Floorplan mystery hole
dark lord oval
dark lord oval is offline
PostPosted: Sun Aug 10, 2025 7:34 am    Post subject: Floorplan mystery hole Reply with quote
Been too long since the pan and body were together on my 63 coupe and I forgot some details
What goes in this hole in the pan either side of the torsion bar housing ?
Thanks bolt above said hole, does it use the big square washer as per either side of the heater channels ?
Thanks
Loren Premium Member
Loren is offline
PostPosted: Sun Aug 10, 2025 10:17 am    Post subject: Re: Floorplan mystery hole Reply with quote
A rubber plug goes there. You used to be able to get these new, but I don’t know of any reproductions available now.
dark lord oval
PostPosted: Sun Aug 10, 2025 1:28 pm    Post subject: Re: Floorplan mystery hole Reply with quote
Thanks.
Anyone have knowledge of something similar that will fit ?
Also does the bolt above use the square washer ?
Loren is offline
PostPosted: Sun Aug 10, 2025 1:38 pm    Post subject: Re: Floorplan mystery hole Reply with quote
The square washer goes on the bolt for the rear shock tower
Ian Godfrey
Ian Godfrey is offline
PostPosted: Sun Aug 10, 2025 4:04 pm    Post subject: Re: Floorplan mystery hole Reply with quote
you can get the oval plug from the 'thing' shop, there are other ones out (on the right) there but the one on the left fits.
dark lord oval
PostPosted: Sun Aug 10, 2025 11:31 pm    Post subject: Re: Floorplan mystery hole Reply with quote
No , I meant the square washers down the heater channels/rockers, does that bolt use one of them ?
dark lord oval
PostPosted: Sun Aug 10, 2025 11:33 pm    Post subject: Re: Floorplan mystery hole Reply with quote
Great thanks !
