Type 3 retractable 3 point seat belts
dc1962cars
dc1962cars is offline
PostPosted: Thu Jul 31, 2025 4:24 am    Post subject: Type 3 retractable 3 point seat belts Reply with quote
Hello all,I'm looking to install 3 point front seat belts in my 69 Fastback.The PO upholstered over the pillar mounting holes. I can feel the mounting hole is there but am hesitant to pock a hole there to mount the shoulder part of the belt.I would like to know what size and type of bolt is used to mount the belt to the pillar.I want to make sure I have the right parts before I start and that these mounting bolts available?Thanks
64 Beetle
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Jul 31, 2025 8:31 am    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
Didn't your belt kit come with bolts?
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Thu Jul 31, 2025 12:37 pm    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
Most seat belt kits come with 7/16ths-20 bolts and nuts, and washers sized for that size bolt. At least the last 4 belt kits that I've bought came that way.
They came with two 7/16-20 bolts, nuts, lock washers, and huge flat washers per belt assembly. I think the bolts were 1.5 inches long.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
dc1962cars
PostPosted: Thu Jul 31, 2025 1:22 pm    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
Thanks for the reply.I haven't purchased the belts yet(J Bugs).I have lap belts now that came with bolts to mount to the floor but those mounting points don't really require the belts to pivot.I want to go with 3 point belts for safety.On my 69 Fastback the pillar mounting hole where the shoulder part of the 3 point belts mount have been covered up with upholstery by the PO.I inserted a small probe in that mounting hole today to make sure it was a threaded,it is threaded.I know there are mounting bolts that come with the new set of belts but I beliece the shoulder or piller mounting point of the belts requires a shoulder bolt so that part of the belt can piviot without coming loose.Not sure if thats correct but I want to make sure I can find all the right parts before I order the belts.J Bugs has a sale on now so I need to order soon.Thanks for your patience.
64 Beetle
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Jul 31, 2025 2:04 pm    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
So, buy a 7/16-20 bolt to try in the B pillar!
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
KTPhil is offline
PostPosted: Thu Jul 31, 2025 2:35 pm    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
Here is what I bought:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7401093
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
sctbrd
sctbrd is offline
PostPosted: Thu Jul 31, 2025 10:06 pm    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
Parts book page 118 shows p/n 111 857 793 C, 7/16" bolt with collar.
https://www.thesamba.com/vw/archives/manuals/type3_parts_book/Type_3_Parts_Book_Group_8_Body.pdf
dc1962cars
PostPosted: Fri Aug 01, 2025 7:57 am    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
Thanks for the information on the shoulder bolt located in the parts list you sent.I didn't know original lists like that were avaiable. I'm downloading the parts list attachment for future reference.I also found and purchased the mounting bolts that I needed listed on The Samba .Thanks for everyones help and all the great information.
64 Beetle
Bobnotch
Bobnotch is offline
PostPosted: Fri Aug 01, 2025 10:59 am    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
Yeah, the seat belt bolts are the only American (SAE) hardware on the car. This is because seat belts were mandated in the USA in 1966 before any other country required them. If your car is early early, then you'll need the threaded adapter (WW sells them) to screw into the factory holes (I had to do that on my 64 T-34). Most times these adapters were used on the tunnel and "B" post (shoulder mount). If you're adding 3 point belts, you'll have to drill a hole in the floor for the 3rd mounting point and use the hardware that comes with the belt kit(2 large washers for sandwiching the floor, the end of the belt, the nut and lock washer, and the bolt itself). I hope this helps.
Tram wrote:
Tram wrote:
dc1962cars
PostPosted: Sat Aug 02, 2025 1:25 am    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
I have retractable lap belts in the car already so I have all the right bolts and the 90 degree bracket for mounting the retractor.The only item I wasn't sure of was the pillar mounting bolt.Thanks
64 Beetle
Bobnotch
Bobnotch is offline
PostPosted: Sat Aug 02, 2025 10:14 am    Post subject: Re: Type 3 retractable 3 point seat belts Reply with quote
You should be good to go then. Just check the metal around where you intend to mount the lower mounting for the belt, to make sure it's nice and solid (for safety sake, as you don't want it ripping out).
Tram wrote:
Tram wrote:
