1980 CA exhaust replacement choices
JDub113
JDub113 is offline
PostPosted: Tue Aug 12, 2025 8:50 am    Post subject: 1980 CA exhaust replacement choices Reply with quote
My air cooled exhaust is dented up but functional. I want to replace it so I don’t haven any future engine problems. Has anyone used Vintage Speed headers and muffler? Would that be good for performance and cht? No smog and I have a Webber carb.
CA exhaust
Vintage Speed
84 Wolfsburg Edition Westy
Mateo83
Mateo83 is offline
PostPosted: Tue Aug 12, 2025 9:40 am    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
Seems like it would work. I thought I read someone here saying it was pretty loud.
83 Air-cooled 2.0 Tin Top
zerotofifty
zerotofifty is offline
PostPosted: Tue Aug 12, 2025 9:52 am    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
I dont know about the aircooled Van, but I found on the wasser boxer Van many of the so called "stock" aftermarket exhaust made in Europe was of poor fit, mounting flanges not lining up, needing lots of work to fit leak free. And I mean LOTS of work, rebending the pipes, cutting off flanges and rewelding, it was that bad, not a "slight missaligning that can be cured with a push. I returned them and went with NOS factory from VW parts dept, found that it was a PERFECT fit at all flanges and gaskets.
For the water cooled Vans, I recommend trying to keep the stock factory exhaust if so fitted, unless you are going for some high performance stuff. Factory stuff fits perfect.
That is not to say that all aftermarket wont fit, my story was from like 20 years ago, and that NOS factory exhaust is still running fine today.
Note that for Bug heater boxes, factory has rather large aluminum heat transfer fins cast over the exhaust pipe that runs in the box. This greatly improves cockpit heat!!! Many aftermarket reproduction "stock" Bug heater boxes do not have any aluminum fins in them, just a bare exhaust pipe, so poor heat transfer, and that makes a VERY wimpy heater. This may or may not be the case with Van heater boxes. Just be aware that this can happen.
Good luck
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
JDub113
JDub113 is offline
PostPosted: Tue Aug 12, 2025 10:10 am    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
Good luck
This is about a 1980 Aircooled Vanagon only.
zerotofifty
PostPosted: Tue Aug 12, 2025 10:25 am    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
JDub113 wrote:
Good luck
I guess I am being sent to my room now, Jeez mom. Laughing
Words to live by.
Xevin Premium Member
Xevin is offline
PostPosted: Tue Aug 12, 2025 10:42 am    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
JDub113 wrote:
Good luck
Would you accept opinions from 2L Type4 engine owners with Bay Window buses?
So no. Copy that.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
Wildthings
Wildthings is offline
PostPosted: Tue Aug 12, 2025 10:46 am    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
Dented up shells on the heat exchangers will not hurt much, but excessive rust on the pipes inside the HXs themselves will, but your van typically needs to have seen road salts for this to be a problem.
Switching your entire system over to a Federal system would be an alternative. Don't know the difference in price though.
JDub113
JDub113 is offline
PostPosted: Tue Aug 12, 2025 10:53 am    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
Looks like csp headers sold through heritage parts would work too and a stock federal exhaust.
JDub113
JDub113 is offline
PostPosted: Tue Aug 12, 2025 11:34 am    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
Well I ended up buying the cheaper headers and stock muffler, its half the price.
MarkWard
MarkWard is offline
PostPosted: Tue Aug 12, 2025 1:27 pm    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
How did it fit up? Have you deleted the heat exchangers? It’s possible to run a bus muffler on an air cooled vanagons, but I remember you need spacers between the muffler and the stock exchangers for it to clear.
How about posting up a picture and what you sourced?
JDub113
JDub113 is offline
PostPosted: Wed Aug 27, 2025 7:00 pm    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
It turned out really nice. No spacers.
kamzcab86
kamzcab86 is offline
PostPosted: Wed Aug 27, 2025 7:57 pm    Post subject: Re: 1980 CA exhaust replacement choices Reply with quote
zerotofifty wrote:
many of the so called "stock" aftermarket exhaust made in Europe was of poor fit...
Vintage Speed, which the OP initially asked about, is in Taiwan and produces quality components, if their straight pipe I recently put on my (water-cooled) van is any indication. It arrived just 2 days after the shipping notification and included all hardware; fit perfectly between the original, crappy-looking J-pipe and shiny Magnaflow muffler.
~Kamz Anxious
2016 Golf GTI S
