telford dorr Samba Member
Joined: March 11, 2009 Posts: 3627 Location: San Diego (Encinitas)
Posted: Mon Oct 31, 2016 10:29 pm Post subject: Re: Vibrator got ya down? |
| SGKent wrote: |
| I saw the note from Old DKP Driver. He indicated VW had some issues with the screw coming loose. If so, I suspect that with a loose screw and no ground then the full 12V would reach the gauge and sender - is that correct Telford? |
Yes indeed. Without a ground, the zeners are out of the circuit, and there's nothing between the battery voltage and the gas gauge other than the resistor. Now that will drop the voltage a little, but nothing like the zener(s) will. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Tue Nov 01, 2016 4:56 pm Post subject: Re: Vibrator got ya down? |
| me, previously wrote: |
| But that wasn't the problem here. The problem is the wire-wound resistor gets really hot - hot enough that it's resistance goes up. We saw it more than double during a short bench test. The side effect is, as the resistance increases, less current flows through the zener diodes, until it reaches zero. Then the voltage to the fuel gauge starts to drop, and the gauge slowly goes to empty. I'll have to do a proper bench test on this unit and document the changes in more detail. |
Well, no - it wasn't the resistor - it was the case. Pulled the resistor and zeners out of the case and did a bench test. The resistor is actually a 27 ohm, 6 watt wire-wound unit. The zeners are 1N4733A 5.1 volt 1 watt units.
At 14.4 volts, the resistor current is around 335 ma. The datasheet test current for this zener is 49 ma. For two in parallel (and assuming equal current sharing), that would be 98 ma. The rated zener voltage is specified at the test current. Running more current will cause the zener voltage to increase a bit. At 335 ma, the zener voltage creeps up to 5.44 volts. The resistor is dissipating 3 watts. The zeners are dissipating 1.7 watts between themselves. With these components removed from the case, the readings are stable.
So, what's going on here?
It turns out that the case is made from a black thermoplastic which softens easily. The various metal components are assembled using a rivet. Unfortunately, the plastic case is part of the metal and rivet sandwich. Consequently, the metal to rivet to metal connection is quite loose. This looseness adds thermally triggered unwanted additional resistance to the circuit.
Now Steve started to solder the external metal parts together, but did not do the internal connections because the resistor was in the way. Unfortunately, this internal connection was flaky. Soldering the internal metal to the rivet has solved the problem.
If you have one of these units, and it is acting flaky, and you want to repair it, do the following:
1 - get a good temperature-regulated soldering iron, and some 60-40 (or better, 63-37) tin-lead radio solder, and some rosin paste flux.
2 - open the unit. Remove the metal cover plate. It will be retained by the zener diode ground wires. Unsolder the zener ground lead from the metal cover plate, and set the plate aside.
3 - unsolder the 27 ohm resistor and remove.
4 - bend the zeners out of the way. There will be a metal bracket that is retained by a rivet. Flux the plate and rivet, then solder them together. Work quickly, as the soldering process will soften the plastic case.
5 - on the outside, solder the other end of the rivet to the metal plate and female terminal it passes through. It will be hot from the previous soldering. Again, work quickly to avoid damaging the case too much.
6 - reinstall the resistor previously removed.
7 - resolder the zener ground leads to the cover plate. Carefully bend the zener leads such that the cover plate can be replaced without the zeners shorting against anything.
8 - on the unit I have, the plastic ear clips which hold the cover plate on aren't up to the job, so a little tape or some tie-wraps are needed to hold the unit together.
While the 5.44 volt output voltage is a little greater than the factory unit voltage, it is close enough to be useful. The gauge will probably read slightly more full than normal - can't say how much, but it wont be much.
Now this unit, while usable, is not as good as a proper factory unit.
I'm still going to build a series regulated circuit using this case. It should be much cooler running than either the factory unit or this repop unit. Stay tuned...
Note: zeners removed completely for clarity.
Here's the unit schematic:
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42801 Location: at the beach
Posted: Tue Nov 01, 2016 9:15 pm Post subject: Re: Vibrator got ya down? |
you the man!
Oh - Cathy told me tonight. She has some DARR, DORR and DERR in her family during the American Revolution. The DORR has two .. over the O. You may be distant cousins if your family lived in PA during the War of Independence. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
Posted: Wed Nov 02, 2016 10:07 am Post subject: Re: Vibrator got ya down? |
Nope. New York, then Canada somewhere, then Minneapolis. _________________ '71 panel, now with FI
SGKent  Samba Member
Posted: Wed Nov 02, 2016 10:55 am Post subject: Re: Vibrator got ya down? |
| telford dorr wrote: |
| Nope. New York, then Canada somewhere, then Minneapolis. |
Canada ~ left after the Rev War? _________________ George Carlin:
"never time to do it right but always time to do it twice"  |
Posted: Wed Nov 02, 2016 11:00 am Post subject: Re: Vibrator got ya down? |
Middle 1800's to now. Don't know before that. _________________ '71 panel, now with FI
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Fri Nov 03, 2017 7:20 am Post subject: Re: Vibrator got ya down? |
Just a couple of notes to complement this great thread, as I was working on this yesterday:
I've got one of the original but newer VDO voltage regulators, that is, a Zener diode + light bulb instead of a mechanical vibrator. Its VW part # is 211 919 051 A.
I observed that with no load, and varying the input voltage from 11.5 V to 14.4 V, the output voltage is 5.353 V (@ 12.6 V) +/- 0.03 V across the range.
However, when adding a load (i.e. the gauge and the sender), and given a constant input voltage of 14.4 V, the voltage regulation is not as rock solid:
• With empty tank (76,2 Ohm on the sender, min load), the regulator output is 5,332 V
• With full tank (5,8 Ohm(*) on the sender, max load), the regulator output is 5,116 V
That is, a voltage drop of 0,2 V from minimum to maximum load. Here is the wiring diagram of the sender, gauge and regulator system as a reminder.
On a separate note, while calibrating the system, I could not find an authoritative source for the sender resistance specs. There are a few places that list them, but all slightly different: 10-73 Ohm from Justkampers, 10-80 Ohm from VW Heritage and 10-70 Ohm from type2.com.
From the calibration exercise, I'd say that the 10 Ohm (full) and 80 Ohm (empty) specs seem to be what worked best for my (Late Bay) fuel gauge. The "full tank" resistance value seemed to be the most critical, and I had to bend the stopper tab on the sender to get a 10 Ohm reading and get the gauge needle to be on the full mark. At 76.2 Ohm for "empty tank", I could have adjusted it to 80 Ohm, but the needle was close enough to the empty mark and I left it alone. A few Ohms there don't seem to make as much difference as at the other end of the scale.
(*) Originally, the "full tank" value on my sender was 5.8 Ohm, which caused the needle to go way past the full mark. As mentioned, bending the "full tank" stopper tab to stop the float at 10 Ohm brought the needle back to the full mark.
| I'm still going to build a series regulated circuit using this case. It should be much cooler running than either the factory unit or this repop unit. Stay tuned... |
This also got me curious... Telford, did you ever get round to retrofitting a modern circuit into the original VDO case?
Thanks. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate
SGKent  Samba Member
Posted: Fri Nov 03, 2017 7:33 am Post subject: Re: Vibrator got ya down? |
calibrating the sender on a late bay (swing arm float) is a problem in part because the original floats were flat on the top. This allowed the float to rise higher in the tank when full. The new ones are round and hollow so they ride different. The arm must be bent to fool the sender into thinking the float is higher than it is or the gauge will never read over 3/4.
Everyone should be aware that the aftermarket vibrators are JUNK. The wires inside are twisted and not soldered, the electronic parts are just stuffed inside. There are also some cheap looking ones that say VW on them but they are forgeries because in no way do they approach the quality of a real VW one. Telford's if you can pay him to make you one, or a factory unit are the only two I would trust. The others will burn up your gauge eventually and NOS gauges are getting rare these days. This is a real one -
furgo Samba Member
Posted: Fri Nov 03, 2017 8:41 am Post subject: Re: Vibrator got ya down? |
| SGKent wrote: |
| calibrating the sender on a late bay (swing arm float) is a problem in part because the original floats were flat on the top. This allowed the float to rise higher in the tank when full. The new ones are round and hollow so they ride different. The arm must be bent to fool the sender into thinking the float is higher than it is or the gauge will never read over 3/4. |
Bummer, and I thought I was done with calibration
I've found this old thread of yours that goes into the details. Thanks for the heads up.
