DirtCheapFrank Samba Member
Joined: August 20, 2023 Posts: 76 Location: Walla walla Wa
Posted: Sat Aug 02, 2025 2:40 pm Post subject: Sunroof delete/shave |
Anyone deleted or shaved a metal sunroof. Mine on my 71 sb is annoying and I could care less if I had it. I've been scheming with my dad and we were thinking that the lip of the sunroof could be folded out then welded flush or a piece of metal to fill the gap. _________________ Save the Super Beetles
Instagram @super.slammed |
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 590 Location: South Bay LA, California
Posted: Sun Aug 03, 2025 8:10 am Post subject: Re: Sunroof delete/shave |
Not sure just how seriously you take your screen name or how your metalworking skills are, but there should be an ample supply of donor cars rotted beyond repair from the bottom up that still have good roofs you could splice in.
That way you can be sure all the contours are correct.
Would create a good time to remove any insulating foam before it becomes death foam while you’ve got it apart. |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 522 Location: Eastern north carolina
Posted: Sun Aug 03, 2025 9:00 am Post subject: Re: Sunroof delete/shave |
As Rob said I would look for one in local junkyards, pick and pull, etc and bring your sawzall and section a roof. That I think would be the easiest and produce the best result. Good luck-Bob |
Marks_Bug Samba Member
Joined: October 23, 2022 Posts: 70 Location: Edmonton, Canada
Posted: Sun Aug 03, 2025 9:57 am Post subject: Re: Sunroof delete/shave |
Why is it "annoying"? I rarely use mine but I don't find it annoying- it's just there and part of it's character and history. Besides, I'm one of those "If it ain't broke don't waste money fixing it" kinda guy! _________________ I'd be perfect if I wasn't so humble
Current driver: '74 Standard "Sun Bug" Others owned- 1959 Beetle, 1959 Beetle, 1969 Beetle, 1971 Type 3, 1978 Bus |
Posted: Sun Aug 03, 2025 10:41 am Post subject: Re: Sunroof delete/shave |
Marks_Bug wrote: |
Why is it "annoying"? I rarely use mine but I don't find it annoying- it's just there and part of it's character and history. Besides, I'm one of those "If it ain't broke don't waste money fixing it" kinda guy! |
Im tired of dealing with the mechanism and seals. I siliconed it shut cause it leaked so bad. Idc anymore and I also wanna do some cool patterns on my roof. _________________ Save the Super Beetles
Blue Baron VW Aficionado
Joined: June 16, 2006 Posts: 28271 Location: Free State of Florida
Posted: Sun Aug 03, 2025 10:45 am Post subject: Re: Sunroof delete/shave |
The dirt cherap solution would be just to cut another roof skin and overlap it. _________________ We are striving for perfection, to make our cars run forever, if possible.
Heinz Nordhoff |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2927 Location: HdG, MD & NJ
Posted: Sun Aug 03, 2025 10:55 am Post subject: Re: Sunroof delete/shave |
Silicone it closed for now. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Bugone Samba Member
Joined: February 02, 2008 Posts: 30 Location: Oklahoma City, Oklahoma
Posted: Thu Aug 28, 2025 11:07 am Post subject: Re: Sunroof delete/shave |
I've owned a number of the metal sunroof sedans and worked on them all.
First, get a Bentley Official Service Manual. Secondly, there are some good videos on YouTube that are helpful.
If your sunroof leaks it's probably the drain tubes. As the manual says, the sunroof seals were never designed to stop the leaks, the water catches in the tray and flows out the tubes.
Before I would "delete" the sunroof I would explore fixing it. With a little time and effort they are not difficult to make work correctly.
And as has been noted, if you get it closed with the seals on, drain tubes clear, and leave it alone it still looks great and part of the history of the vehicle.
I hope this is helpful.
Keep on Buggin'
Brian "Bugone" |
OldSchoolVW's  Samba Member
Joined: July 03, 2020 Posts: 1469 Location: San Diego
Posted: Thu Aug 28, 2025 11:30 am Post subject: Re: Sunroof delete/shave |
Bugone wrote: |
Before I would "delete" the sunroof I would explore fixing it. With a little time and effort they are not difficult to make work correctly. |
I think the main problem with fixing the sunroof mechanism is the poor fitment of the replacement parts available today. It can be next to impossible to get the sunroof to work with these aftermarket parts. If you know of a source that is selling OEM quality sunroof parts please let us know.
Bugone wrote: |
Mine works if you baby it, but I really never use it. I agree, If you can get the drain tubes clear, close it up and let it be. _________________ Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Bugone Samba Member
Posted: Thu Aug 28, 2025 7:40 pm Post subject: Re: Sunroof delete/shave |
I agree, the aftermarket parts we get today are not up to the standard of the OEM and that causes problems in all areas of restoring a VW to original condition. It's sad but it's what we have to work with if we want to keep our old VWs running and enjoy them.
Unfortunately I do not have a source for original quality sunroof cables but I have not had any problems with the cables from Wolfsburg West. I read another post about sunroof cables saying they had trouble with the Wolfsburg West cables "breaking". I do not know what that means but I do know that several years ago it was not possible to get a good set of cables. I waited about 6 months at one point. During that time there were a lot of bad reproduction cables and I know that you had to get a pair from the same manufacturer. If you tried to buy one cable from one source and the other from another they would not work. The problem I saw was that the cable ends would pull off, but I never had a cable "break".
I suspect that many of the problems are with the adjustments. If the cables are not exactly in sync the roof will bind, and if a lot of pressure is applied with the crank handle you will damage the cables.
I did some looking today and I see that JBugs now says that their cables are a "new high quality OEM part". I have not tried them so I can't speak to their quality. Might be worth a shot if you've had trouble with the Wolfsburg cables!
Good luck and Keep on Buggin'
Brian "Bugone" |
Posted: Thu Aug 28, 2025 7:42 pm Post subject: Re: Sunroof delete/shave |
"Its part of the history" "just fix the drains" "preserve your car"
Womp womp its not like a sunroof super beetle is that rare. The car is ruined anyways.
It looks ugly, I need to fix it. _________________ Save the Super Beetles
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1694 Location: Eerie PA
Posted: Fri Aug 29, 2025 5:08 am Post subject: Re: Sunroof delete/shave |
Ok first off when someone replies with womp womp it really annoys people, people who are trying to help. Grow up a bit.
Here are your options
1. Get another roof section cut out your sunroof and give it to someone who will use it and weld in the new section.
2. Fiberglass the seams and bondo the roof smooth
3. Weld the seam up leaving the sunroof in there.
4. Use fiberglass reinforced bond and fill the seam finish with regular bondo.
Only one of these options is a correct course of fire. It’s the 1st one but it sounds like you don’t care about that so have at it. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
Another 65 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
