Wich ones I can make work?
I found the thread covering the how to on making an adjustable one with a non adjustable unit. I don't seam to see any adjustable ones like mine available. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23209 Location: Oklahoma City
Posted: Thu Jul 31, 2025 1:52 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Jeremiah Berger wrote: |
Yes, the canister is shot. I have been inside of a few., at some level they could be fixed....if I could find a suitable membrane (more than a few candidates for materials).
Crimping it back together and keeping it looking good are the difficult part. At one point in time I was really looking into rebuilding my own.
Then I realized that there are a handful of part #s similar enough except for some having excessive advance. This is why the adjustable one comes in handy.
I had to do some shopping around for thin wall panel inserts. I found a few that will work and also look professional and factory with no leaks.
Ray |
Posted: Thu Jul 31, 2025 2:16 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Ok I found this one available new that says it was for type 4 . I'm not sure if it would be compatible?...it a single vacuum.
https://mrfiat.com/products/volkswagen-type-4-vacu...98-2079-01
There's also a similar one on cip1 and they are both reasonably priced.
There's also some used units on the samba.
If I can find a reasonable priced vacuum unit then I would attempt to add the adjustment screw.
But if I have to spend hundreds getting this one working I would definitely consider just getting a 1-2-3. |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 1090 Location: Seattle, Wa
Posted: Thu Jul 31, 2025 5:29 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Guess I got lucky with mine because it still works after all these years. It is the original without any adjustment…no screw. I always wondered why some came with the adjustable screws and others like mine did not? We have same year automatic 412s with the same engines.
Bill |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7508 Location: Houston, Texas
Posted: Thu Jul 31, 2025 5:40 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Those bulbous units come from China. I've never liked them.
I have original Bosch ones made in Mexico so maybe that is why.
You have to be careful buying vacuum canisters like that. They are very generic. Although vacuum canisters look the same they have different properties.
Which distributor do you have? _________________ www.vwnos.com [email protected]
Posted: Fri Aug 01, 2025 4:08 am Post subject: Re: Jeremiah's 73 412 restoration project |
Pepperbilly wrote: |
Bill |
I think I read somewhere that the distributors where fit by the dealership? Maybe Ray can chime in on that. I believe it was something he wrote. Or if not maybe they where different for places with emissions regulations? |
Posted: Fri Aug 01, 2025 4:41 am Post subject: Re: Jeremiah's 73 412 restoration project |
heimlich wrote: |
Which distributor do you have? |
Yeah I kinda figured that, you have to be careful buying just about any aftermarket part these days because that's pretty much always the case.
Only reason I consider it is wwith something like this it seams like your options are not many.Just seams silly to put a used one in and hope it's not on its last leg. And OEM ones I've seen are so expensive if rather put that money to a 1-2-3. Considering the 1-2-3 because not only can I fix this issue, I solve my advance issue potentially It also cures any issues I may have or get with my trigger points. And upgrade from points to electronic ignition.
But considering I'm not made of money like I wish I was ...I need to try to find a reasonable priced vacuum unit first if I can and make it adjustable.
distributor part # 022905205 |
heimlich  VWNOS.com
Posted: Fri Aug 01, 2025 6:44 am Post subject: Re: Jeremiah's 73 412 restoration project |
What's the letter(s) at the end?
You mentioned you have the trigger points. Do you have them in the side of the distributor? _________________ www.vwnos.com [email protected]
Posted: Fri Aug 01, 2025 9:11 am Post subject: Re: Jeremiah's 73 412 restoration project |
heimlich wrote: |
You mentioned you have the trigger points. Do you have them in the side of the distributor? |
Sorry I didn't see that the first time...it's P
022 905 205 P
Or Bosch # 0 231 172 019
The armature on the vacuum has 917 stamped on it. Yes it is a trigger points in the distributor, for a d-jetronic . |
heimlich  VWNOS.com
Posted: Fri Aug 01, 2025 9:28 am Post subject: Re: Jeremiah's 73 412 restoration project |
heimlich wrote: |
022 905 205 P
I would not purchase a rebuilt unit or pay to have your unit rebuilt unless you want to keep it original. 123 is the way to go.
If you need the small fiber washer that goes on the inside let me know. I can stick one in the mail for you.
If you put that vacuum advance on your car you will need to pin it so that it doesn't advance too much. Your stock distributor calls for 4 degrees (8 at the crank max). The one you pictured in a stock setting can give 6 degrees (12 at the crank). So you will want to make sure under full load and rpm you are not going over the limit and doing any pinging/etc.
I was trying to find a used canister I could send you but nothing matches the one you need. If you want a used one you can pin it to stop it from over advancing.
Keep in mind when it comes to some of these parts you are competing with Porsche people which will pay 3 times the price of VW. I'm sure you've already witnessed this.
Here is the advance curve of your distributor:
Posted: Fri Aug 01, 2025 9:57 am Post subject: Re: Jeremiah's 73 412 restoration project |
heimlich wrote: |
heimlich wrote: |
022 905 205 P
I actually emailed you too . So yes I'm actually trying to achieve a whole different curve at this point because I rebuilt it with a new cam and it now wants 12-14@ idle so I was hoping to get my adjustable unit replaced or find a unit to add an adjustment screw so I can limit the advance. That's my ultimate goal.Im looking more at the 123. Thanks for looking. |
heimlich  VWNOS.com
Posted: Fri Aug 01, 2025 10:42 am Post subject: Re: Jeremiah's 73 412 restoration project |
That might be possible. I think you could take one of the very early SVA vacuum canisters and attach it. That would give you a whole bunch of advance at idle. You would need to limit it.
The problem is with all that advance at the beginning you will get it at the top end too. Your mechanical will be added to it. In the graph I showed you get 27 degrees. Add 12 to that and you are at 39 without any timing adjustment. _________________ www.vwnos.com [email protected]
Posted: Fri Aug 01, 2025 11:05 am Post subject: Re: Jeremiah's 73 412 restoration project |
My next question is am I going to be happy with one of the 16 preset curves that come pre programmed on the 123? You can look at the chart on the type 4 store if you look at the product description...
Would be awesome if I could just get a tune or tune+ version Wich let's you set the curve to exactly what you want but the one that is compatible with the djet is the Switched version.
I am only starting to understand advance curves and I'm not sure exactly what I am gonna want with this cam. I'm also not exactly sure how to make sense of the chart. I read somewhere that the advance starts at the same point on all them which is 12* but I'm not sure? Or they start at 2* but plus the 10* static that you start it at.Its kinda confusing seaming. Wich obviously you can get more by adjusting static but that effects total.So I'm not sure if the total advance on the chart is your actual total advance or you add that to the static you start at. Obviously this can all be checked with a light but I wanna know that it will work before I buy it ..
On that note how on earth is type 4 store charging $225 more for the exact same part as heritage parts?$625 vs. $403 Am I missing something here?
Ray, I know you have considered getting a 123. Have you looked at the preset curves and how they might play with upgraded cam djet etc. Do you have an opinion on wether this would be a good distributor for my setup and cam? |
heimlich  VWNOS.com
Posted: Fri Aug 01, 2025 11:08 am Post subject: Re: Jeremiah's 73 412 restoration project |
Does 123 have a programmable unit that has the trigger points? You want the programmable one.
Share the links and I can look at it for you. _________________ www.vwnos.com [email protected]
Posted: Fri Aug 01, 2025 11:18 am Post subject: Re: Jeremiah's 73 412 restoration project |
heimlich wrote: |
Share the links and I can look at it for you. |
As far as I can tell they do not. When I first started looking I thought that was gonna be an option but it seems that the only model with hookups for injectors is the Switched version.
https://lnengineering.com/products/aircooled-porsche-parts-and-upgrades/123-ignition.html?mode=list |
heimlich  VWNOS.com
Posted: Fri Aug 01, 2025 1:15 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Hmmm? Interesting. The only question I have is it says in the description that it has an angled distributor cap.
I'll do some more research later .
Thanks |
heimlich  VWNOS.com
Posted: Fri Aug 01, 2025 1:19 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Ask Ray about it. I seem to recall mentioning something like this to him before and the reply wasn't as expected. _________________ www.vwnos.com [email protected]
Posted: Fri Aug 01, 2025 5:53 pm Post subject: Re: Jeremiah's 73 412 restoration project |
I decided to give fixing this diaphragm a try and I am happy with the results. Works like it should and should probably last a little while...
I opened it up by grinding away the lip and leaving four tabs to be able to clamp it back shut.
I found a small pin hole/burn hole right at the vacuum inlet. I used flex tape to add a layer to the entire diaphragm and than used a razor to cut out the inner circle and stretched it the rest of the way over the center piece.
The results are an entire lamination of the original diaphragm and it stretches and works like original.
Holds up to 15hg with no leak down whatsoever...
I put some sealant on the sealing surfaces of the diaphragm material.closed it up with the four tabs and added a layer of JB weld after vacuum tested. I should be able to clean up the JB and polish it up to barely noticeable.
I think the 123 is still something I will consider but hopefully this works for a while until I can afford one.
I also loosened up the adjustment screw and got it moving. Next step is to understand how to adjust it exactly. If I turn the screw clockwise i lessen the advance is what it seams to me. Is that correct? |
Posted: Fri Aug 01, 2025 6:05 pm Post subject: Re: Jeremiah's 73 412 restoration project |
Glad you tore this apart. I have several I have done this to over the years. I am not sure if I ever posted those pictures.
I actually uncrimped mine all the way around...trashed a trashed one figuring out how to do it without dangling it so I could crimp it back together.
For a long time I worried about what exact material to make the diaphragm from. But after looking it over and realizing that as long as it was che.ically decent, thin enough to fit and could handle about 250° F....it really does not matter. It's all about vacuum area and spring tension.
But today ai spent about 20 minutes taking a few pictures of about five different part numbers all of which can work with some small mods. I point out the details other than just internal spring tension that make them different to each other and post tomorrow or Sunday. Ray |