My VDO sender has the cylindrical/round-ish float (i.e. not flat at the top), so I guess in addition to modifying the stops, I'll have to bend the arm too (away from the top wall) once I put it into the tank.
Here's an upside-down picture of what it would look like from inside a full tank. I guess that even though the float does not reach the plane where the lid is located, it might still touch the top wall (as the tank's top is not flat, if I remember correctly?).
Please ignore the tape. It's just there to temporarily hold the metal case until I finally close the metal tabs once the sender is fully restored. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Posted: Fri Nov 03, 2017 8:57 am Post subject: Re: Vibrator got ya down? |
| furgo wrote: |
That is, a voltage drop of 0,2 V from minimum to maximum load. |
That's typical for a zener diode. Contrary to popular opinion, the voltage regulation of a zener varies a little as the current flowing through it varies. In actuality, a zener is only constant when operated at a constant current (e.g. as a reference for another circuit which controls the actual power).
That said, I'm not sure it makes all that much difference for a fuel gauge. But the conversions I build use a LM317T regulator IC, and are rock solid.
Here's the circuit:
I gut the original regulator and build the circuit into it. That way, it fits and connects just like the original. _________________ '71 panel, now with FI
SGKent  Samba Member
Posted: Fri Nov 03, 2017 8:59 am Post subject: Re: Vibrator got ya down? |
the way I calibrated mine was when the tank was out of the bus after cleaning it. I wired it up to the bus and used a yard stick thru the opening for the filler to raise and lower the float. The float would hit the top of the tank at about 3/4 indicated. I kept bending the arm until the float read full when it was all the way up, then set the bottom stop properly. Shinning a flashlight thru the filler I could also see about 1/4 and 1/2 so those were close too.
I found these photos in the gallery. Different variations of why they read differently. Don't like the idea the metal hoop touches / wears on the inside of the tank when it is full.
furgo Samba Member
Posted: Fri Nov 03, 2017 9:35 am Post subject: Re: Vibrator got ya down? |
All clear now, I guess there is some more calibration to do once the sender is in the tank.
Thanks Telford and SGKent. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52939 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Jul 02, 2018 10:26 am Post subject: Re: Vibrator got ya down? |
| sestino wrote: |
I received the Chinese adjustable voltage regulators in September and mailed one to Telford a few weeks ago. I'll let him express his opinion, but in a PM he said he thought it could work in place of a vibrator.
I haven't used one yet because my gas gauge works now after I pulled the motor and put in a new sender in the tank. |
Anyone have any long term real life experience with these yet?, they certainly seem promising, _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
furgo Samba Member
Posted: Mon Jul 02, 2018 12:52 pm Post subject: Re: Fuel Gauge Vibrator got ya down? FAQ |
There are many variations of this module. I've got the slightly less cheap version with current limitation and screw terminals for another application. Essentially it was cheaper and less time consuming to buy it than to solder discrete components.
Same chip, similar components. It's been working well for a few months, although admittedly I only use it occasionally.
All the SMD components should withstand vibration well. If it were to go on the bus, I'd put some glue or wax on the potentiometer once the output has been calibrated, though.
The only downside I'd see would be that it probably does not fit into the original enclosure, and a new enclosure for the module would have to be built. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Mon Jul 02, 2018 12:57 pm Post subject: Re: Fuel Gauge Vibrator got ya down? FAQ |
Thanks, I have a Super beetle and a Datsun that are acting up at the moment, since you can't see it the new enclosure doesn't matter, I just want it to work and not come back, sounds like it'll do everything I need it to. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Blue69Baja Samba Member
Joined: September 04, 2008 Posts: 1119 Location: Fair Oaks
Posted: Fri Dec 14, 2018 10:51 am Post subject: Re: Fuel Gauge Vibrator got ya down? FAQ |
Another gauge, vibrator thread here that I started.
I like the regulator idea, needs to be adjustable. The sad is the meters avail now need to be adjusted too if one wants the gauge to be close to accurate.
Not sure if anyone knows that the original electro mechanical vibrators were adjustable....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
Jim _________________ 69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original.. |
Posted: Fri Dec 14, 2018 11:05 am Post subject: Re: Vibrator got ya down? |
| sestino wrote: |
Bump.
I don't understand all of the discussion of electronics, but I saw above that one of the components is an adjustable voltage regulator.
I just stumbled across this adjustable voltage regulator on DX.com selling for $1.80 plus shipping.
http://www.dx.com/p/20083-adjustable-power-supply-...7PGqCgrI2w
Could this inexpensive piece be used in place of the vibrator? One commenter on DX.com wrote:
Pros:
Simply and sturdy board for DIY aplications, ideal to branch to a 12-24V line and reduce to 5 or 3.3V MCU application. Just branch and adjust the tension using the potentiometer.
Cons:
Limited to 2.5 A, means that you must have that current limitation in your proyect. Not sutable for motors or other stuff, but it can be very useful for install a led bar in a car or add sensors on a industrial installation.
This is the same Buck regulator I am working with right now.
Thread here:
One has to be aware that out of the box it is set for max output voltage and it can fry your gauge. Takes <>20 turns CCW to start reducing the output voltage. Put a load on the output and adjust to <>5.5vdc to start with.
There will be some AM radio interference with this unit, just so you know.
Some guys using them in other non-vehicle applications remove the Pot after proper voltage has been adjusted and replacing the pot with a fixed resistor.
The bad is, if the pot opens the output voltage will rise to max... Gauge fries. A simple solution would be to put a 7vdc zener across the output... Zener shorts if the output voltage can not be regulated to 7vdc. Put a small 500ma pico fuse in the input and that should work for protection of the regulator from getting hot.
Posted: Sat Jan 05, 2019 1:11 pm Post subject: Re: Vibrator got ya down? |
A great post!
I just read this post while working on the same issue. Resistor diode instead of bulb diode...
They both work differently. currently wrapping up the regulator changes needed for the 33 ohm gauges. What a cluster f(*&(9,.... The 33 ohm gauges really throw a wrench into the mess.
Here is a great thread that is a take off another thread about calibration:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8970183#8970183
megachaos Samba Member
Posted: Fri Aug 08, 2025 5:26 am Post subject: Re: Fuel Gauge Vibrator got ya down? FAQ |
...6 years later:
+12V---Vibrator (Voltage Stabilizer/Regulator to 5,1V)---Fuel gauge---Long wire---Fuel sender---ground/body:
We have 3 simple electromechanical components: Voltage regulator, Gauge, Sender. It is a more than 50 year's old design, but at that time it was very precisely and high quality made. Those times are gone! There is No Longer Available NEW Vibrator or NEW HQ Sender. So let's take a closer look at it:
1: Voltage regulator – Vibrator is perfect component, but it is more than 50 years old, so it will break. When it breaks, it can be repaired electrically, but it will definitely break again. When it breaks, it will pass the entire 12V voltage and that will fry the Gauge or Sender or both of them. The last thing you want in your gas tank is a burning Sender or heating coil! Electronic regulators (zener diodes, LM7805, LM317...) are great because they won't fry the Gauge or Sender. Unlike a working vibrator, which constantly switches the circuit ON and OFF, electronic regulators keep the circuit ON all the time. The electronic regulators must be in good working condition, otherwise the Sender still functions as a heating coil. Note: With the broken vibrator, I measured the current through the Sender from 0.1A to almost 1A! The Sender actually burned out and when I replaced it, the new one started burning too... (Pict.: Fried Original vs. Aftermarket sender)
Result1: I will leave out this voltage regulator/vibrator as a separate component!
2: Gauge – My Gauge still works, but it was almost fried and adjusting the Needle is now quite tricky.
Result2: No problem - if I want to omit the Vibrator/Regulator, I have to replace the Gauge.
3: Sender – The resistance wire was originally wound exponentially with high precision and quality material was used - This is No longer available. Aftermarket sender = Rubbish! The wire is wound poorly, linearly and breaks easily. Since another one cannot be bought, it is forced to use it. It is almost impossible to adjust it with a satisfactory result for the original vibrator and gauge.
Result3: The aftermarket sender must to be set up so, that it can be used successfully and does not function as a heater - so that it is completely Safe!
Process:
1. On the new Sender, we set the resistance range to 10 ohms for Full tank and approximately 80 ohms for Empty tank – by bending the stops. Then we bend the arm so that it copies the full stroke height in the tank of 200mm.
2. Now we can use an ohmmeter to measure the values between E and F according to the known values of the angles or levels. My aftermarket ClassicLine has: E=79ohm, R=67ohm, ¼=51ohm, ½=30ohm, F=10ohm. I made a cardboard jig for this, but the lines drawn with a protractor on the table are quite sufficient.
3. Making an electronic Gauge is easy thanks to the complete files from Pegor Karoglanian in the link below (except Uploading the programm to ATtiny85 – some issues are there with the right version of Servo libraries and also version of ATTiny Board installed in Arduino IDE). But Pegor shared all of the files, that You need – simply download it.
What You need:
a) A Friend with 3D printer (filament ABS, ASA, PA..., 0€)
b) Some money for electronic components (tme.eu, aliexpress, digikey..., cca 15€)
c) From Pegor downloaded files for made the PCB (pcbway.com, 6€ - for that price you actually get 10 pieces, so... 0.60€/each? ...hmm)
d) Some time for assembly this electronic Gauge and installation to dash (without old Vibrator and old Gauge). There is necessary to drill one hole (5mm) for new Gauge ground. (see Pict.)
e) Measure and edit the Sender resistance values in the SmoothBus.ino program for your new Gauge.
f) A Friend with Arduino UNO or MEGA as SPI programmer (0€) or buy Arduino Uno R3 with ATmega328P chip (20€)
g) After checking the functionality, if necessary, edit the servo position values in the program and upload again.
Programming with Arduino UNO R3 with ATmega328P chip:
1. Download and install „Arduino IDE“ to your computer (at this time is latest version 2.3.6).
2. Paste this link: http://drazzy.com/package_drazzy.com_index.json into IDE to File/Preferences-Additional boards manager URL´s column, click to OK and in IDE´s Boards Manager install ATTinyCore Boards by Spence Konde (v1.5.2).
3. Write/Upload to the Arduino UNO Sketch from File/Examples „11. Arduino ISP“. (see Tutorial on Youtube – link bellow)
5. PinUp the assembled gauge to Arduino UNO and set the IDE as programmer (see pict.).
6. Write to your new ATTiny85 the Bootloader.
7. Upload the SmoothBus.ino sketch to ATTiny85 via Arduino UNO as ISP.
Final: The voltage regulator is part of the new Gauge. The current through the Sender is in the range of 85mA at Full to 40mA for Empty. These are values similar to a system with a well-functioning original Gauge and electronic Regulator. The needle on the Gauge now shows accurate fuel values in the tank despite the poor quality of Aftermarket Sender.
This tutorial is also useful for me, because I struggled with uploading the program to the ATTiny for about 2 weeks (I saw ATTiny and Arduino for the first time in my life).
Links for download all the files and more infos:
1. Files for made the Gauge https://github.com/PegorK/SmoothBus/blob/V2/README.md
2. Tutorial for upload the programm with Arduino https://www.youtube.com/watch?v=sycSdI49hlY
3. Support for Arduino IDE software: http://drazzy.com/package_drazzy.com_index.json
4. Infos https://www.type2.com/library/misc/vwggauge.htm
5. Infos https://www.thesamba.com/vw/forum/viewtopic.php?t=693930
Note: I had to make some modifications to the Pegor's files: LED_1 and LED_2 should be orange (not red), the spacer should be 5mm thick for better gauge placement, the needle should be 4mm shorter, and my 3D model of the case is more durable.
Well - And (thanks to Pegor) now you have SAFE and fully functional Fuel gauge for 20~30€ – Hooray! ...and I have another 9 pcs for sell. |
kpf Samba Member
Joined: March 01, 2017 Posts: 1061 Location: California, US
Posted: Fri Aug 08, 2025 8:16 am Post subject: Re: Fuel Gauge Vibrator got ya down? FAQ |
Fantastic! Thank you!  _________________ 1971 Super Beetle |
